Windows 7: System Image - Extract Files Using Disk Management
20 Jun 2012   #70
Brink
64-bit Windows 10 Pro
Quote   Quote: Originally Posted by bthrash18 View Post
I have mounted the VHD in Computer Management, and the J:/ drive mounts, but whenever I open the drive it doesn't appear to have any files in it. I do believe I chose the correct VHD (231 GB) and I'm not sure how else to do it. There are vital files on this image and I've done all the research I can, but they all seem to stop at the mounting of the new drive.
Any help would be greatly appreciated,
╚Brandon╝
Brandon,
Could you post a screenshot showing the contents of the location below to see if maybe what the issue may be or if there is another VHD that should have been used instead?
F:\WindowsImageBackup\Computer-Name\Backup Year-######
08 Nov 2012   #71
boetiejon
Windows 7 Professional
Hi Brink
Thanks great tut! Proplem is it does not work for me. I get the same message as Richard earlier: "The requested operation could not be completed due to a file system limitation". I've got enough disk space. The image is spanned over 4 disks. I've also opened all folders to see that all are allowed. Any other suggestion?
Isn't there a way to merge the four disks to one vhd file?
08 Nov 2012   #72
Brink
Hello boetiejon, and welcome to Seven Forums.
Ah, yep that would be the issue. It needs to be a single VHD file. I'm afraid that I don't know if they can be merged or not as a VHD.
17 Apr 2013   #73
Kaktussoft
Nice tutorial and very handy.
7. Click on OK. (See screenshot below)
NOTE: Be sure to leave the Read only box unchecked.
Why not readonly? you only want to mount it and READ files from it.
17 Apr 2013   #74
Brink
Hey Ron,
Only in case one may want more than read-only access.
21 Jun 2013   #75
frsgalaxy
Windows 7 Professional Service Pack 1 (build 7601)
Hey there Brink,
Was just posting to see if you can help? I had a few problems with my laptop for the past few days, I don't have an installation disc (was not supplied, Win 7 was already installed).
Today I found a .vhd file (20.5GB in size) in a folder called WindowsImageBackup (I did not create this this, It was already on the computer on a partitioned drive called "LENOVO" (I am assuming the manufacturer placed this partition with the image file on it).
Anyway I followed this tutorial on how to extract the files from the .vhd file and replace any of the files you need to replace on your main drive, Anyway I managed to attach the .vhd file and it appears as attached in the Disc Management menu, but when I try to locate that drive afterwards I can't find it anywhere. Can you provideme with any help as I really need to fix this issue, Everything is extremely unresponsive and internet pages are taking roughly 30 - 40 minutes to load (even though I have 100mb fibre optic connection, It runs at 13mb though ).
21 Jun 2013   #76
Brink
Hello frsgalaxy, and welcome to Seven Forums.
When Disk Management attached the VHD, did it assign it a drive letter to show up in the "Computer" window?
You might also consider doing a system restore at boot using a restore point (if available) dated before this happened to see if it may be able to undo and fix this for you.
Hope this helps for now,
21 Jun 2013   #77
Kaktussoft
Quote   Quote: Originally Posted by frsgalaxy View Post
Hey there Brink,
What do you want to do with that vhd file? You want to do a factory install... so replace your current win7 install with that one?
21 Jun 2013   #78
frsgalaxy
No drive letter was assigned to the .vhd after attaching it (at least not in Start --> Computer) in fact no drive even showed up in that section, It was "only" displayed in disc management.
As for a system restore from boot that is not an option as there is no restore point available according to my laptop at least (even though a restore point is created every week, I'm an Indie Game Dev so I need everything to be safe and secure ).
Kaktussoft
There is no option for a factory reset on my laptop (apparently laptop's don't have them according to my local microsoft engineer or at least my brand of laptop doesn't) but yeah I guess so or just replace all the file's and regi's that are created during setup if at all possible (Don't really fancy paying 199.99 for a copy of windows 7 seem's the laptop only cost me 200, Additionally I can't afford to pay out for one, Damn I need a new computer :-s)
21 Jun 2013   #79
Kaktussoft
Kaktussoft
If you attach the vhd in disk management:
  • Is only 1 partition in vhd?
  • Look in windows explorer. When was vhd file created? Prior to buying laptop... so vhd is made by shop?
  • Assign a drive letter. Just right click in disk management on partition in vhd and assign drive letter P for example
  • In windows explorer: P has folders like windows, users etcetera. So looks like a win7 disk?
Make a new thread for this problem and post url here
ISO - Disk Image File : Extract to the Desktop
Extract an ISO File to the Windows Desktop This suggests an excellent, free program to use and how to extract an ISO / Disk Image File using that program to the Windows desktop, or wherever you like, for use in any number of situations. First you will need to download and then install this...
Tutorials
Disk Management - Post a Screen Capture Image
How to post a proper screen capture image of your Disk Management screen If you are seeking help with Windows 7, you will often be asked to include a screen capture image of your Disk Management screen. A well executed capture of the Disk Management screen means you get accurate advice in the...
Tutorials
System Repair Disk + Image + Backing up files : is it enough?
Hi all, I used the Win 7 Back up & Restore to create a system repair disk plus a system image on an external HD. I'm also backing up my files/documents. Is that enough to do a complete clean re-install of everything in case of a worst-case scenario? Another question for perhaps another...
Backup and Restore
System Restore Points - Manually Extract Files and Folders
How to Extract Files and Folders from System Restore Points in Windows 7 and Vista This will show you how to use a free program System Restore Explorer to be able to mount specific restore points to be able to browse and copy individual files and folders from a mounted restore point back into...
Tutorials
Problem w extracting files from system image. format disk?
After searching for a few hours, I decided to post a new thread. I am trying to extract some specific files from a system image rather than doing a full restore. The WindowsImageBackup is on an external 500gb hard drive. I have followed all directions on how to do this: Computer management...
Backup and Restore
Extract files from backup VHD image
My ST3500418AS 500GB died and took my Windows 7 with it, so I had to do a fresh install to another hard disk. Unfortunately, Backup and Restore cannot see the backup location from my previous install, so I can't get my files back that way. I presume that the VHD file I see in the backup folder...
Backup and Restore
