#20
Groove2love, i think your problem can be solved by: go to 'audio devices' / 'sound' -> 'recording' tab -> click with the right button on your default recording device and then click on 'properties' -> search for a 'listen' tab, or something similar lurking around, possibly in the properties (in the 'stereo mix' properties you can see this 'listen' tab, go there and check 'listen to this device'; this should fix your problem).
if that doesnt work: try going to 'sound manager' and search for any listen options... good luck!
