System Type - 32-bit (x86) or 64-bit (x64)
    How to Tell if Windows 7 is a 32-bit or 64-bit System Type
    This will show you how to tell if you have a 32-bit (x86) or 64-bit (x64) Windows 7 version.
    Here's How:
    1. Press the Windows Key + Pause/Break key.
    A) Go to step 3.
    OR
    2. Open the Start Menu.
    A) Right click on the Computer button and click on Properties. (See screenshot below)
    3. If You Have a 32-bit (x86) Windows 7 System Type
    4. If You Have a 64-bit (x64) Windows 7 System Type
  1. Posts : 1
    window 7
    thank you sir
  2. Posts : 2
    Windows 7 Home Premium(32-bit)
    HOW TO CHANGE 32BIT TO 64 BIT....(NOTE) I HAV WARRENTY PERIOD REMAINS 7 MONTHS.....
  3. Posts : 72,049
    Hello, and welcome to Seven Forums.
    Sorry, but the only way to go from 32-bit to 64 bit Windows 7, or in reverse, is to do a clean install with the one you want to install.
  4. Posts : 759
    Windows 7 Enterprise x64
    You can always edit the "System Type" text, but it won't change your OS platform one iotta...LOL
  5. Posts : 72,049
    LOL, now I suppose that is one workaround.
  6. Posts : 20
    Sorry for bumping. If I do a clean install, can I install Windows 7 Ultimate x64 on my x86 machine?
  7. Posts : 72,049
    Hello Duane,
    Yes, since you have a 64-bit CPU you will be able to. You will also need to make sure that you hae 64-bit drivers available for all of your devices as well to install after Windows 7.
  8. Posts : 20
    I want to install in my old machine. And I think it's a 32-bit CPU.
    2GB RAM.
  9. Posts : 72,049
    If it's a 32-bit CPU, then you will not be able to install 64-bit Windows 7 on it. Plus, with only 2GB of RAM, you would be better off with 32-bit Windows 7 installed on it.
    What's the CPU brand and model number?
