Windows 7: New Installation: How to Create a General System Image in Audit Mode
09 Dec 2012   #10
Kari
OK DjMaj, first I would like to welcome you to the Seven Forums.
I have given you some rep for pointing out a mistake in my tutorial. You are completely right, you need to quit SysPrep tool before creating the image, otherwise the imaging tool sees Audit Mode as Safe Mode thus refusing to create an image.
I edited steps 3 & 4 in tutorial, works now .
Kari
12 Dec 2012   #11
DjMaj
Windows 7 x64
Hi Kari ,
Thank for the fix
Regards.
21 Jan 2013   #12
bonesboy
Windows 7 Enterprise 32bit & Windows 8 Single Language
hi there.
Is there by any chance i can change the user folder to another location in the audit mode? How can i go on about it?
21 Jan 2013   #13
essenbe
Windows 7 Enterprise X64/Windows 10 Enterprise X64/Windows 10 Pro X64/Linux Mint
24 Jan 2013   #14
bonesboy
Sorry about that.. thank you for pointing me to the correct thread.
24 Jan 2013   #15
essenbe
No problem, hope it helps.
06 Mar 2013   #16
too
Windows 7 x64 Ultimate
Great tutorial!!!
One question, I have Windows in one HD and the programs installed in another HD.
Is there a way to reinstall Windows and then "reinstall" the programs that are in the other HD? Without having to reinstall everything, that takes a very long time. Sort of linking them back, adding registry information or something.
Thanks!
06 Mar 2013   #17
Kari
No, reinstall requires all software to be reinstalled.
There are some third party tools meant to transfer your installed apps from one installation to another, but a skeptic as I am I would not trust them. A correctly installed and registered application can have many entries in registry, ProgramData and AppData that moving / copying them is IMO a doomed project.
Kari
06 Mar 2013   #18
essenbe
I may not be correct here, but I think if you did the sysprep, most, if not all your programs should still work without the other Windows installation. If you moved the user files during a clean install, they will have to be reinstalled. I believe that is correct. If not, I'm sure someone with more knowledge than me will be able to give you a better answer.
06 Mar 2013   #19
Kari
As this tutorial is about creating a system image during a clean install before any user accounts are created I understood the question being if he can port installed apps from a backup or other installation to this fresh installation.
Windows 7 Image - Customize in Audit Mode with Sysprep
How to Create, Customize, and Maintain Windows 7 Image in Audit Mode with Sysprep Tool There were two things that made me start writing this tutorial. First one was a very misleading article I read on the Internet and the second one was this response on another tutorial of mine: We...
Tutorials
Windows 7 pro - Create system image only system c: drive
I have a 1TB drive that partioned with 120gb system and rest is a non primary/non boot data partition volumn.. I've never used windows 7 create system image, but want to . When I try to create a system image it insist on backing up both drives. I don't see how to deselect the data drive. Is...
Backup and Restore
Create OS image only for re installation from Partitioned Hard drive
Not exactly sure how to explain or even exactly what im looking for but basically I had an older laptop running windows 7 home premium that allowed me from the boot menu to re install windows & home premium w/o key or anything. It was placed on a partition of my hard drive. I would like to do this...
Backup and Restore
Activating an local partition to the protection system in audit mode
HI I have partitioned a disk into two primary partitions. On one of them, I installed Windows 7 SP1 Ultimate 64 bit, but, during its installation, I pressed, the Ctrl+Shift+F3 sequence to go in audit mode. Now, wanting to activate the D local partition to the protection system, I wrote:...
Installation & Setup
Create a System Image Shortcut - Create
How to Create a "Create a System Image" Shortcut in Windows 7 This will show you how to create a Create a System Image shortcut in Windows 7. To be able to use this shortcut, you must be logged in as an administrator. EXAMPLE: Create a System Image
Tutorials
