Windows 7: System Repair Disc - Create
27 Feb 2013   #160
theog
ME/XP/Vista/Win7
You can not use a USB Pendrive to do a startup Repair, as startup repair will find the MBR on the Pendrive & not the HD.
Therefore will not detect a problem.
Windows Vista or Windows 7 no longer starts, and the Startup Repair tool does not fix the problem
27 Feb 2013   #161
VistaKing
Windows 7 Ultimate 32-Bit & Windows 7 Ultimate 64-Bit
Thank you theog
FredyC, DON'T do post # 159
28 Feb 2013   #162
FredyC
Windows 7 Enterprise 64bit
Oh snap, it looked like nice and sophisticated solution So I guess my solution with virtual burner still applies, I just have to try it.
17 Jun 2013   #163
erjoell
Window 7 64 bit
where is repair disk
I can not find anywhere on this page to download the repair disk.
17 Jun 2013   #164
Brink
64-bit Windows 10 Pro
Hello Joell, and welcome to Seven Forums.
The tutorial is for how to "create" a system repair disc instead. It would be a violation of Microsoft's copyrights and distribution policy to have one available for download.
07 Aug 2013   #165
DavidTango
Window 7 Ultimate 32bit
A very nice tutorial Brink and thanks for sharing.
It is a nice help. When you got trouble.
07 Aug 2013   #166
Brink
Welcome to Seven Forums David. I'm glad it was able to help.
12 Sep 2013   #167
Roadrunnermd
Windows 7 Home Premium 32-bit
I have Windows 7 Home Premium 32-bit. I assume that if I needed to create a repair disc using someone else's computer, that it has to be this version of Win 7 in addition to being 32-bit. Is that correct, or can it be any Win 7 OS that has 32-bit?
12 Sep 2013   #168
Brink
Hello Roadrunner, and welcome to Seven Forums.
That's correct.
However, if you have a retail 32-bit Windows Home Premium installation USB/DVD, then you could use that instead since it also includes this.
Windows 7 USB/DVD Download Tool
(see the blue note box at link for details about an ISO file)
12 Sep 2013   #169
Roadrunnermd
Unfortunately I don't have the install disc because I downloaded from Microsoft, then copied the files to my flash drive after installation. That's why I'm scrambling to find someone with the same OS, so I can get the repair disc. I have an NTLDR error message that I'm trying to resolve.
Create System Repair Disc
Trying to create a system repair disc I get error #0x80004005. It appears to have something to do with Outlook--I do use 2010 Office Outlook. Any help is greatly appreciated!
Performance & Maintenance
Cannot create system repair disc
I am unable to create a system repair / recovery disc by either running recDisc.exe or using the option to create a recovery disk in Backup and Retore. It says System Repair Disc could not be created. "The parameter is incorrect (0x80070057)" I have tried using both a blank CDr and a DVDr. I am...
Cannot create system repair disc.
Known good cd drive & dvd drive installed in my pc. Known good Taiyo Yuden cd & dvd discs. Tried discs separately in each drive three ways. Have tried Search box typing recdisc.exe. Have tried going through Control Panel to reach the part to create repair disc. Have tried using an...
Backup and Restore
Create a System Repair Disc
Using Windows 7 Backup and Restore, I am attempting to create a disc to save: "Create a System Repair Disc" However, when I put in a blank DVD-R disc, that's not been used, the message comes up: "The disc in the selected drive is not blank" I've tested the DVD disc and it comes out fine.
How often should I create a system repair disc?
Hello, I have created a system repair disc for both of my PCs. I also create system backups on a regular basis. Should I also create system repair disc on a regular basis? I have recently changed the drive letter of several of my external hard drives, whould this require a new repair...
Backup and Restore
Hi all Windows updates have been doing some unpredictable things to my system so I have done a system restore and and now creating a mirror image using the tutorial on this forum. I read that it should only take about 15 mins and need over 1GB of space to do this (I am backing up on a DVD as I...
Backup and Restore
