Windows 7: System Repair Disc - Create
01 Dec 2012   #140
LucasI34
Windows 7 x64
When downloading the .iso file, does it matter which version (Home, Ultimate, Professional) I download to use? Does it have to be the same as the computer that I am repairing?
01 Dec 2012   #141
Brink
64-bit Windows 10 Pro
It must be the same 32-bit or 64-bit version. It doesn't have to be the same edition, but it would be best if it was.
01 Dec 2012   #142
LucasI34
Windows 7 x64
Okay, thank you. I was checking through the downloads on the dell link you provided a few posts ago, but there was no option for Enterprise, so what would be the best fit from the other three?
01 Dec 2012   #143
Brink
For Enterprise, you could download the ISO files for the 90-day evaluation below at Microsoft for this.
Windows 7 Enterprise| Trial, Evaluation, Test, Deploy
10 Dec 2012   #144
vagrant
Thanks for the tutorial.
I do some IT support. I know you can dual boot 7 for 32 and 64 bit editions, but could I create a setup on a USB stick to dual boot for Win 7 SP1 Repair 32 and 64 bit versions? What I'm thinking in fact is to have a usb stick with 5 partitions, 2 for the aforementioned, 2 for SP2 when it comes out and a fifth partition for data/storage. I guess it would also be beneficial to put the respective ISO files in each partition. Any ideas on how to go about this would be much appreciated.
23 Jan 2013   #145
Juxxize
Microsoft Windows 7 Home Premium 64-bit SP1
thank-you a great tutorial. I have made a repair disk but it's on a re-writable disk is that OK or should it be on a normal DVD disk or CD ?
23 Jan 2013   #146
Golden
Microsoft MVP
Windows 7 Ult. x64
Quote   Quote: Originally Posted by Juxxize View Post
A normal or re-writable DVD will be fine.
15 Feb 2013   #147
ExcelsiorPC
Can I create the Syst Repair on one and use on another
Can I create this System Repair disk on my Win 7 computer and use it to repair another Win 7 computer. Both are laptops. The one that is having the problem is an HP.
15 Feb 2013   #148
Brink
Hello ExcelsiorPC, and welcome to Seven Forums.
If both PC are the same 32-bit or 64-bit type, then yes you can use it on both.
Do note that a "System Repair Disc" is not the same as an "OEM Factory Recovery/Restore disc", and cannot reinstall Windows. It can only be used to boot to and use "System Recovery Options" screen.
27 Feb 2013   #149
FredyC
Windows 7 Enterprise 64bit
Hey. I am wondering, is there any way how to make repair disc on USB ? It's been like 5 years I had used any dvd drive and I don't have access to any currently.
I had found this program ... TotalMounter - a Free Virtual CD/DVD Burner That's Easy to Use. Anybody has experience with it ? Guess I can burn repair disc to image, but I am not sure how to place it on USB afterwards so it's bootable. Thanks for help.
Create System Repair Disc
Trying to create a system repair disc I get error #0x80004005. It appears to have something to do with Outlook--I do use 2010 Office Outlook. Any help is greatly appreciated!
Performance & Maintenance
Cannot create system repair disc
I am unable to create a system repair / recovery disc by either running recDisc.exe or using the option to create a recovery disk in Backup and Retore. It says System Repair Disc could not be created. "The parameter is incorrect (0x80070057)" I have tried using both a blank CDr and a DVDr. I am...
Cannot create system repair disc.
Known good cd drive & dvd drive installed in my pc. Known good Taiyo Yuden cd & dvd discs. Tried discs separately in each drive three ways. Have tried Search box typing recdisc.exe. Have tried going through Control Panel to reach the part to create repair disc. Have tried using an...
Backup and Restore
Create a System Repair Disc
Using Windows 7 Backup and Restore, I am attempting to create a disc to save: "Create a System Repair Disc" However, when I put in a blank DVD-R disc, that's not been used, the message comes up: "The disc in the selected drive is not blank" I've tested the DVD disc and it comes out fine.
How often should I create a system repair disc?
Hello, I have created a system repair disc for both of my PCs. I also create system backups on a regular basis. Should I also create system repair disc on a regular basis? I have recently changed the drive letter of several of my external hard drives, whould this require a new repair...
Backup and Restore
Hi all Windows updates have been doing some unpredictable things to my system so I have done a system restore and and now creating a mirror image using the tutorial on this forum. I read that it should only take about 15 mins and need over 1GB of space to do this (I am backing up on a DVD as I...
Backup and Restore
