SSD - Fix Misalignment
  1. Posts : 19,383
    It looks like I am a candidate for your tutorial Wolfgang - Patition 2 offset 101 MB not divisible by 4. I'll give it a go this weekend and post back here.
    Microsoft Windows [Version 6.1.7601]
    Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
    C:\Windows\system32>diskpart
    Microsoft DiskPart version 6.1.7601
    Copyright (C) 1999-2008 Microsoft Corporation.
    On computer: COLIN-PC
    DISKPART> list disk
      Disk ###  Status         Size     Free     Dyn  Gpt
      Disk 0    Online          931 GB  1024 KB
      Disk 1    Online          931 GB  6144 KB
      Disk 2    Online           55 GB      0 B
      Disk 3    Online          931 GB     8 MB
      Disk 4    Online          465 GB      0 B
      Disk 5    Online          465 GB  1024 KB
    DISKPART> select disk 2
    Disk 2 is now the selected disk.
    DISKPART> list partition
      Partition ###  Type              Size     Offset
      Partition 1    Primary            100 MB  1024 KB
      Partition 2    Primary             55 GB   101 MB
    DISKPART>
    EDIT : My bad . 101 MB = 103,424 KB which IS divisible by 4
  2. Posts : 12,177
    The first partition is the one that needs to be aligned.
  3. Posts : 19,383
       #12
    Doh! {face palm x 2}
    From Step 1:
    Note: This step only applies if you have the 100MB active System Partition
    Thanks Dave
  4. whs
    From Step 1:
    Thanks Dave
    You are OK. You fell into the classic trap. The second partition offset is in 101MB which is 101,000KB and very well divisible by 4.
  5. Posts : 12,177
       #14
    From Step 1:
    Thanks Dave
    You're welcome, no worries mate
  6. Posts : 24,479
    Windows 7 Ultimate X64 SP1
       #15
    whs said:
    Snakeyeskm said:
    Very nice and needed tutorial.
    Since this is aimed at SSD's, I would suggest a secure erase as an option to replace Step 3. This could be particularly important for smaller SSD's since the delete and re-imaging process would create a fairly large amount of activity for the internal garbage collection process. A secure erase would bring the SSD to "fresh" speeds.
    Good suggestion. Option added. Thanks!
    Does the Parted Magic do the same as the clean all command?
  7. whs
       #16
    I don't know. Maybe someone else knows.
  8. Posts : 475
    Windows 7 Pro x64 -- PCLinuxOS KDE4 FullMonty 2011
       #17
    Yes parted magic can do a secure erase.
  9. Posts : 24,479
       #18
    I know that, but is it the same as the diskpart clean all command which also writes zeros to all sectors?. The article says PM will take "Acouple of minutes" while clean all takes much longer. PM claims it is doing the same.
  10. Posts : 475
       #19
    I'm no expert not even close with using parted magic.
    I've used it a few times for doing a secure erase. First couple of times it took 1 or 2 seconds. Supposedly writing zeros.
    Next time I did it it went to an additional screen. (can't remember what it was about) This time for a 120gb drive it took 24 minutes. Supposedly writing zeros also.
