How to Turn Toggle Keys Tone On or Off in Windows 7 and Windows 8
This tutorial will show you how to turn on or off the tone you hear when the CAPS LOCK, NUM LOCK, or SCROLL LOCK toggle keys are pressed in Windows 7 and Windows 8.
Tip
You may also have a setting for this in your keyboard properties when you open the
Control Panel (icons view) and click/tap on the
Keyboard icon. This will vary depending on what the drivers for that brand of keyboard has included with it though.
OPTION ONE
Turn On or Off Toggle Keys Tone in Control Panel
1. Open the
Control Panel (icons view) in
Windows 7 and
Windows 8, and click/tap on the
Ease of Access Center icon.
2. Click on either the
Make the Keyboard Easier To Use or
Make it easier to focus on tasks link, and do to
step 3 or 4 below for what you would like to do. (see screenshot below)
3. To Turn On Toggle Keys Tone A) Check the Turn on Toggle Keys box, and go to step 5 or 7 below. (see screenshots below step 7)
4. To Turn Off Toggle Keys Tone
NOTE: This
is the default setting.
A) Uncheck the Turn on Toggle Keys box, and go to step 5 or 7 below. (see screenshots below step 7)
5. To Enable NUM LOCK Key to Turn On Toggle Keys Tone
This will allow you to toggle the Toggle Keys Tone on or off by holding down the
NUM LOCK key for 5 seconds.
- When Toggle Keys is turned off, you will hear a sick sounding tone.
- When Toggle Keys is turned on, you will here a beep tone and may need to click on Yes to confirm.
A) Check the Turn on Toggle Keys by holding down the NUM LOCK key for 5 seconds box, and go to step 7 below. (see screenshots below step 7)
6. To Disable NUM LOCK Key to Turn On Toggle Keys Tone A) Uncheck the Turn on Toggle Keys by holding down the NUM LOCK key for 5 seconds box, and go to step 7 below. (see screenshots below step 7)
7. Click/tap on
OK, and close the
Ease of Access Center window. (see screenshots below)
OPTION ONE
Turn On or Off Toggle Keys Tone in PC settings
NOTE: This option is only available in Windows 8.1 and Windows RT 8.1. 1. Open
PC settings, and click/tap on
Ease of Access on the left side. (see screenshot below)
2. Click/tap on
Keyboard on the left side of
Ease of Access, and do step 3 or 4 below for what you would like to do. (see screenshot below)
3. To Turn On Toggle Keys Tone A) Under Toggle Keys on the right side of Keyboard, move the slider to the right to turn it on, and go to step 5 below. (see screenshot below step 2)
NOTE: This
A) Under Toggle Keys on the right side of Keyboard, move the slider to the left to turn it off, and go to step 5 below. (see screenshot below step 2)
5. When finished, you could
close PC settings if you like.
