Page 34 of 43 FirstFirst ... 243233343536 ... LastLast
  1. Posts : 24,479
    Windows 7 Ultimate X64 SP1
       #330
    ZakASenior said:
    After typing diskpart into cmd prompt, it does not allow me to type anything else. What could be the issue?
    Are you using the Elevated CMD prompt? Option Two, Step Three.
  2. Posts : 21,004
       #331
    Oops I should have thought of that too Gary I take it you mean as admin??
  3. Posts : 24,479
       #332
    Yes that's it John. I use Shawn's tutorial Elevated Command Prompt Shortcut and then put the shortcut in my Start menu. :)
  4. Posts : 3
    Well, I'm a beginner and my English is not so good, but I will try my best to describe my question.
    I had learned the installation steps but I'm puzzled by the WARNING .
    Here,
    • You can only create a 64-bit Windows 7 bootable USB flash drive if your current Windows 7 installation is also 64-bit.
    • You can create a 32-bit Windows 7 bootable USB flash drive if your current Windows 7 installation is 32-bit or 64-bit.
    I'm wondering that, how can I create a 32-bit flash drive in a 64-bit installation while I can only create a 64-bit flash drive if my current installation is also 64-bit?
    Thanks very much!:)
  5. Posts : 72,058
       #334
    Hello Kylee, and welcome to Seven Forums.
    It means that you can create a 32-bit USB in both a 32-bit and 64-bit Windows 7, but will only be able to create a 64-bit USB in a 64-bit Windows 7.
  6. Posts : 3
    So, that means:
    64-bit installation + 64-bit ISO = 64-bit flash drive
    64-bit installation + 32-bit ISO = 32-bit flash drive
    32-bit installation + 32-bit ISO = 32-bit flash drive
    32-bit installation + 64-bit ISO = unable to create the flash drive
    Is that correct?
  7. Posts : 72,058
       #336
    Correct. :)
  8. Posts : 3
    Brink said:
    Correct. :)
    Oh well, thanks.:)
    And question two: in some very early replys, there was a talk about E:\boot\bootsect.exe /nt60 H:
    but I can't see this instruction in the installation steps. Is this instruction a optional or necessary?
  9. Posts : 72,058
       #338
    Yeah, that part was just redundant, so it was removed from the steps in the tutorial.
  10. Posts : 24,479
       #339
    So, that means:
    Is that correct?
    Pardon my dunceness, but my USB stick have no "bitness" that I can tell?
