How to Quickly and Easily Tell if Your Hard Drive is Formatted GPT or MBR
NoteNew PCs are arriving with their hard disks pre-formatted using the GUID Partition Table (GPT) rather than the legacy MBR method.
This tutorial shows you a quick and easy way to determine the file table format.
Here's how:
1. Open Disk Management: Start > Control Panel > Administrative Tools > Computer Management > Disk Management.
2. Right click on the Disk # box
NOTE: The smaller box on the left, with the Disk #, not the larger volume boxes.
3. Select Properties
4. Click the Volumes tab.
5. Next to Partition Style, it will list the format as "Master Boot Record (MBR)" or “GUID Partition Table (GPT)”.
Done!NoteAlso here it lists the small Unallocated and Reserved spaces that Windows requires at the beginning and end of disks for it's housekeeping duties.
- The unallocated space at the end of a hard drive is used by Windows to create (convert Basic to) Dynamic Disks. Any unallocated space at the beginning of of a hard drive is used by Windows in case it needs to manage uncommon partition structures.
- The MSR partition is required for UEFI systems.
