Applications - Prevent Running Specified Programs
    How to Prevent Users from Running Specified Programs in Windows
    This tutorial will show you how to prevent all or specific users on the computer from being able to run a list of disallowed program EXE files you specify in Vista, Windows 7, or Windows 8.
    You must be logged in as an administrator to be able to do the steps in this tutorial.
       Warning
    This will not prevent users from being able to run a program through the command prompt unless you also add cmd.exe to the list of disallowed applications.
    If you have an .exe file of a program in the list of allowed applications and also in the list of disallowed applications, then users will not be able to run the .exe. Anything disallowed will always override anything allowed.
    Renaming an .exe file will bypass the list of disallowed programs to let it run anyways, but not with the list of allowed programs. If the .exe file name is not on the list of allowed programs, then it can't run.
    This does not apply to "Metro" Store apps in Windows 8.
    EXAMPLE: Message
    NOTE: This is a message that all users will get when they try to run a EXE file on the list of disallowed programs that you specified.
    OPTION ONE
    Through the Local Group Policy Editor
    2. In the left pane, click/tap on to expand User Configuration, Administrative Templates, and System. (see screenshot below)
    3. In the right pane of System, double click/tap on Don't run specified Windows applications to edit it. (see screenshot above)
    4. To Allow All Applications to Run
    A) Select (dot) either Not Configured or Disabled, and go to step 6 below. (see screenshot below)
    NOTE: Not configured is the default setting.
    5. To Prevent Specified Applications from Running
    A) Select (dot) Enabled, then click/tap on the Show button under Options. (see screenshot above)
    B) Under Value, double click/tap in a blank line and type in the name of the EXE file (ex: cmd.exe) with file extension that you want to prevent from running. (see screenshots below)
       Tip
    • To change or remove a listed exe file name, you can just type over it.
    • To clear or reset the list of disallowed applications, you can select Not Configured (step 4), click/tap on Apply, select Enabled again, and click/tap on Apply.
    C) Repeat step 5B until you have added any other EXE files (ex: CCleaner) you want on the list of disallowed applications as well. When finished, click/tap on OK. (see screenshots above)
    D) Go to step 6 below.
    6. Click/tap on OK. (see screenshot below step 4A)
    7. If used, you may also wish to make changes to your list of allowed programs to run.
    8. Close the Local Group Policy Editor window.
    OPTION TWO
    Manually in Registry Editor
    NOTE: This option affects all users on the computer.
    1. Press the Windows + R keys to open the Run dialog, type regedit, and click/tap on OK.
    2. If prompted by UAC, click/tap on Yes (Windows 7/8) or Continue (Vista).
    3. In regedit, navigate to the location below. (see screenshot below)
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
    4. To Prevent Specified Applications from Running for Only Current User
    A) In the right pane of Explorer, right click or press and hold on a empty space, and click/tap on New and DWORD (32-bit) Value. (see screenshot below)
    B) Type in DisallowRun and press Enter. Double click/tap on DisallowRun to modify it. (see screenshot below)
    C) Type in 1 and click/tap on OK. (see screenshot below)
    D) In the left pane, right click or press and hold on Explorer, click/tap on New and Key, type in DisallowRun, and press Enter. (see screenshot below)
    E) In the right pane of DisallowRun, right click or press and hold on a empty space, and click/tap on New and String Value. (see screenshot below)
    F) Type in the number (1 to ....) of the order that this EXE file will be in the list of disallowed applications and press Enter. Double click/tap on this number to modify it. (see screenshot below)
    NOTE: For example, you would type 1 if this is the first EXE in the list, 2 if it's the second, 3 for the third, etc........
    G) Type in the name of the EXE file (ex: cmd.exe) with file extension that you want to prevent from running, and click/tap on OK. (see screenshot below)
       Tip
    • To change a listed EXE file name, double click/tap on the number of the EXE to modify it (step 4F), type the new EXE name, and click/tap on OK.
    • To remove a listed EXE file name, right click on the number of the EXE, then click/tap on Delete and Yes.
    H) Repeat steps 4F and 4G until you have added any other EXE files (ex: #2 CCleaner) you want on the list of disallowed applications as well.
    I) When finished, go to step 6 below.
    5. To Allow All Applications to Run for Only Current User
    A) In the right pane of Explorer, right click on DisallowRun and click/tap on Delete. (see screenshot below)
    B) Click/tap on Yes to approve. (see screenshot below)
    C) In the left pane, right click or press and hold on DisallowRun, and click/tap on Delete. (see screenshot below)
    D) Click/tap on Yes to approve, go to step 6 below. (see screenshot below)
    6. If used, you may also wish to make changes to your list of allowed programs to run.
    7. Close regedit.
    8. Log off and log on, or restart the computer to apply.
  1. Posts : 4
    Windows 7 Home Premium 32bit.
    problem
    Hi, my application goal that i would like to disallow it but in the second option don't worked for me, in the option 2 i tested and checked it in either win 7 and 8 but don't work correctly ! please help me if some thing is needed after that , thank you
  2. Posts : 71,977
    Hello Avacs, and welcome to Seven Forums.
    Please go ahead and post back with the name of the application that you are trying to block, and post some screenshots showing your settings from the tutorial to help see what the issue may be. :)
  3. Posts : 4
    problem
    i did all of the steps in the picture above that you posted. and after doing all of these the application are opening again and dont stopped ever. i attached some pictures here maybe you understand my says !
    Attached Thumbnails Attached Thumbnails Applications - Prevent Running Specified Programs-1.png   Applications - Prevent Running Specified Programs-2.png   Applications - Prevent Running Specified Programs-3.png
  4. Posts : 71,977
    Your settings look good to me. Did you restart the computer to apply?
  5. Posts : 4
    thank you admin after i restarted my pc this option worked as well ,
    i don't want the error be appear when i clicked on the icon, can be without any errors and opening without windows ? (Nothing happen after clicking)
  6. Posts : 71,977
    Good news. :)
    Unfortunately, since you have W7 Home Premium, you do not have Group Policy that you could use to set to only block that file for specific users and not for your account or administrators.
    If you like, you could also use Parental Controls to block a standard user from running that app instead. This way, you will still be able run the app.
    Parental Controls - Allow or Block Specific Programs
  7. Posts : 4
    is the problem solved in windows 8 or 8.1 ?
    i dont want the application error's appear on the windows display ?
  8. Posts : 71,977
    Avacs,
    The message is by design and serves as a notice for why users are not able to run the .exe. They will always show when a restricted app has been attempted to be opened.
