Windows 7: Dual Boot - Delete a OS
How to Properly Delete a OS in a Dual Boot
Published by whs
27 Jan 2012
whs's Avatar
information   Information
Deleting a double booted OS may seem simple - you just delete the partition with the OS you want to get rid of and you are done. Well, it is not that easy. With said approach you may get yourself into a lot of trouble. This tutorial describes a safe way how to properly delete a double booted OS.
Step 1 - Check where the bootmgr resides
Open Disk Management and find the partition that is marked "active". That is the partition that contains the bootmgr. If there are several active partitions, you have to look for the system flag - best seen in Computer.
The active partition is usually from the OS that was on the system first - e.g. if you installed Windows 7 on an XP system, the XP system would be the active partition. But there are also other cases.
If Windows 7 was the first OS on the system, then your bootmgr resides most likely in a separate system partition which is usually small.
If you installed Windows 7 as first OS to a disk that was not attached to the Sata port0, it can very well be that the bootmgr resides on an arbitrary partition on the disk that is attached to port0.
If you have e.g. a Dell system, your bootmgr may be on the recovery partition. Other OEMs may do the same, but I was not able to verify that.
This is the example of my current system. Note the two last partitions which are Windows 7 and Windows 8. The Windows 7 partition is marked as active. You also see that I have no small system partition because I have eliminated that partition after I moved the bootmgr from that small system partition to the Windows 7 partition.
If I would delete the Windows 7 partition, my Windows 8 would not boot any more because it would have lost it's bootmgr that is in cohabitation with the Windows7 bootmgr.
In order to avoid such an unfortunate situation, we launch the system that we want to retain and move the bootmgr to that system's OS partition. Here is how.
Step 2 - Delete the unwanted OS partition and reuse the space (Optional)
Stay in the OS that you want to keep and open Disk Management. Right click on the partition that contains the OS you want to delete and Delete Volume. Then right click on the deleted volume and Delete Partition. Now you should have "Freespace" where this partition originally was.
With Disk Management, you can define a new partition in that freespace or you can add it to the partition that shows to the left of that freespce. Just click on the partition which is to the left and Extend Volume.
If, however, you want to add that freespace to a partition that is to the right of the freespace, then you have to use an external tool. I suggest the bootable CD of Partition Wizard. Here is how.
A word of caution: before you manipulate partitions with Partition Wizard, make an image of all partitions on that disk. I once lost all my partitions on a disk because I made a small mistake manipulating one partition with Partition Wizard. For imaging I recommend Free Macrium. Here is how.
Step 3 - Cleanup the bootmgr
Now that we removed one OS, we have a surplus entry in the bootmgr. We will remove this entry with EasyBCD. As you can see in the picture, the operation takes only 4 clicks.
EasyBCD is a very handy tool for a variety of operations on the bootmgr. You should have that in your toolkit anyhow.
If you stop at this step, the MBR is still in a double boot configuration and when you boot, the BIOS will present you the black screen where you have to choose the operating sytem - although only one operating system is present. This is not a disaster, but it is an unnecessary step that requires your intervention.
The next two steps will reset the MBR to your current OS and then your system will automatically boot into that.
Important: You absolutely have to execute both Steps 4 and Step 5. If you only do Step 4, your system will not boot any more.
Step 4 - Clean the MBR
Step 5 - Reset MBR with the entry of the current OS
27 Jan 2012   #1
SIW2
Vista x64 / 7 X64
You do such friendly tutorials.
27 Jan 2012   #2
whs
Microsoft MVP
I am a friendly person.
27 Jan 2012   #3
netbox
Win7 Pro SP1 x64
Thanks for this easy to follow tutorial but Im a bit confused with this;
I want to install XP on another new partition on my Windows 7 HP laptop, Id check the disk management and the boot was in C:
so, if I delete XP I'll just delete the new partition where XP was installed and remove the boot menu entry via EasyBCD? is that okay?
27 Jan 2012   #4
whs
Microsoft MVP
1. The OS into which you boot will always assume C for the OS partition, regartdles which OS it is.
2. If you install XP, the XP bootmgr will land in the 100MB active partition where the Win7 bootmgr already is.
3. Yes, the day you want to remove XP, you delete the XP volume and partition and cleanup the bootmgr with EasyBCD.
24 Apr 2012   #5
boyans
Win 8 RP, Win 7, XP
Just a small note:
There is no Windows 7 boot manager and Windows 8 boot manager "cohabitation" !
If you can boot Windows 8 then ONLY Windows 8 boot manager is present on active partition. Windows 7 boot manager was replaced by Windows 8 boot manager during Windows 8 installation. (The file name for both is bootmgr and the file can be found on active partition in root folder).
Always the latest boot manager is in control of the booting in a dual or multi boot system based on Vista and later Windows versions.
Every Windows boot manager can boot earlier Windows systems - the oposite is not possible.
09 Jun 2012   #6
GoofyGoober442
Windows 7 Ultimate 64 Bit
Delete Non Active OS from Dual Boot
Hello
Currently I have Windows 7 Ultimate 32bit and 64 bit in a dual boot configuration. I installed the 32bit version first therefore under disk management it is marked as the active OS.
I want to delete the 32 bit version and keep the 64 bit version of Windows 7. I am very leery of errors and want to avoid the "BOOTMGR IS MISSING CTRL-ALT-DELETE TO RESET".
My question is.... Can I delete the 64 bit OS which is not marked as active, then boot into my 32 bit OS and install Windows 7 64 bit over the 32bit so that I end up with just Windows 7 64 bit as my main OS?
To install the Windows 64 bit over the 32 bit version I would just install the 64 bit version and then run windows cleanup to erase the 32 bit version. This way I would not have to format the partition with win7 32 bit and therefore reduce my chances of getting the BOOTMGR error described above.
Sorry if this is difficult to understand but I tried...
Here is a screen shot of my disk management for reference.
PS: I was logged into the 64bit partition when I took the screen shot.
If any of you could please help me out or give insightful advice as to what I should or should not do please let me know.
Thanks!
10 Jun 2012   #7
whs
Microsoft MVP
Unless you have another reason to reinstall the 64bit version, I would move the bootmgr to the current 64bit version (which I believe is C right now as per your picture). Then you can get rid of the 32bit version. Bootmgr - Move to C:\ with EasyBCD
29 Aug 2012   #8
mz7thc
Windows 8 pro
Windows 8 does not boot without old Windows 7
Hi there,
I moved the BCD to the Windows 8 drive. I have now two active drives, the one with Windows 8 on it is the boot disk and one with Windows 7.
If I disable the Windows 7 drive in Bios, I get a disk read error when booting up. I am also unable to delete the old drive.
I am a bit stuck here and don't know how to (safely) proceed.
Hope someone can help, thanks.
29 Aug 2012   #9
whs
Microsoft MVP
It is apparently looking for the bootmgr on the Win7 disk. How did you 'move' the BCD?
How to delete Windows 7 from Dual boot
Hello all, I have windows XP and Windows 7 (Dual Boot). I want to delete windows 7 from it as my computer becomes really laggy. I have Pentium D as processor with 2 GB DDR2 RAM. So can you please tell me as to how delete the partition? Will install Fedora in its place. Hoping to hear from...
General Discussion
help here how to delete dual boot
i already install dual boot which is Windows 7 and winxp but in different hhd i formatted windows xp that partition and still show on boot menu how to delete that? its show in startup and recovery but not show at msconfig there
Installation & Setup
delete XP from dual boot ...
Hi, I first installed WinXP on the first partition of hard disk - drive C:. After that I installed Win7 on a new created 4. partition of the HD. When I start Win7 using boot menue, drive C: ist now for Win7 and D: is for WinXP with following status displayed by disk managment: C: startpartition,...
How to delete XP from dual boot with Win 7
Xp was installed first, then Windows 7 added as dual boot. Now no need to keep XP. However boot files are on XP partition so you cannot just delete/format the XP partition. So get EasyBCD 2.0 latest, you need to register but it's free. Check Windows Disk Management for the "system" flag....
Delete XP dual boot
I see no reason to keep my XP dual boot. The XP installation is on a discrete physical drive. Win7 is on an active drive set as the first boot drive in BIOS and is the default OS at system startup. Can I just remove the drive and do a 7 startup repair to fix the boot, or are there more necessary...
Want to delete an OS from a dual boot configuration
Hello, I originally stated out with XP Pro and then installed Win 7 in a separate partition with dual booting. Now I want to get rid of the XP OS and recover the partition the XP OS is in for other uses. Running bcdedit shows the the Win 7 as drive C and XP as drive D. The master boot...
