Control Panel - Change Default Icons
How to Change Default Control Panel Icons in Windows 7
This will show you how to change the default icons in the All Control Panel Items small and large icons view to any custom icon that you want instead in Windows 7.
   Tip
You should use a 256x256 pixel .ico (icon) files to have the best support for all icon view sizes.
   Warning
This can only be done in an administrator account.
EXAMPLE: All Control Panel Items with Small and Large Icons View
OPTION ONE
Change Control Panel Icons
1. If open, close the Control Panel.
2. Open the Start Menu, and type regedit in the search line and press enter.
3. If prompted by UAC, then click on Yes.
4. In regedit, navigate to HKEY_CLASSES_ROOT\CLSID and continue to the location of the Control Panel icon in the table below for the one that you want to change.
Control Panel IconRegistry CLSID Location
Action Center{BB64F8A7-BEE7-4E1A-AB8D-7D8273F7FDB6}\DefaultIcon
Administrative Tools{D20EA4E1-3957-11d2-A40B-0C5020524153}\DefaultIcon
Autoplay{9C60DE1E-E5FC-4of4-A487-460851A8D915}\DefaultIcon
Biometrics{0142e4d0-fb7a-11dc-ba4a-000ffe7ab428}\DefaultIcon
Backup and Restore{B98A2BEA-7D42-4558-8BD1-832F41BAC6FD}\DefaultIcon
BitLocker Drive Encryption{D9EF8727-CAC2-4e60-809E-86F80A666C91}\DefaultIcon
Color Management{B2C761C6-29BC-4f19-9251-E6195265BAF1}\DefaultIcon
Credential Manager{1206F5F1-0569-412C-8FEC-3204630DFB70}\DefaultIcon
Date and Time{E2E7934B-DCE5-43C4-9576-7FE4F75E7480}\DefaultIcon
Default Programs{17cd9488-1228-4b2f-88ce-4298e93e0966}\DefaultIcon
Desktop Gadgets{37efd44d-ef8d-41b1-940d-96973a50e9eo}\DefaultIcon
Device Manager{74246bfc-4c96-11d0-9bef-0020afgb0b7a}\DefaultIcon
Devices and Printers{A8A91A66-3A7D-4424-8D24-04E180695C7A}\DefaultIcon
Display{C555438B-3C23-4769-A71F-B6D3D9B6053A}\DefaultIcon
Ease of Access Center{D555645E-D4F8-4c29-A827-D93C859C4F2A}\DefaultIcon
Folder Options{6DFD7C5C-2451-11d3-A299-00C04F8EF6AF}\DefaultIcon
Fonts{BD84B380-8CA2-1069-AB1D-08000948F534}\DefaultIcon
Getting Started{CB1B7F8C-C50A-4176-B604-9E24DEE8D4D1}\DefaultIcon
HomeGroup{67CA7650-96E6-4fDD-BB43-A8E774F73A57}\DefaultIcon
Indexing Options{87D66A43-7B11-4A28-9811-C86EEE395ACF7}\DefaultIcon
Infared{A0275511-0E86-4ECA-97C2-ECD8F1221D08}
Internet Options{A3DD4F92-658A-410F-84FD-6FBBBEF2FFFE}\DefaultIcon
Keyboard{725BE8F7-668E-4C7B-8F90-46BDB0936430}\DefaultIcon
Location and Other Sensors{E9950154-C418-419e-A90A-20C5287AE24B]\DefaultIcon
Mouse{6C8EEC18-8D75-41B2-A177-8831D59D2D50}\DefaultIcon
Network and Sharing Center{8E908FC9-BECC-40f6-915B-F4CAOE70D03D}\DefaultIcon
Notification Area Icons{05d7b0f4-2121-4eff-bf6b-ed3f69b894d9}\DefaultIcon
Parental Controls{96AE8D84-A250-4520-95A5-A46A7E3C548B}\DefaultIcon
Pen and Touch{F82DF8F7-8B9F-442E-A48C-818EA735FF9B}\DefaultIcon
Performance Information and Tools​
{78F3955E-3B90-4184-BD14-5397C15F1EFC}\DefaultIcon
Personalization{ED834ED6-485A-4bfe-8F11-A626DCB6A921}\DefaultIcon
Phone and Modem{40419485-C444-4567-851A-2DD7BFA1684D}\DefaultIcon
Power Options{025A5937-A6BE-4686-A844-36FE4BEC8B6D}\DefaulIcon
Programs and Features{7b81be6a-ce2b-4676-a29e-eb907a5126c5}\DefaultIcon
Recovery{9FE63AFD-59CF-4419-9775-ABCC3849F861}\DefaultIcon
Region and Language{62D8ED13-C9D0-4CE8-A914-47DD628FB1B0}\DefaultIcon
RemoteApp and Desktop Connections​
{241D7C96-F8BF-4F85-B01F-E2B043341A4B}\DefaultIcon
Sound{F2DDFC82-8F12-4CDD-B7DC-D4FE1425AA4D]\DefaultIcon
Speech Recognition{58E3C745-D971-4081-9034-86E34B30836A}\DefaultIcon
Sync Center{9C73F5E5-7AE7-4E32-A8E8-8D23B85255BF}\DefaultIcon
System{BB06C0E4-D293-4f75-8A90-CB05B6A77EEE}\DefaultIcon
Tablet PC Settings{80F3F1D5-FECA-45F3-BC32-752C152E456E}\DefaultIcon
Taskbar and Start Menu{0DF44EAA-FF21-4412-828E-260A8728E7F1}\DefaultIcon
Troubleshooting{C58C4893-3BE0-4B45-ABB5-A63E4B8C8651}\DefaultIcon
User Accounts{60632754-c523-4b62-b45c-4172da012619}\DefaultIcon
Windows Cardspace{78CB147A-98EA-4AA6-B0DF-C8681F69341C}\DefaultIcon
Windows Defender{D8559EB9-20C0-410E-BEDA-7ED416AECC2A}\DefaultIcon
Windows Firewall{4026492F-2F69-46B8-B9BF-5654FC07E423}\DefaultIcon
Windows Live Language Setting{2BADA6D5-9815-4f01-9957-74AF8077FD18}\DefaultIcon
Windows Mobility Center{5ea4f148-308c-46d7-98a9-49041b1dd468}\DefaultIcon
Windows SideShow{E95A4861-D57A-4be1-AD0F-35267E261739}\DefaultIcon
Windows Update{36eef7db-88ad-4e81-ad49-0e313f0c35f8}\DefaultIcon
5. In the left pane, right click on DefaultIcon and click on Permissions. (See screenshot below)
NOTE: This (steps 5 to 7) is to take ownership of the DefaultIcon key. It is required.Reg1.jpg
7. Click on the Owner tab, select Administrators (highlighted in blue below), and click on OK. (See screenshot below)
NOTE: If you are prompted to approve changing the owner, then approve it.Take_Ownership_2.jpg
8. At the top, select Administrators (highlighted in blue below), then check the Allow box for Full Control and click on OK. (See screenshot below)
NOTE: This just allowed you (administrator) full permission to make changes to the DefaultIcon key in step 9 below.Full_Control.jpg
9. In the right pane of the DefaultIcon key in regedit, right click on (Default) and click on Modify. (See screenshot below)Reg1.jpg
10. Type in the full path within quotes to the custom icon that you want to use instead of the default icon with the .ico file extension included, then click on OK. (See screenshot below)
NOTE: If you move or change this icon's location that you used in this step, then the icon will no longer work in the Control Panel until you change the path again to the new location.
For a custom icon path example: "C:\icon folder\icon file.ico"Modify.jpg
11. Repeat steps 4 to 10 to change another default Control Panel icon.
12. When done, close regedit and open the Control Panel with small or large icons view to see your changes.
OPTION TWO
Restore Default Control Panel Icons
This option assumes that you have already taken ownership and gave yourself permission of the DefaultIcon key from steps 5 to 8 in OPTION ONE above. If you have not, then you will need to do so before Windows 7 will allow you to do the ones below.
1. Repeat only steps 1 to 4 in OPTION ONE above for the Control Panel icon that you want to restore to default.
2. In the right pane of the DefaultIcon key in regedit, right click on (Default) and click on Modify. (See screenshot below)Reg1.jpg
3. Type in the default path for the Control Panel icon in the table below and click on OK. (See screenshot below)Modify.jpg
Control Panel IconDefault Icon Path
Action Center%SystemRoot%\System32\ActionCenterCPL.dll,-1
Administrative Tools%SystemRoot%\System32\imageres.dll,-114
Autoplay%SystemRoot%\System32\autoplay.dll,-1
Backup and Restore%SystemRoot%\System32\sdcpl.dll,-1
Biometrics%SystemRoot%\System32\biocpl.dll,-1
BitLocker Drive Encryption%SystemRoot%\System32\fvecpl.dll,-1
Color Management%systemroot%\system32\colorcpl.exe,-5
Credential Manager%SystemRoot%\system32\Vault.dll,-1
Date and Time%SystemRoot%\System32\timedate.cpl,-50
Default Programs%SystemRoot%\System32\imageres.dll,-24
Desktop Gadgets%ProgramFiles%\Windows Sidebar\Sidebar.exe,-100
Device Manager%SystemRoot%\system32\devmgr.dll,-201
Devices and Printers%systemroot%\system32\DeviceCenter.dll,-1
Display%SystemRoot%\System32\Display.dll,-1
Ease of Access Center%SystemRoot%\System32\accessibilitycpl.dll,-1
Folder Options%SystemRoot%\system32\imageres.dll,-166
Fonts%SystemRoot%\System32\fontext.dll
Getting Started%SystemRoot%\branding\shellbrd\shellbrd.dll
HomeGroup%SystemRoot%\System32\imageres.dll,-1013
Indexing Options%SystemRoot%\System32\srchadmin.dll,-201
Infared%SystemRoot%\System32\irprops.cpl,-129
Internet OptionsC:\Windows\System32\inetcpl.cpl,-4487
Keyboard%SystemRoot%\System32\main.cpl,-200
Location and Other Sensors%SystemRoot%\System32\SensorsCpl.dll,-1
Mouse%SystemRoot%\system32\main.cpl,-100
Network and Sharing Center%SystemRoot%\System32\netcenter.dll,-1
Notification Area Icons%SystemRoot%\System32\taskbarcpl.dll,-1
Parental Controls%SystemRoot%\System32\wpccpl.dll,-1
Pen and Touch%SystemRoot%\System32\tabletpc.cpl,-10201
%SystemRoot%\System32\PerfCenterCPL.dll,-1
Personalization%SystemRoot%\System32\themecpl.dll,-1
Phone and Modem%SystemRoot%\System32\telephon.cpl,-100
Power Options%SystemRoot%\System32\Powercpl.dll,-1
Programs and Featuresimageres.dll,-87
Recovery%SystemRoot%\System32\imageres.dll,-1022
Region and Language%SystemRoot%\System32\intl.cpl,-200
%SystemRoot%\System32\tsworkspace.dll
Sound%SystemRoot%\System32\mmsys.cpl,-100
Speech Recognition%SystemRoot%\System32\Speech\SpeechUX\speechuxcpl.dll,-1
Sync Center%SystemRoot%\System32\SyncCenter.dll,-1000
System%SystemRoot%\System32\imageres.dll,-149
Tablet PC Settings%SystemRoot%\System32\tabletpc.cpl,-10200
Taskbar and Start Menu%SystemRoot%\System32\imageres.dll,-80
Troubleshooting%SystemRoot%\System32\DiagCpl.dll,-1
User Accounts%SystemRoot%\System32\usercpl.dll,-1
Windows Cardspace%SystemRoot%\System32\icardres.dll,-4096
Windows Defender%ProgramFiles%\Windows Defender\MsMpRes.dll,-103
Windows FirewallC:\Windows\system32\FirewallControlPanel.dll,-1
Windows Live Language Setting​
C:\Program Files (x86)\windows live\installer\LangSelectorRes.dll,0
Windows Mobility Center%SystemRoot%\system32\mblctr.exe,0
Windows SideShow%SystemRoot%\System32\AuxiliaryDisplayCpl.dll,-1
Windows Update%SystemRoot%\system32\wucltux.dll,-1
4. Repeat steps 1 to 3 to change another default Control Panel icon.
5. When done, close regedit and open the Control Panel with small or large icons view to see your changes.
Shawn Brink
Very nice tutorial Shawn!
Maybe [Hint]someone will make an icon pack for control panel[/Hint]
Windows 7 Ultimate, OS X 10.7, Ubuntu 11.04Intel E6750 @ 3.80GHz2x2GB & 2x1GB (6GB) OCZ Reaper 1066MHz @ 1080MHzEVGA nVidia GTX 260 896mb (216 Core) FTW Edition
Custom | Whitebox
Realtek ALC888
21" VIZIO TV
1680x1050 @ 60Hz
Corsair 750W
NZXT Nemesis Elite
Thermaltake SpinQ
Logitech Wireless S520
Thank you Steve.
LOL, now that would be a bit of work to create a pack for all of them. :eek:
Thank you Steve.
Yeah I suppose, maybe a tutorial for making icons? :) I'd like to take a whack at them (who doesn't love whack-a-mole?).
Custom | Whitebox
Realtek ALC888
21" VIZIO TV
1680x1050 @ 60Hz
Corsair 750W
NZXT Nemesis Elite
Thermaltake SpinQ
Great Tutorial, Brink.
Win 7
Win 7
That would be nice. If anyone knows of a good set please feel free to let me know.
Thanks for tutorial, easy to follow for a newbie like me. :o
Tye
Windows 7 Ultimate 32 bitAMD Phenom 8450 Triple Core 2.1GHzCorsair 4GBATI Radeon HD3650 1GB
MSI MS-7388
Corsair 4GB
Onboard 7.1
Samsung 24" LCD - Philips 42" LCD
1600 x 900 32bit @60Hz
Maxtor 120GB IDE - Hitachi 1TB SATA
650w
You're welcome Tye. I'm happy to hear that you found it easy to follow. :)
Thanks BRink, I've searched high and low for such a tutorial, two thumbs up, you rock.
windows 7 64bit
windows 7 64bit
You're most welcome Optical, and welcome to Seven Forums. :)
I have a problem restoring the default icons. I restored all but 2, backup and restore - windows firewall. I noticed that windows firewall refers to a folder location and when I navigated there, C:\Windows\system32\FirewallControlPanel.exe is not present, I have a FirewallControlPanel.dll file but not an .exe. I triple checked to make sure I entered the info correctly but when I open control panel both icons are the windows default folder icon.
Any Ideas?
Thanks, Tye.
MSI MS-7388
Corsair 4GB
Onboard 7.1
650w
Hi Tye,
I've just checked, and the correct data is as shown in the image below. I have corrected the Tutorial.
The data reads: C:\Windows\system32\FirewallControlPanel.dll,-1
Dwarf Dwf/11/2012 r09/2013
Windows 8.1 Pro RTM x64
ASRock Z77 Extreme4-M
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Gigabyte IF233
Avast! 8.0.1497
IE 11
Thank you Dwarf. :)
You're welcome, Shawn. :)
I've also corrected the error pertaining to the default icon for Backup and Restore (the other item Tye was having trouble with).
The data is as follows: %SystemRoot%\System32\sdcpl.dll,-1
Gigabyte IF233
Avast! 8.0.1497
IE 11
Thanks Dwarf, problem fixed.
Tye.
MSI MS-7388
Corsair 4GB
Onboard 7.1
650w
You're welcome, Tye. :)
Gigabyte IF233
Avast! 8.0.1497
IE 11
Works, thanks alot Brink :)
one question tho, how come the homegroup icon isn't changed on other locations?
Picture 2 the icon is working
Picture 1 nothing is changed..
aren't they linked to the same register key?
if not then how do one change the homegroup icon in the first image?
Windows 7 Ultimate x642.1Ghz3GbnVidia 8600M GT
LG Notebook
2.1Ghz
N/A
3Gb
nVidia 8600M GT
17.1" TFT ( WSXGA+ ) - Glare
17.1"
320Gig disc
N/A
Laptop Case =)
Laptop again xD
Builtin @ Laptop =)
Razer Copperhead
100/100Mb :) Swe Connection =D
i eat metal :D
Is there a way to change the icons in category view
Windows 7 Home Premium x64 SP1intel(R)core(TM)2 duo CPU T6600 @ 2.20GHz3 gb ddr3ati radeon hd4570/512mb
acer aspire 5935g
intel gm45/gm47 revision 07
3 gb ddr3
lop156wh2-tle1 15.3 flat
1366x768
OCZ-Agility3 60gig ssd
320gig external hdd
500gig external hdd
Optical
30Mbps Down/30Mbps Up
Hello Danny,
I've only found the ones in the small/large icon views to change so far. :(
One Q?
Is it possible to replace this icons as well
Registry files + Icons
CP-Reg-Icons.rar
1. Put the IconCP (folder with icons) in C:\Windows folder (or edit .reg to correct path)
Icons in "IconCP" replace with Your own icons just don't rename it!
2. Merge reg files.
7 Ultimate x64 sp1Intel i5-4690K16Gb HyperX furyR9-270x 2Gb
696
7 Ultimate x64 sp1
Intel i5-4690K
GA Z97X Gaming 5
16Gb HyperX fury
R9-270x 2Gb
On Board
2443NW
1920x1200
WD5000 -
WD5001 -
WD1002
Cft-650-14cs
Very Big Case
stock
G11
Adsl
FF
RWD
