System Repair Disc - Create
How to Create a Windows 7 System Repair Disc
This will show you how to create a Windows 7 system repair disc to be able to use to boot to system recovery options to help recover your Windows 7 installation if you don't have a Windows installation disc, can't find your Windows installation disc, or can't access the recovery options provided by your computer manufacturer.
A system repair disc is not able to install Windows 7.
If you are unable to boot your Windows 7 to create a Windows 7 System Repair Disc, then you could create it on another computer to use on your computer.
   Warning
  • A system repair disc is not the same as a OEM factory recovery/restore disc.
  • A system repair disc is not an installation disc. You cannot do a repair install or install Windows 7 with a system repair disc.
  • A system repair disc can only be used to repair Windows 7 through the system recovery options.
  • 32-bit System Repair Disc can only be created on a 32-bit Windows 7.
  • 64-bit System Repair Disc can only be created on a 64-bit Windows 7.
  • 32-bit System Repair Disc can only be used to repair a 32-bit Windows 7.
  • 64-bit System Repair Disc can only be used to repair a 64-bit Windows 7.
:note: For Windows 10, see the following link - System Repair Disc - Create in Windows 10 - Windows 10 Tutorials
EXAMPLE: System Recovery Options
NOTE: Using the System Repair Disc that you have created below, you can boot to the system recovery options screen below.
Here's How:
1. Open the Start Menu, then type recdisc.exe in the search box and press Enter.
A) Go to step 3.
OR
2. Open the Control Panel (icons view), and click on the Backup and Restore icon.
A) Click on the Create a System repair disc link in the left blue pane. (See screenshot below)
3. Insert a blank unformatted CD or DVD into your CD/DVD drive and click on the Create disc button. (See screenshot below)
NOTE: If you are prompted to insert a Windows installation disc, it means that the files needed to create the system repair disc cannot be found on your computer. Insert a Windows 7 installation disc.
4. It will now start creating the System Repair Disc. (See screenshot below)
NOTE: If a AutoPlay window pops up, just close it.
5. When it's finished, click on the Close button. (See screenshot below)
6. Click on OK. (See screenshot below)
7. Remove and label your new Windows 7 System Repair Disc from the CD/DVD drive.
   Tip
If you would like to create a bootable System Repair USB flash drive, then you could use the free program ImgBurn to create an ISO file with this Windows 7 System Repair Disc (DVD), then use the Part 1 section in the tutorial below to extract the ISO file to a USB flash drive.
Windows 7 USB/DVD Download Tool
Created my System Repair Disk ... thank you for the Tutorial :)
Ciara ... X
Windows 7 Professional 64-bit SP1Intel E84004GB Crucial BallistixATI ASUS Radeon HD 4830
Home Built
Intel E8400
MSI P35 Neo
Realtek ALC888 on Board
Asus 22-inch VH226H Widescreen
Two Western Digital 500GB
Hiper HPU-4M 530W
Thermaltake Tsunami Dream Black
Air/Fans
Saitek Eclipse
Razer
Sky Broadband
USB Hub/Card Reader - 2 Pen Drives, 1 Phone Dock
You're most welcome Ciara. Thank you. :)
Brink
Single post please read.
http://www.sevenforums.com/installa...t-down-during-windows-update.html#post1282865
Posting here because I didn't want to hijack the above thread
So is my non SP1 repair disk useless?
Not a problem if needed to burn a new one but it seems not to be widely known issue if true.
1) Do I need to make a new one since installing SP1?
2) May need to be added to tutorial if true.
Mike
Hopalong/ Godzilla
ASUS P7P55D-E PRO
VIA Onboard
1920x1080; 1440x900
Samsung 830 120GB SSD
Intel 320 120GB SSD
Logitech K-320
Kensington
Avast Inernet Suite
IE 9 ; Chrome
Hello Mike,
You could still use a non SP1 Windows 7 disc to use the command prompt at boot on a Windows 7 SP1 installation. However, if you wanted to use the other options at "System Recovery", you would need to have a Windows 7 SP1 disc for a Windows 7 SP1 installation.
Thanks Brink.
I'll burn a new one and mark it SP1 version. ;)
I figured BFK would not be wrong!!
Mike
Hopalong/ Godzilla
ASUS P7P55D-E PRO
VIA Onboard
1920x1080; 1440x900
Intel 320 120GB SSD
Logitech K-320
Kensington
Avast Inernet Suite
IE 9 ; Chrome
Outside of the fact that a repair disc would save wear and tear on the original W7 DVD, does a repair disc offer any additional advantage(s)?
W7x64 Pro, SuSe 12.1/** W7 x64 Pro, XP MCEPhenom II 1090T w/Noctua NH-D14 /**4400+ X2 w...2 x 2GB Patriot PGS34g1600LLKA/**4x1GB Corsai...EVGA GTX460 SC/**EVGA 8800GTS
DIY
Asus Xonar D2X/**Xonar D1
HAF922/**Antec 1040IIB
3.3Mbps
(** = 2nd rig)
Hello Seekermeister,
Other than that, creating a system repair disc after installing SP1 would be better since you would no longer be able to use a non SP1 Windows 7 installation DVD for any of the "System Recovery Options" other than "Command Prompt" and maybe "Windows Memory Diagnostic Tool".
A large no. of PC users have OEM machines and never got a win7 dvd for their hefty purchase! A repair disk is invaluable for them.
Too many to describe...
what if i create a repair disk in my laptop(32bit) will it work with my computer(32bit)?
Windows 7 x32
Windows 7 x32
1024x768
    7 X64i5 84002x8gb 3200mhz
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    pure power 11 400w cm
    Coolermaster
    cryorig m9i
    7x64g54008gb ddr4 2400
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
Right but I can not access the start menu or the control panel. Windows will not start up. All I can get to is the boot menu and and the screen with the start up options like start in safe mode and the like. That's all I can get it to do.
Jeremy
winodws 7
Toshiba Satellite L455-S5009
winodws 7
Hello Jeremy,
If you have your BIOS settings set to boot from a DVD (most are), then you will be able to boot directly from the created "System Repair Disc" in this tutorial to then be able to select from the System Recovery Options. Since you can't boot, I would recommend running Startup Repair.
It would be nice with a howto explaining how to copy this repair disk onto a usb drive and make it bootable.
Windows 7 Professional x64Intel i7 2600K OC'd @ 4620 MHz16GB GSkill Sniper 2133 Mhz (4x4GB)EVGA GeForce GTX 480 SuperClocked+
Asus P8Z68-V Pro
2x Acer S273HLbmii 27"
2 x 1920x1080
64GB Crucial M4 SSD
Storage: Hitachi 1TB 5400RPM, Samsung 1.5TB 5400RPM
Corsair HW Series 750w (modular)
Cooler Master HAF 932 Advanced Blue Edition
CM Hyper 212+ CPU cooler, 3x 230mm + 1x 140mm case fans
Logitech MK320 (wireless)
30 Mb/s : 2 Mb/s
thanks :3 Picked up a 5pk of CD-r's and made one today :3
Windows 7 Ultimate x64AMD FX 41008GB DDR3-1333ATI HD Radeon 5750
AMD FX 4100
Gigabyte 990FXA-UD3 USB 3.0
8GB DDR3-1333
ATI HD Radeon 5750
AOC LM-500 & Curtis HDTV 19'
1024x768 & 1360x768
Main: SATAII 500GB WD Blue
Secondary: 200GB Maxtor SataII
700Watt OCZ 80+
Xion II
standard Stock CPU heatsink and fan
standard PS/2 keyboard
Gearhead Lighted Optical Mouse
WideOpenWest (Cable) 15Mbps/1Mbps
Comodo
Firefox/Chrome
Updated Specs as of 4/4/2013
(refelect new build as of mid 2012)
Just made a disk, first time.
Thanks a lot. :-)
Windows 7 ultimate 32biti3-5404gigo/b
Self Build
i3-540
MSI H55M-ED55
4gig
o/b
o/b
HG216D
Samsung 500 gig sata
Hiper Type-R 480W
Cooler Master
Rear 120cm -- CPU Frezer Pro rev2
You're welcome Cael, and Spud. Welcome to Seven Forums Spud. :)
the download links are removed !!! what can we do now?
Windows XP 32bit, Windows 7 Home Premium 32bi...Intel Core2Duo E7500 @ 2.93 Ghz4gb DDR2ATI Radeon 4670 1gb
Windows XP 32bit, Windows 7 Home Premium 32bit & 64bit
4gb DDR2
ATI Radeon 4670 1gb
1360x768
Hitachi 500gb
Hello Sayem,
You could create the System Repair Disc on another Windows 7 computer, and be able to use it on yours. :)
Brink, can you confirm the following is true:
1. Win7 setup or repair disc can repair win7 installation only.
2. Win7 sp1 setup or repair disc can repair win7 sp1 installation only.
3. Win7 32bit can repair win7 32bit only.
4. Win7 64bit can repair win7 64bit only.
Windows 7 Professional 64bit
