Presentation Settings - Turn On or Off
    How to Turn Presentation Settings On or Off in Windows 7 and Windows 8
    Presentation settings are options on a laptop or desktop that you can apply when giving a presentation. When presentation settings are turned on, your laptop stays awake and system notifications are turned off. You can also turn off the screen saver, adjust the speaker volume, and change your desktop background image when presentation settings are turned on.
    This tutorial will show you how to either turn on, change, or turn off presentation settings in Windows 7 and Windows 8.
    In Windows 7, "Presentation Settings" is only available in the Windows 7 Professional, Windows 7 Ultimate, and Windows 7 Enterprise editions.
    In Windows 8, "Presentation Settings" is only available in the Windows RT, Windows 8 Pro, and Windows 8 Enterprise editions.
    OPTION ONE
    Turn Presentation Settings On or Off using Windows Mobility Center
    1. Open Windows Mobility Center.
    2. To Turn On Presentation Settings
    A) In the Presentation Settings tile, click/tap on the Turn on button, and go to step 4 below. (See screenshot below)
    NOTE: This will turn on the presentation settings that you have set in step 4.
    3. To Turn Off Presentation Settings
    A) In the Presentation Settings tile, click/tap on the Turn off button, and go to step 5 below. (See screenshot below)
    4. To Change the Presentation Settings
    A) In the Presentation Settings tile, click/tap on icon in the upper left corner of the tile. (See screenshot below)
    B) Change the settings for what you want when giving a presentation, click on OK, and go to step 5 below. (See screenshot below)
    5. When finished, you can close Windows Mobility Center if you like.
    OPTION TWO
    Turn Presentation Settings On or Off in Presentation Settings
    1. Press the Windows + R keys to open the Run dialog, type presentationsettings.exe, and press Enter. (See screenshot below)
    NOTE: If you would like to create a Windows Mobility Center shortcut, then right click on presentationsettings.exe at the top of the Start Menu below and click on Send to and Desktop (create shortcut). You can also create one from the exe file located at
    C:\Windows\System32\PresentationSettings.exe.
    A) Check the I am currently giving a presentation box, and go to step 4 below. (See screenshot below step 5)
    A) Uncheck the I am currently giving a presentation box, and go to step 5 below. (See screenshot below step 5)
    A) Change the settings for what you want when giving a presentation, and go to step 5 below. (See screenshot below step 5)
    5. When finished, click/tap on OK. (See screenshot below)
    OPTION THREE
    Turn Presentation Settings On or Off using a Command
    1. Open the Run (Win+R) dialog, or a command prompt.
    A) Type the command below, and press Enter.
    PresentationSettings.exe /start
    PresentationSettings.exe /stop
  1. Posts : 15
    Windows 7 Professional x64
    I think there should be an additional shortcut listed in one of these tutorials that I found from this blog on Windows Presentation Mode
    You can create a shortcut to turn on or turn off windows presentation mode automatically with one shortcut using a variation on the presentation settings shortcut, without having to open up the settings dialog to either click the button or checkbox to turn it on/off. You just have to add an additional parameter
    Presentation Mode On:
    %windir%\System32\PresentationSettings.exe /start
    Presentation Mode Off:
    %windir%\System32\PresentationSettings.exe /stop
    I find this very useful.
  2. Posts : 71,975
    Thank you Matt. I added OPTION THREE to the tutorial for a command option to help. :)
