Windows 7: Advanced System Settings Shortcut - Create
How to Create a Windows 7 Advanced System Properties Shortcut
Published 08 Sep 2009
Featured Tutorial
User Profile - Customize During Installation
How to Customize Default User Profile in Audit Mode
Secunia ONLINE Software Inspector
How to Scan for Common Software Vulnerabilities
Windows 7 Installation - Transfer to a New Computer
How to Transfer your Complete Windows 7 Installation to a New Computer
Driver Install - Device Manager
How to Install a Driver in Device Manager
Troubleshooting Windows 7 Failure to Boot
information   Information
This will show you how to create or download a Advanced System Settings shortcut that opens directly to the Advanced tab in System Properties.
You can also Pin to Taskbar or Pin to Start Menu this shortcut, or move where you like in Windows 7 for easy use.
Note   Note
In Advanced System Settings, you have the option to set the Visual effects performance, User Profiles, and Startup and Recovery settings.
warning   Warning
You must be logged on as an administrator to make changes to the settings using this shortcut.
EXAMPLE: Advanced System Properties
OPTION ONE
Download the Shortcut
1. Click on the Download button below to download the file below.
Advanced_System_Settings.zip
download
2. Click on Save, and save the .zip file to the desktop.
3. Open the .zip file and extract the Advanced System Settings shortcut to the desktop.
4. Right click on the Advanced System Settings shortcut, and click on Properties, General tab, and on the Unblock button. (See screenshot below)
5. Move the shortcut to where you like for easy use.
6. When done, you can delete the downloaded .zip file on the desktop if you like, or save it to use again.
Option Two
Manually Create the Shortcut
1. Right click on a empty area on desktop, and click on New and Shortcut. (See screenshot below)
2. Copy and paste the location below into the location area, and click on the Next button. (See screenshot below)
C:\Windows\System32\SystemPropertiesAdvanced.exe
3. Type Advanced System Settings for the name, and click on the Finish button. (See screenshot below)
4. Move the shortcut to where you like for easy use.
Need more help? Try searching our extensive help and support site.
Loading
Comment
 Advanced System Settings Shortcut - Create problems?
Tutorial Tools
Similar help and support threads for: Advanced System Settings Shortcut - Create
Windows 7 Tutorial Category
Advanced Power Options Shortcut - Create Tutorials
Pen and Touch Settings - Create Shortcut Tutorials
Advanced User Accounts Shortcut - Create Tutorials
WMP Settings Troubleshoot Shortcut - Create Tutorials
Solved Advanced System Settings General Discussion
