Host a Website - IIS7.5
Page 1 of 6 123 ... LastLast
    Host a website using IIS7.5
    Host your own website using IIS7.5
    Windows 7 comes with a very handy application/tool set called Internet Information Services 7.5 which allows you to use any PC (Home or on a Network) as a server for your newly created website
    You will need to register a DNS Host from here for free, purchasing a Domain is Optional
    Update:
    You can host a website without the need to register a Dynamic DNS host name. If you visit YouGetSignal it will give an External Address which can be used instead of the host name. For example, typing "http://x.xxx.xx.xxx" into your browser address bar will gain you access to the site you're hosting.
    You can only host 1 website by using this method unless you add "/[new folder]/" to the end of the address
    You will also need your IPv4 address, run command prompt (type cmd into the Start Menu) and type ipconfig, scroll up slightly & take note of your IPv4 address. This will be used to configure your router.
    Special thanks goes to z3r010 for the majority of this information
    Here's How:
    Part 1: Acquiring the DNS Host
    Go to www.no-ip.com and register for free. Click the 'Add Host' button and you will be give the option to name your host.
    Host a Website - IIS7.5-add-host.pngHost a Website - IIS7.5-enter-details.png
    Just enter the name of your website and choose a prefix then click 'Create Host' (highlighted in image)
    That is all the info you need to enter to create your DNS Host. It is also recommended that you download their NO-IP software too, as this will manage/sync your host.
    Part 2: Installing & Using IIS7.5
    1, Access 'Control Panel, and click 'Programs' followed by 'Turn Windows features on or off'.
    2, Click the checkbox for each of the Internet Information Service toolsets then click 'OK'
    Note: A system restart may be required
    3, Run the IIS Manager - in the Start Menu type "IIS"
    4, Right-Click on 'Sites' and click 'Add Web Site'
    Note: You may need to 'Expand' the explorer branch to allow you to see 'Sites'
    5, Enter a 'Site Name', this can be anything (E.g. My New Site), 'Phisical Path' (E.g. C:\MY_SITE) and 'HOST Address', this is the address of the HOST you created in step 1 (e.g. my-new-site.no-ip.org) and click OK
    Step 3: Router/Windows Firewall exception
    1, In the Start Menu, type "firewall" and click 'Windows Firewall with Advanced Settings'
    2, Click 'Inbound Rules' then 'New Rule' to start the 'New Rule Wizard. Click 'Port' then 'Next'
    Click 'TCP' and enter port '80' then click 'Next'
    Click 'Allow the connection' then click 'Next'
    Click the rules that apply, then 'Next'
    Lastly, name the new fule & click 'Finish'
    You will see that the new rule has now been created and you can close Windows firewall
    You will need to consult your router documentation for details on how to allow firewall exceptions
    The 2 exceptions you will need to configure are
    • 'Outbound service' - Always allow HTTP(TCP:80)
    • 'Inbound Service' - Always allow HTTP(TCP:80) and 'Send to lan server' within that (enter your IPv4 address)
    Now when you type the HOST address, e.g. no-ip.org, you, and others, will be able to access your site.
  1. Posts : 51,477
    Windows 11 Workstation x64
    If you want to add php support etc then the quickest way is to use the Web platform installer:-
    Download the Microsoft Web Platform
      My Computers
  2. Posts : 682
    Window 7 build 7600, Xp pro(VM)
    NIce tutorial, thanks guys............
    I think now it is time for me to send Apache web server to Recycle bin..
  3. Posts : 11,840
    64-bit Windows 8.1 Pro
    Apache is ok except its not native to Windows. Once you finally find your way around and get it going its fine ... once you get it going ... Im not sayin, Im just sayin!!
    Nice Tutorial!!
  4. Posts : 682
    Nice Tutorial!!
    yesterday I spend the whole day to get it working but I failed very badly..
    Check this thread out Apache web server help.
  5. Posts : 8,476
    Windows® 8 Pro (64-bit)
    Nice work Jeff. :)
  6. Posts : 8,476
    Could you please tell me how do you do that? I m almost done, except this.
  7. Posts : 6,305
    You will need to access your router setup, just type in the IP address of the router homepage into your browser.
    You then need to access the 'Securty' features, then 'Firewall' and add an exception to both 'Incoming' and 'outgoing
    What router do you have, I may be able to help in more detail
  8. Posts : 8,476
    I dont have a router. Its direct.
  9. Posts : 6,305
    Ah, in that case i'm not sure sorry
    Hopefully someone may be able to help you
