How to Reset the Windows 7 Reliability Monitor
Published by Brink
08-13-2009
Reliability Monitor - Reset
If you have fixed the errors or just want to clear the reported data in Reliabilty Monitor, then this will show you how to reset the Windows 7 Reliability Monitor back to a clean default state.
Reliability Monitor is an advanced tool that measures hardware and software problems and other changes to your computer. It collects 24 hours of data before it displays any results and calculates the stability index that ranges from 1 (the least stable) to 10 (the most stable). You can use the index to help evaluate the reliability of your computer by reviewing the reported application failures, Windows 7 failures, Miscellaneous failures, Warnings, and Information. Any change you make to your computer or problem that occurs on your computer affects the stability index.
Warning
If you reset the Reliability Monitor, then any previously displayed data will no longer be available unless you have backed it up in step 3 below to restore.
EXAMPLE: Reliability Monitor NOTE:You can tell your Index score (scales from 1 to 10, 10 is the best score) by looking at how the chart line ends in the upper right corner boxed in red below compared to the scale of 10 to 1 on the left upper corner boxed in red below.
Here's How: NOTE:You must be logged in as an administrator to be able to do this.
1. Click on the Download button below to download the file below, and save it to your desktop. NOTE:Special thanks to Zardoc for providing the part of the BAT file to clear the Event Viewer logs.
Reset_Reliability_Monitor.bat
2. Right click on the downloaded .bat file, and click on Run as administrator. NOTE:If for some reason the BAT file will not run for you, then unblock it first, and try again.
3. If prompted by UAC, then click on Yes.
4. When it's finished, restart the computer to fully apply.
Reliability Monitor will collect 24 hours of data before it displays any results and calculates the stability index that ranges from 1 (the least stable) to 10 (the most stable) again.
System Manufacturer/Model Number Compal JFT02 (Custom Build Laptop) OS Windows 7 Home Premium x64 - Mac OS X 10.6.4 x64 CPU Intel Core 2 Duo T9300 2.5 GHz Motherboard JFT02 Memory 4GB Kingston DDR2-800 Graphics Card NVIDIA Geforce 8600M GT (512MB Model) Sound Card Realtek HD Audio Monitor(s) Displays WUXGA Standard Laptop Display Screen Resolution 1680*1050
Keyboard Standard Laptop 105 Key-Keyboard Mouse Synaptics Touchpad PSU Standard Laptop Power Supply Case Standard Laptop Case Cooling Standard Laptop Cooling Hard Drives Toshiba 320GB 5400RPM Laptop HD Internet Speed Verizion Online DSL 3360/864 kbs (dl/up)
hi im new to this site and good Tutorial man but is it bad to reset it or no and i didn't back up the folders they weren't that important.. if i get new errors will they show up in my reliability monitor?
Reason: fixed format
After some time (a few hrs.) it will reset your index to 10 and it will start to show new errors(lowering your index of course)
Reason: fixed format in quote
System Manufacturer/Model Number Generic PC built by me OS Windows 7 Ultimate 32 bits CPU 3.2 Ghz Pentium 4 HT Motherboard Biostar P4M800 Pro-M7 Memory 2 GB Kingston Graphics Card 512 MB AGP 8x PowerColor Radeon HD 3650 Sound Card Realtek AC'97 Audio For Via Monitor(s) Displays 15" LG 505G and a 19" LG 19LG30 LCD TV/Monitor
Keyboard Actek Smart Evolution Office Keyboard with built-in USB port Mouse Arteck RX5 Laser Mouse PSU 550 Watts Pixxo PSU PK Series Case Blue Code Black Case Cooling Foxconn NBT-CMI77516B3-C CPU Cooler Hard Drives 7200 RPM Seagate Barracude 500 GB SATA Disk (Main disk)
7200 RPM Seagate Barracude 320 GB IDE Disk (Backup disk) Internet Speed 2mbps download and 512kbps upload
