Windows 7: Reliability Monitor - Reset
How to Reset Reliability Monitor in Windows 7 and Windows 8
Published by Brink
13 Aug 2009
information   Information
If you have fixed the errors or just want to clear the reported data in Reliabilty Monitor, then this will show you how to reset the Reliability Monitor back to a clean default state in Windows 7 and Windows 8.
You must be logged in as an administrator to be able to do this tutorial.
Note   Note
Reliability Monitor is an advanced tool that measures hardware and software problems and other changes to your computer. It collects 24 hours of data before it displays any results and calculates the stability index that ranges from 1 (the least stable) to 10 (the most stable). You can use the index to help evaluate the reliability of your computer by reviewing the reported application failures, Windows failures, Miscellaneous failures, Warnings, and Information. Any change you make to your computer or problem that occurs on your computer affects the stability index.
warning   Warning
If you reset the Reliability Monitor, then any previously displayed data will no longer be available unless you have backed it up in step 3 below to restore.
This does not work in Windows 8.1 Update.
EXAMPLE: Reliability Monitor
NOTE: You can tell your Index score (scales from 1 to 10, 10 is the best score) by looking at how the chart line ends in the upper right corner boxed in red below compared to the scale of 10 to 1 on the left upper corner boxed in red below.
Here's How:
1. Click/tap on the Download button below to download the file below, and save it to your desktop.
NOTE: Special thanks to Zardoc for providing the part in the BAT file to clear the Event Viewer logs.
Reset_Reliability_Monitor.bat
download
2. Unblock the .bat file.
3. Right click or press and hold on the downloaded .bat file and click/tap on Run as administrator.
4. If prompted, click/tap on Yes (UAC).
5. You will now see a command prompt open, run the commands to reset Reliability Monitor, then close.
6. If this is for Windows 8 and 8.1, then you must repeat steps 3-5 to run the .bat file a second time for this to work.
7. When finished, restart the computer to fully apply.
Note   Note
It may take Reliability Monitor a few to 24 hours to display results again after being reset.
14 Aug 2009   #1
Zidane24
This is still cheating Shawn
14 Aug 2009   #2
Brink
64-bit Windows 10 Pro
LOL, not if you fixed the issues.
14 Aug 2009   #3
Zidane24
Quote   Quote: Originally Posted by Brink View Post
lmao...I was under the impression that Windows 7 would "erase" fixed issues off your record
14 Aug 2009   #4
Brink
Nope, they will still show up in the Reliability Monitor's history report.
14 Aug 2009   #5
Zidane24
It is hard to get "crimes" off your record huh
14 Aug 2009   #6
Brink
LOL, yep.
13 Jun 2010   #7
amir57
Windows 7 ultimate 32 bit
hi im new to this site and good Tutorial man but is it bad to reset it or no and i didn't back up the folders they weren't that important.. if i get new errors will they show up in my reliability monitor?
13 Jun 2010   #8
ratePV
Windows 7 SP1 x64
Quote   Quote: Originally Posted by amir57 View Post
After some time (a few hrs.) it will reset your index to 10 and it will start to show new errors(lowering your index of course)
29 Aug 2010   #9
dbgarza
Windows 7 Ultimate 32 bits
Thanks a lot for this, it sure worked like a charm!
Now I got rid of the evidence of the crimes
Reliability Monitor
i have just realized that the Reliability Monitor has stopped updating on my machine i have looked at the settings but it looks ok what is the best way to reset it and get it up and running again?
Performance & Maintenance
Reliability Monitor
View Reliability and Problem History with Reliability Monitor in Windows 7 and Windows 8 This tutorial will show you how to open and use Reliability Monitor to review reliability and problem history to help resolve issues in Windows 7 and Windows 8. Reliability Monitor is an advanced tool...
Tutorials
Reliability monitor wont reset
I have followed the tutorial on this site to reset the reliability history - trash RAC files etc. The graph clears ok but a few hours later back comes all the old problem. I am thinking there must be another file hidden away that is being accessed for the data. I would not be bothered normally but...
How to reset Windows 7 Reliability Monitor?
I have deleted all the files in the C:\ProgramData\Microsoft\RAC\PublishedData folder and C:\ProgramData\Microsoft\RAC\StateData folder waited few hours but the same old chart reappers as if i have done nothing. wtf? Is there a way to reset the Reliability Monitor once and for all in windows 7...
Reliability Monitor
The Reliability Monitor of Windows 7 is a very handy tool for monitoring the history of when which applications have failed. Being a developer, it is to be expected that applications that are "In-Development" will cause problems, which in turn negativly affects the scores of the Windows...
I've just tried resetting reliability monitor but?
Its not working for me,ive followed the tutorial here to a T twice and both times it does seem to work then a while later all the old history is back,and yep thats after deleting inside them folders etc? Am i missing something here?
