Windows 7: Power Plan - Create Shortcut to Change Power Plan
11 Sep 2009   #10
Quote   Quote: Originally Posted by Brink View Post
Quote   Quote: Originally Posted by WinSmith View Post
Yeah, cool. Athough there exists an alternative solution. Yesterday I found a small program which shows all powerplans in list and also changes the tray icon color like R-G-B on changing to power saver - balanced - high performance. I got it at Power Plan Assistant for Windows 7 - TechSpot Downloads
But what I like most of all: this Power Plan Assistant puts my laptop to high performance on plugging in and lets me to standby the monitor with a mouse click. Overall neat, although I'd like it as well to put my lappie back to balanced on plugging out.
Hello WinSmith,
It's ok, but it will not have any custom power plans available to select from in that program.
Oh, haven't noticed that! However 3 default plans seem enough for me. By the way, I was wrong about NOT putting my laptop to balanced on plugging out - program is capable to do so, I just had check the relevant item in settings menu. Regarding custom powerplans, again, I do see the option 'Show custom power plans' in settings menu, it's dimmed though, that's the problem. I'm going to write a support request to its creator, just wondering why the option available yet dimmed...
06 Oct 2009   #11
Windows 7 beta
How to cut and paste the GUID codes
1)Open a CMD window
2)Redirect the command powercfg -list output to a text file the following way:
  • Open a command prompt
  • type powercfg -list > guid.txt
  • Go to Users /Username
  • Open guid.txt with Notepad
3)Now, from the opened file, you can copy and paste the codes as per your needs.
06 Oct 2009   #12
64-bit Windows 10 Pro
Hello Pcadrgas, and welcome to Seven Forums.
Thank you. You can also just copy it straight from the command prompt.
Command Prompt - Copy to Clipboard
08 Dec 2009   #13
PowerToggle.exe program!
Hello to all, I just feel like I had to give out this program I made not too long ago, I am new to programming, so this isn't exactly perfected yet, A hidden app that toggles from High Performance to Power Saver vise versa by running the exe, you can hook it to laptop buttons if your laptop supports such feature.
It uses a separated registry entry, so using the tray icon from windows to change the power plan won't notify the program that the plan has been changed, it only saves what it is currently using to a separated registry entry.
Until I learn how to detect current power plan, this is the most efficient way I have produced so far.
Program is completely free, no watermark, no limitations etc
If you use launching hooks for your keyboard (ones without OSD), this will not disturb the fullscreen applications such as games, on laptops, you can real-time switch your power profile to reduce power usage without having to minimize game and switch the plan.
Program runs from anywhere on the computer, since it uses the registry to save the current profile, NO INSTALLATION NECESSARY!!
Works with Windows Vista and Windows 7, both 32 and 64 bit with the "High Performance" and "Power saver" defaulted in Windows
Eventually I want add support for different and custom profiles support.
Morris Lee
Feedbacks are appreciated!
09 Dec 2009   #14
@morrislee: thanks for an effort man. although to be honest Power Plan Assistant application ( works in Vista, too. I know Vista support is not declared, but it does actually. Power Plan Assistant is a very convenient tool, nicely integrated into OS. God bless your work, but at a moment I'd prefer to use Power Plan Assistant to manage powerplans.
10 Dec 2009   #15
I am aware of that, I know the developer of GMABooster/PowerPlan7 myself, I recall there is only one problem that is why not declared as vista supported, it was the monitor off on double click the icon. But you never know if he fixed it yet!
Morris Lee
14 Dec 2009   #16
Haha, I got it
Ok, after searching through the registry(what a pain...) finally found the entry, so it is finally done(in a way), in the future, I will write more features for it.
so now it detects the real current plan rather then creating a temporary one.
16 Dec 2009   #17
dual: windows 7 Ultimate x64 7600 and XP SP3
thanks a lot m8s, it works like a charm. I always like to disable asus'cool'n'quite feature before gaming.... that's a handy way to do it. I used to run powertogler in windows XP. thanks!
27 Apr 2010   #18
Thanks a lot Brink!! This is much more convenient than the task bar method! Just wanted to know, I assigned keys to the shortcuts (Ctrl+Alt+1 etc) for the power plans, and would like to know if these shortcuts will work when running a full screen application?
27 Apr 2010   #19
Hello Jasimracer, and welcome to Seven Forums.
I've never tried with a full screen application, but if not, you can always use the keyboard shortcut right before and after you open and close the app.
Tutorial Tools Search this Tutorial
Search this Tutorial:
Advanced Search
Windows 7 Tutorial Category
Power Plan Settings - Change
How to Change Power Plan Settings in Windows 7 This will show you how to change the settings for the power plan that you have selected to reflect how you want your Windows 7 computer to manage power usage. Here's How: 1. Open the Start Menu, and type powercfg.cpl in the search...
Trying to change Power Plan details
Always get a message "Your power plan information isn't available". I can change the plan (normal one is Balanced) and I can see it change (radio buttons that is), but I can never look at any plan itself. System is shutting off the monitor (video that is) and there is no way to change the...
Hardware & Devices
How can I change power plan and run scripts based on power state?
I overclock my CPU by changing its FSB and I have scheduled (Task Scheduler) this script to run every time I logon to Windows. But I would like to schedule it to downclock when I pull the power cord and then overclock as I plug it back in. Is this possible? It would also be nice if Windows changed...
General Discussion
Changing power plan also change wallpaper.
Hello to all, As my title says i just want to do that particular thing, if possible. I have a samsung laptop that has a preintalled program that changes to silent mode(low consumption)- normal mode and speed mode (high cunsuption plan). When i change to low or high plan i want to also change to...
Themes and Styles
View/Change Power Plan via Registry?
Hello all, I'm working on a little Visual Basic .NET program that simply changes the power plan based upon the AC power status and battery percentage status (something that Windows 7 should already do...:rolleyes:) Anyway, it's coming along well enough, except that I need to have my program run...
Performance & Maintenance
Custom Power Plan - Create or Delete
How to Create or Delete a Custom Power Plan in Windows 7 and Windows 8 A power plan is a collection of hardware and system settings that manages how your computer uses power. Power plans can help you save energy, maximize system performance, or achieve a balance between the two. This...
