How to Create a Hibernate Shortcut in Windows
This tutorial will show you how to create a shortcut for Hibernation on the desktop. This can then be moved anywhere you like.
Warning
You will need to enable hibernate for this hibernate shortcut to work. Otherwise it will put your computer to sleep instead.
Step 1: Right click on the desktop and select New -> Shortcut
Step 2: Type this into the location field:
C:\Windows\System32\rundll32.exe powrprof.dll,SetSuspendState 0,1,0
Step 3: Name it whatever you would like:
You now have your Hibernation shortcut!
Step 4 (optional): Change the icon to something meaningful. Right click on the shortcut, and select Properties. In the Shortcut tab, choose "Change Icon". You can use the default icons in there, or choose from the power icons by clicking browse, and typing this:
%SystemRoot%\System32\powrprof.dll
Step 5: Enable hibernate.
All done!
~Lordbob
Related Tutorials
- How to Enable or Disable Hibernate in Windows 7
- How to Change the Size of the hiberfil.sys File in Windows 7
- How to See What Your Windows 7 Restart Time is
- How to Create a Lock Computer Shortcut on Your Windows 7 Desktop
- How to Create a Log Off Shortcut in Windows
- How to Create a Shut Down Windows Shortcut in Windows 7
- How to Create a Shut Down Computer Shortcut in Windows
- How to Create a Abort Shortcut in Windows
- How to Create a Switch User Shortcut in Windows 7
- How to Create a Restart Computer Shortcut in Windows
- How to Create a Sleep Shortcut in Windows
- How to Create a Keyboard Shortcut for a Program in Vista and Windows 7
- How to Add or Remove the Shut Down, Restart, Sleep, and Hibernate Commands in Windows 7
