Start Menu Button - Change
Page 9 of 19 FirstFirst ... 7891011 ... LastLast
  1. Posts : 4,755
       #80
    Dinesh said:
    Ok can someone upload red fusion start buttons please>>>
    Dinesh.... I got this custom made from Ray (xxrazor) and i think you might like it
    Start Menu Button - Change Attached Files
  2. Posts : 8,476
    Windows® 8 Pro (64-bit)
       #81
    Thanks Sergio.
  3. Posts : 1
    Windows 7 Ultimate
       #82
    xD thanks man!!!!!! thanks to your tutorial i finally changed the explorer.exe icon xD!!!!! i replace his icon in explorer.exe check:
  4. Posts : 4,755
       #83
    You're all welcome :)
  5. Posts : 2
    Hey...I can't replace my explorer.exe even when I take ownership of it, and the windows folder...It says I don't have permission to edit it when I am a Admin...Please Help!
  6. Posts : 2
    Nvm, I got it fixed, I never turned off UAC :P
  7. Posts : 913
    Windows 7 x64 Professional
       #86
    Awesome tutorial... Had no problems with anything...
    EXCEPT:
    Now the start button don't do NOTHING! It shows the new image but I can't click it. Nothing happens. I should mention that I have a little app in my startup folder that automatically kills the taskbar but that never affected the old start button (no taskbar is visible, just the orb - looks pretty cool). All this tutorial does is change the orb image, nothing else right? So i don't see why the orb shows but doesn't respond...
    Strangely, when I press the start key on the keyboard THEN the orb highlights (as if its has been clicked) and the start menu appears...
    I mean, wtf?
    Help guys, please...
    PS: why can't I edit the explorer.exe file with ResHack?
  8. Posts : 4,755
       #87
    EXCEPT:
    I mean, wtf?
    Hmm sounds weird. Might have something to do with that app. Try restoring to your old explorer.exe and see if the problem is still there.
    And yes i believe you can use reshacker for editing the explorer.exe
  9. Posts : 913
       #88
    Gonna try that now...
    It won't show in reshack though
    FILE ---> OPEN ----> (C:/windows/explorer.exe) ---> NOTHING!!! AAAARRRRGGGHHH!
    BTW: that was quick
  10. Posts : 913
       #89
    Reverted back to original explorer.exe and it works perfectly ?! I dunno mate, is it possible that the images alone can affect it so? My anti-taskbar app hasn't been touched - I really doubt it's that though...
    Any other ideas?
