Windows 7: SSD - Fix Misalignment
12 Jun 2012   #30
whs
Microsoft MVP
1. For the general question of what alignment of a SSDs means I recommend Google - especially Wikipedia.
2. Secure Erase cleans the SSD of all data which speeds up future Write operations. It does the same as Trim and Garbage Collection except that you get an immediate clean SSD rather than a cleanup over time. This article explains what happens: Garbage Collection and TRIM in SSDs Explained - An SSD Primer - The SSD Review
3. If you do a clean install, the Windows installer will align the SSD automatically. If you want to make sure that the 100MB system partition lands on the SSD, it is advised to disconnect all other disks during the installation. Why? - because the installer has the habit of placing the 100MB system partition on the disk with the lowest port number - and often that is not the SSD. Should you have the mishap of the 100MB system partition (and thereby the bootmgr) landing on another disk, I suggest to move the bootmgr to the C partition on the SSD. Bootmgr - Move to C:\ with EasyBCD. In fact I always move the bootmgr to C in all cases because that makes imaging and recovery a lot easier.
05 Jan 2013   #31
whs
Microsoft MVP
Quote   Quote: Originally Posted by Saurabh A View Post
Very useful
Thanks.
26 Jan 2014   #32
brummyfan
Thanks whs, great help
26 Jan 2014   #33
whs
Microsoft MVP
You are welcome.
There is a new free program on the market that claims to aling misaligned SSDs => AOMEI Partition Assistant. I have not yet tried it, but it is an option. My guess would be that you cannot do it on an active SSD from the installed program but need to do it with their bootable CD or stick. Else run the SSD in an external enclosure and do it there.
26 Jan 2014   #34
brummyfan
Quote   Quote: Originally Posted by whs View Post
You are welcome.
Yes, I used that new program and worked perfectly and it works in PreOS environment.
26 Jan 2014   #35
whs
Microsoft MVP
Do you mean in the RE (F8) ?
26 Jan 2014   #36
brummyfan
No, when I clicked "Partition Alignment" it rebooted in to Pre OS environment.
26 Jan 2014   #37
whs
Microsoft MVP
That sounds like it is going into RE. Interesting trick.
27 Jan 2014   #38
brummyfan
I did back up my Vista on to a hard drive and recovered with Macrium to install on a SSD but it was misaligned, then I saw your tutorial and tried AOMEI P Assist and amazed how easy it was to use the program.
27 Jan 2014   #39
whs
Microsoft MVP
Yeah, the AOMEI people seem to have done a good job. There is, however, still work in progress because there are some problems on a 32bit system.
Startup fade-in/out misalignment
First of all, this is nothing major. Just something that looks out of the ordinary and I've been trying to find out for a while why it does this (MUST.... UNDERSTAND.... EVERYTHING..... :mad:) At the welcome screen, you get this fade-in and fade-out deal, right? On my system, when it fades, it...
General Discussion
