System Repair Disc - Create
How to Create a Windows 7 System Repair Disc
This will show you how to create a Windows 7 system repair disc to be able to use to boot to system recovery options to help recover your Windows 7 installation if you don't have a Windows installation disc, can't find your Windows installation disc, or can't access the recovery options provided by your computer manufacturer.
A system repair disc is not able to install Windows 7.
If you are unable to boot your Windows 7 to create a Windows 7 System Repair Disc, then you could create it on another computer to use on your computer.
   Warning
  • A system repair disc is not the same as a OEM factory recovery/restore disc.
  • A system repair disc is not an installation disc. You cannot do a repair install or install Windows 7 with a system repair disc.
  • A system repair disc can only be used to repair Windows 7 through the system recovery options.
  • 32-bit System Repair Disc can only be created on a 32-bit Windows 7.
  • 64-bit System Repair Disc can only be created on a 64-bit Windows 7.
  • 32-bit System Repair Disc can only be used to repair a 32-bit Windows 7.
  • 64-bit System Repair Disc can only be used to repair a 64-bit Windows 7.
:note: For Windows 10, see the following link - System Repair Disc - Create in Windows 10 - Windows 10 Tutorials
EXAMPLE: System Recovery Options
NOTE: Using the System Repair Disc that you have created below, you can boot to the system recovery options screen below.
Here's How:
1. Open the Start Menu, then type recdisc.exe in the search box and press Enter.
A) Go to step 3.
OR
2. Open the Control Panel (icons view), and click on the Backup and Restore icon.
A) Click on the Create a System repair disc link in the left blue pane. (See screenshot below)
3. Insert a blank unformatted CD or DVD into your CD/DVD drive and click on the Create disc button. (See screenshot below)
NOTE: If you are prompted to insert a Windows installation disc, it means that the files needed to create the system repair disc cannot be found on your computer. Insert a Windows 7 installation disc.
4. It will now start creating the System Repair Disc. (See screenshot below)
NOTE: If a AutoPlay window pops up, just close it.
5. When it's finished, click on the Close button. (See screenshot below)
6. Click on OK. (See screenshot below)
7. Remove and label your new Windows 7 System Repair Disc from the CD/DVD drive.
   Tip
If you would like to create a bootable System Repair USB flash drive, then you could use the free program ImgBurn to create an ISO file with this Windows 7 System Repair Disc (DVD), then use the Part 1 section in the tutorial below to extract the ISO file to a USB flash drive.
Windows 7 USB/DVD Download Tool
can i use this repair disk solving the problem such as restart loop after starting windows?
Windows 7 Ultimate x32
How much space will occupy for system repair disk on CD or dvd? I am using windows 7 ultimate.
Hello Ganesh,
It only needs about 150 MB of space since it's not an installation DVD, so any DVD can be used. :)
So 150 mb means CD is enough, I will burn on CD instead of dvd. Thanks for information about the space. :), but how to burn on USB?
There's not an option to do so on a USB.
If you have retail installation media, you could use it instead since it includes this already.
sorry, I dont understand this line: Remove and label your new Windows 7 System Repair Disc from the CD/DVD drive means what?
It means to write what you want on the label (sticker) on the top of the CD/DVD to help you know what it is for. :)
Thank you once again, hopefully this fixes my gaming rigs problem with the bootmgr missing. :huh:
Windows 7 Ultimate x64Intel Core i5-3570K Quad-Core Processor 3.4GHz8GB Corsair Vengance 1600MHzEVGA GeForce GTX 970 Super Clocked ACX 2.0 4G...
ASUS P8Z77-V
EVGA GeForce GTX 970 Super Clocked ACX 2.0 4GB GDDR5
HANNS-G HL229
WD Blue 1TB, WD Blue 500GB, 120GB - Samsung 840 Series SSD (not hooked up.)
OCZ 600W
Antec Twelve Hundred V3 Black Steel ATX Full Tower
Logitech G105 - Call of Duty MW3 Edition
Etekcity® Scroll FLY 3200 DPI Wired
28Mbps
Malwarebytes
Hi, is the system repair disk the same for any Win7 Home Premium x64bit machine? I already have one created from another laptop. Do I need to make another one from my own laptop?
Toshiba
Hello lc007, :)
It'll also need to be for the same edition of Windows you have.
Hello again Brink! Both machines are running Win7 Home Premium x64 bit. That's the same edition, right?
Toshiba
Yep, that's right. You're good to go then. :)
Toshiba
:thumbsup:
:cry:
My Windows 7 Pro 64bit system is no longer booting. When I start the PC I get the POST screen, then when the Windows logo is supposed to appear I just get a black text screen with the "_" cursor slowly moving down the screen about 1 line every second.
I'm guessing my boot record is messed up and I want to try and repair it, BUT when I boot from my installation DVD and choose to repair it doesn't show any Windows installations. If I select to look for a driver I can see the system drive with all my files on it, so I know the Windows drive is working.
I just went to my second Win 7 Pro 64 system and tried to create a repair CD as laid out in this post, but the CD does not boot. Any ideas why the "Create a system repair disk" would work without any errors, but the resulting CD would not be bootable?
Windows 7 Pro 64bitAMD FX 6350 Six core CPU @ 3.9Ghz24GBnVidia GeForce GTX 660
Custom build
Windows 7 Pro 64bit
Asus m5a88-m
24GB
Onboard
Vizio 32" TV + 24" Asus
1980x1200 (x2)
240Gb OCZ Agility 3 (C:)
1TB Western Digital (D:)
120Gb OCZ Agility 3 (E:)
Corsair
Centurion
Microsoft Wireless 3000 v2
Hello Calab, :)
Did you see the black "Press a key to boot from CD/DVD" screen at boot to boot from the CD/DVD?
Nope... Just a message about the media not being bootable and to press any key.
I was able to get my system working though. I had to go into the BIOS and mess with the UEFI settings to get my installation DVD to detect the Windows installation.
All is well again on my PC. :geek:
Custom build
Windows 7 Pro 64bit
Asus m5a88-m
24GB
Onboard
1980x1200 (x2)
Corsair
Centurion
And if you have an install dvd you don`t really need to create a system repair disc, but nice to have an extra :)
Skylake Special #666
Intel Core i7 6700K
Asus Sabertooth Z170 Mark 1
EVGA GTX 980 Ti SC x2
Realtek High Definition
AOC G2460PG
Logitech G910 Orion Spectrum
I always prefer to have an installation DVD or USB instead as well. :)
