Bootrec.exe Tool - How to Use in Windows Recovery Environment
    Bootrec.exe Tool - How to Use in the Windows Recovery Environment
    How to Use Bootrec.exe Tool in Windows Recovery Environment
    You can use the Bootrec.exe tool in the Windows Recovery Environment to repair the following item in Windows 7 should you be experiencing startup issues that cannot be resolved by the Startup Repair option:
    • The Boot Configuration Data (BCD) store
    To run this tool you must do so from within the Windows 7 Recovery Environment.
    1. Make sure your computer is configured to start from the DVD drive
    2. Insert your Windows installation DVD or Windows repair DVD
    3. Press any key when prompted
    4. Choose your language, time, currency, keyboard language and click Next
    5. Click Repair your computer
    6. Select the operating system you want to repair and click Next
    7. Click Command Prompt in the Systems Recovery Options dialog box
    8. Type the following commands in the Windows RE command prompt window and press Enter to execute each command (paying particular attention to insert a space where shown below):
    9. bcdedit /export C:\BCD_Backup
    10. c:
    11. cd boot
    12. attrib bcd -s -h -r
    13. ren c:\boot\bcd bcd.old
    14. bootrec /RebuildBcd
    When you have finished, type Exit at the command prompt then press Enter to close the command prompt window. Restart your computer.
  1. Posts : 1
    Windows 7 Ultimate
    Please Help...
    I've tried this among many other things, and nothing has worked. I continue to get "BootMgr is missing" error message. Can you help please?
  2. Posts : 16,161
    7 X64
    What kind of machine have you got?
    Do you have one of those 100mb partitions?
      My Computers
  3. Posts : 16,161
    7 X64
    Are you still awake?
      My Computers
  4. Posts : 7,730
    Windows 7 Ultimate SP1 64-Bit
    Welcome to Windows Seven Forums.
    Can you post a screen shot of your disk management layout?
    Mine looks like this:
    Bootrec.exe Tool - How to Use in Windows Recovery Environment-disk-management.png
    You'll notice there is a small 100Mb partition at the beginning of Drive 0. It is this partition that should be active as it is the one that holds the master boot record.
    You could try this method. If it doesn't work at first, try again.
    Bootmgr is missing - Fix
  5. Posts : 16,161
    7 X64
    Hi Seavixen,
    I don't know how he can do that - he can't get into windows.
    I was going to outline using 7 boot media - but caed seems to have lost interest.
    It's late here.
    Goodnight.
      My Computers
  6. Posts : 7,730
    SIW2 said:
    Hi Seavixen,
    It's late here.
    Goodnight.
    It's early here and I was having trouble sleeping and thinking straight too.
    You're quite right of course, but perhaps he'll post back later.
  7. Posts : 5
    Win7 x64
    So I have tried this due to OS drive letters changing from C: to D: (for some reason) and now I can't even load system repair tools because it doesn't locate the OS in System Recovery Options window... I guess now I'll HAVE to reinstall windows, but how can I be sure the files that are (were?) on D: don't get deleted ?
  8. Posts : 3
    Windows7 Pro 64 bit
    It did with me also.
    I booted using Hiren Boot CD in mini Windows XP.
    Disk Management.
    Removed drive letter for system partition.
    Assigned C letter to OS partition.
    Now windows booted OK !
    Try this.
    You can backup the files also.
  9. Posts : 5
    Win7 x64
    I basically used a Ubuntu Live dvd and pulled the files I needed to an external storage device, formatted the drive completely, can't install windows now... I chalk it up to beat up HDD
