#20
You could do the same for them as well. You'll just need to substitute the bottom command for the .bat file below for the one you want instead.
The message displayed by the echo command can be anything you like to help know what it it's for, etc...
I'm not sure how to have the abort command work using this method though, but luckily it gives you the option to abort during the prompt.Code:@echo off echo Your message here timeout /t 30 /nobreak shutdown -h -f
