#30
i have entered exactly the same recovery key which matches the identifier code
after running that recovery command my drive is status is this whats this means now
From your screenshot, it looks like it may be a permissions issue instead.
As a test, use the tutorial below to add a "Take Ownership" context menu, then take ownership of the E: drive to see if that may allow you to be able to access it afterwards.
Take Ownership - Add to Context Menu in Windows 10 - Windows 10 Forums
