The
Enable forced button/lid shutdown setting is to have a forced shudown (set to On) or normal shutdown (set to Off) of the computer when the system "power button" is pressed or "lid closed" if their action is set to
Shut down.
This tutorial will show you how to add or remove the
Enable forced button/lid shutdown setting under
Power buttons and lid in the
advanced power settings of all power plans for all users in
Vista,
Windows 7, and
Windows 8.
You must be logged in as an
administrator to be able to do this tutorial.
