Windows 7: Dual Boot - Delete a OS
18 Jan 2013   #30
whs
Microsoft MVP
John, if you want to move the bootmgr to C, use this: Bootmgr - Move to C:\ with EasyBCD
19 Jan 2013   #31
JohnF1938
win 7 Home Premium 32bit
Thanks for reply. When I try this C: is not available. I have however moved it to the H: drive so the system & Bootmgr are on the same drive.
After doing this I tried to rename the H: drive C: but Computer Management would not alow this.
Regards John
19 Jan 2013   #32
whs
Microsoft MVP
Don't muck around with the lettering. Let the system manage that.
Btw: the bootmgr is only being copied, not really moved. I should have chosen another title when I made the tutorial. So wherever it was before, it still is also. But it will not have any effect because EasyBCD has deactivated that partition.
19 Jan 2013   #33
JohnF1938
Thanks, I have managed to stop windows including the F: drive in a system image by using EasyBCD to copy BootMng to the h: drive then Format the f:drive. I will leave the system Drive as h:
So I am home and dry.
Regards John
25 Jan 2013   #34
Kimwu
Win7 Ultimate x64
Hi!
Thanks for the great tut !! However, after a long research (and about 4/5 boot files repair with WinRE), I believe it misses a very important part, which will cause the system NOT to boot : it cant find any boot file.
You miss a final step 6 !
Under "BCD BACKUP", you have to launch "Re-create boot files" !
I have tested this many times to make sure. Without doing it, the bios wont find the "boot files"
But when doing Step 4 - Reset the BCD / Step 5 - Adding a new entry / Step 6 - Reset the Mbr it works
To my "understanding", there are two parts : the boot files // the boot data config
- When hitting Reset BCD, I guess it will erase everything, files included.
- When adding new entry, you setup the boot data again, but not the files
- When hitting Recreate boot file, you copy the file again.
Files + data = Boot
25 Jan 2013   #35
Kimwu
Win7 Ultimate x64
Note: Of course, I might be totaly wrong in my understanding, but in my situation (VaioZ Win7 ultimate x64 with only 1 system installed) it didnt work another way.
I am using the 350Mb system reserved partition, and boot files were there for a long time.. that's why I believe the boot files were deleted when hitting reset BCD. At least that's what the bios says.
I should go on esayBCD forum to check what's going on exactly when hitting the reset button / recreate button
25 Jan 2013   #36
whs
Microsoft MVP
That is strange. I have done it several times as described and never had a problem. I wonder why that was different in your case.
27 Jan 2013   #37
Kimwu
Win7 Ultimate x64
Alright ..
I have spent some time on the esayBCD online user guide. It's a nice guide, pretty well done.
This page explain what you did in the first page of this guide :
Resetting the BCD - EasyBCD - NeoSmart Technologies Wiki
Then, this one explain some more "possibilities".
Recovering the Windows Bootloader with EasyBCD - EasyBCD - NeoSmart Technologies Wiki
Option 3 is the last one they give, so I guess I was in this situation.
What really *is* odd, is that the missing files were due to the "Reset BCD" first step, for sure. Tested 4 times in a row. So, it is strange indeed they do not advise to "Recreate" the boot files after a "Reset BCD", even if they know its deleting some files.
Anyway, hope my posts might help someone else with the same situation I was, it'es never fun to see a "no operating system" screen just after a fresh install ^^
07 May 2013   #38
Somebody777
Windows 7 Home 64bit
Hey guys
I ended up this tutorial with Windows Boot Manager error:
File: \Boot\BCD
Status: 0xc0000098
Info: The windows Boot Configuration Data file does not contain a valid OS entry.
I have not recovery disk and F8 doesn't work
I found this tutorial which explains how to fix problem, but it required full EBCD version software which I can't afford.
Any advice how to fix this problem?
Thanks in advance
21 Jun 2013   #39
faluppa
w7 64b
thx
I want to thank you for a very well and good explaind step-by-step guide. After I bought a new SSD for my gf's laptop , I installed the os by hooking it up to my desktop. Ever since I had the ' problem ' . Looked everywhere , device manager bios..etc. Should've looked here first . So thank you !
How to delete Windows 7 from Dual boot
Hello all, I have windows XP and Windows 7 (Dual Boot). I want to delete windows 7 from it as my computer becomes really laggy. I have Pentium D as processor with 2 GB DDR2 RAM. So can you please tell me as to how delete the partition? Will install Fedora in its place. Hoping to hear from...
General Discussion
help here how to delete dual boot
i already install dual boot which is Windows 7 and winxp but in different hhd i formatted windows xp that partition and still show on boot menu how to delete that? its show in startup and recovery but not show at msconfig there
Installation & Setup
delete XP from dual boot ...
Hi, I first installed WinXP on the first partition of hard disk - drive C:. After that I installed Win7 on a new created 4. partition of the HD. When I start Win7 using boot menue, drive C: ist now for Win7 and D: is for WinXP with following status displayed by disk managment: C: startpartition,...
How to delete XP from dual boot with Win 7
Xp was installed first, then Windows 7 added as dual boot. Now no need to keep XP. However boot files are on XP partition so you cannot just delete/format the XP partition. So get EasyBCD 2.0 latest, you need to register but it's free. Check Windows Disk Management for the "system" flag....
Delete XP dual boot
I see no reason to keep my XP dual boot. The XP installation is on a discrete physical drive. Win7 is on an active drive set as the first boot drive in BIOS and is the default OS at system startup. Can I just remove the drive and do a 7 startup repair to fix the boot, or are there more necessary...
Want to delete an OS from a dual boot configuration
Hello, I originally stated out with XP Pro and then installed Win 7 in a separate partition with dual booting. Now I want to get rid of the XP OS and recover the partition the XP OS is in for other uses. Running bcdedit shows the the Win 7 as drive C and XP as drive D. The master boot...
