System Repair Disc - Create
Page 6 of 20 FirstFirst ... 4567816 ... LastLast
  1. Posts : 41
    Thanks, much appreciated.
  2. Posts : 16,161
    7 X64
       #51
    Hi Selvan,
    Here. LOL.
    CreateImage.zip
    You will find that all the tutorials on all the forums are virtually identical - on every subject.
    You can bet that there will be tutorials about making a "system image shortcut" springing up all over the place now.
      My Computers
  3. Posts : 41
    Right on, SIW2, it works like a champ!
  4. Posts : 72,052
       #53
    SIW2 said:
    Hi Selvan,
    Here. LOL.
    CreateImage.zip
    That is a great find Simon. This tutorial is credited to you.
    Create a System Image Shortcut - Create
    Thank you very much for sharing this. :)
  5. Posts : 237
    I am wondering instead of downloading imgburn. I saved the file to a folder in my files. Then I put in a DVD in my DVD burner. I then went to the file right clicked selected open with. Then I selected windows disk image burner. and I burned it to my DVD. Does that work like that. Or do I have to download imgburn? The file size is 169,650. I am pretty sure it is the same thing they almost have the same name. I just would like to make sure.
  6. Posts : 13,354
    Windows 7 Professional x64
       #55
    Hello,
    The Windows Disc Image Burner is a built-in program that does essentially the same thing as ImgBurn. ImgBurn supports a few more formats, and a few other things, but for burning ISOs to a CD, the method you used works great.
  7. Posts : 237
    Jonathan_King said:
    Hello,
    Awesome thank you.
    Now is there anything else I can download to a DVD to make sure if anything goes wrong with my PC I am all set to put it back to the way it was before. I have done the system back up also.
  8. Posts : 13,354
       #57
    Chiumiento said:
    Awesome thank you.
    Without going into 3rd-party tools, the system repair disc is the best you'll get. You could always add a 3rd-party data recovery program, anti-virus program, etc, but chances are you'll have all you'll need, if you have a repair disc and backups.
  9. Posts : 112
    Windows 7 Professional 64-bit
       #58
    Can I do this with Daemon tools? and mount the ISO instead of burning it?
    Thanks,
    The Unofficial
  10. Posts : 13,354
       #59
    Thanks,
    The Unofficial
    No, you'll have to burn it to a CD, and then boot from it. It won't run under Windows.
