Event Viewer One Click Clear
How to Clear Event Viewer with One Click in Windows
This will show you how to create a command line shortcut that will clear all of the Event Viewer logs in one click.
Here is a batch file that can help you clear the event viewer in one click.
Download
Download this file above..
Unzip on your desktop.
You can use the task scheduler to give it a high priority so you won't get a UAC prompt
See Brink's Tip HERE
Or, just copy this script and paste in notepad and save as Clean Viewer.BAT
Right click, and click on Run as administrator to run the file
@echo off
FOR /F "tokens=1,2*" %%V IN ('bcdedit') DO SET adminTest=%%V
IF (%adminTest%)==(Access) goto noAdmin
for /F "tokens=*" %%G in ('wevtutil.exe el') DO (call :do_clear "%%G")
echo.
echo goto theEnd
:do_clear
echo clearing %1
wevtutil.exe cl %1
goto :eof
:noAdmin
exit
:geek:
Added Virtual PC clean log.
Windows 7 x64 Ultimate SP1I5 875K UnlockedKingston HyperX Genesis DDR3-1600MHz 9-9-9-27...EVGA GeForce GTX 570 HD 732 MHz GPU 1280 MB, ...
Asus
I5 875K Unlocked
P7P55D-E-PRO
Kingston HyperX Genesis DDR3-1600MHz 9-9-9-27 @ 1.65V XMP
EVGA GeForce GTX 570 HD 732 MHz GPU 1280 MB, 152 GB Mem
Onboard Via 1828S
Samsung T240 HD
Dual 1920X1200 1027X768
OCZ Vertex II Extended Sandforce SSD 60 Gig 2X WD Black Caviar 1 terabyte 6GBS Transer Sata 3 Marvell Chip
Corsair Gold fully Modular 80 Plus 850
Coolermaster Half X Full Tower
Noctua NH-U12P
MS
MS
Fast enough
My fridge has a water tap
Very nice!
I clean the Event log because it gets full of error/warning events...
This will shorten the time needed to clean it out!
Thanks!:geek:
Windows 7 SP1 x64Intel E8400 3.0 GHz4x1 Trascend DDR2 800 MhzGainward 8800GT 512 Mb
Windows 7 SP1 x64
Intel E8400 3.0 GHz
Gigabyte EP45-DS3R
Realtek HD Audio 889A
LG L204WS
Intel 520 Series 120Gb SSD (System)
Western Digital 6400AAKS 640Gb (Data)
Cooler Master 650W
Cooler Master Centurion 532
2x 12 cm fans
Logitech Wave
Logitech G5
10 Mbit Cable Flat
NOD32 Smart Security
That's the main reason why I created this script. Microsoft is supposed to re examine the viewer to make it less scary with usless warnings.
Happy to help.
Asus
I5 875K Unlocked
P7P55D-E-PRO
Onboard Via 1828S
Samsung T240 HD
Noctua NH-U12P
MS
MS
Fast enough
Z
Really nice thanks
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
Very nice.:)
Samsung NP530U4B-S02IN
Windows® 8 Pro (64-bit)
Samsung Electronics
1366x768
sucks
Google Chrome (Sync enabled)
Pleasure guys.
There's some very good stuff in this section!!
Asus
I5 875K Unlocked
P7P55D-E-PRO
Onboard Via 1828S
Samsung T240 HD
Noctua NH-U12P
MS
MS
Fast enough
Very useful, thanks heaps Zardoc!!
Windows 7 Ultimate x64AMD Turion(tm) 64 X2 Mobile Technology TL-563GB Nanya PC2-6400 DDR2-SDRAM SO-DIM (400MHz)NVIDIA GeForce Go 7600 256MB GDDR3 SDRAM
HP Touchsmart IQ771.uk
ASUS Pheonix
High Definition Intergrated NVIDIA MCP51
46" Sony Bravia HDTV
1600x1200
1.5TB Samsug
320GB Seagate ST3320820AS - SATA 3Gb/s 8MB
500GB Maxtor Basics STM305003EHD301-RK
↓6.32 Mb/s ↑0.35 Mb/s ↔26ms
BIOS - American Megatrends Inc. 5.07
Ethernet Port - NVIDIA nForce 10/100/1000 Mbps
DVD Drive - TSSTcorp DVDR/RW TS-T632L
My pleasure.
Asus
I5 875K Unlocked
P7P55D-E-PRO
Onboard Via 1828S
Samsung T240 HD
Noctua NH-U12P
MS
MS
Fast enough
Even shorter event clear script...
This is an even shorter script to clear the event logs and will cover new logs as well as the current ones (Don't remember who I got it from, but works fantastically):
View attachment Clear_All_Logs.bat
OR you could also paste the following into a new batch file:
@echo off
echo.
echo Event Logs have been cleared! ^<press any key^>
goto theEnd
:do_clear
echo clearing %1
wevtutil.exe cl %1
goto :eof
:noAdmin
echo You must run this script as an Administrator!
echo ^<press any key^>
:theEnd
pause>NUL
Windows 7 64-bitIntel Core 2 quad (2000MHZ, 4 core)4 GigATI HD4650
HP DV7-2270US
Windows 7 64-bit
HP
4 Gig
ATI HD4650
IDT HD and ATI HD
17" wide laptop and 65" secondary (for 'work' :) )
1600X900
Patriot 64-Gig M28 SSD in bay 1
Seagate ST9500420AS 500 Gig in bay 2(laptop)
HP Laptop
T3
Someone seems to know code better than I do. ;)
Seems to work (I say that because I don't understand the code)
Let's say you don't want to have to press exit key every time. We can modify this way
@echo off
echo.
echo goto theEnd
:do_clear
echo clearing %1
wevtutil.exe cl %1
goto :eof
:noAdmin
exit
Download
Nice. I'll try it a while and check. :)
Asus
I5 875K Unlocked
P7P55D-E-PRO
Onboard Via 1828S
Samsung T240 HD
Noctua NH-U12P
MS
MS
Fast enough
I am logged in as administrator and I keep getting access is denied error when trying to clear out my event logs. Why?
I have tried this script, the command prompt, the event viewer doesn't event have a clear function available. Can anyone help?
Hi and welcome to the forums.​
Even if you are logged in as administrator you must right click the command and choose run as administrator for it to work.​
Asus
I5 875K Unlocked
P7P55D-E-PRO
Onboard Via 1828S
Samsung T240 HD
Noctua NH-U12P
MS
MS
Fast enough
Thanks..!
Windows 7 Ultimate
Windows 7 Ultimate
Wow, Thank's Zardoc, That is a major timesaver!:cool:
Win 10 Pro x64
Intel I5-2500K @3.3GHz
Asrock P67 Extreme4
EVGA GeForce 750 Ti SC 2GB
auria eq2367
250GB Samsung 850 EVO SSD
1TB WD Blue
1TB Hitachi
SeaSonic X 650W 80 Plus Gold
Corsair Obsidian 750D
Logitech Wireless Mouse M310
Wave Broadband ~ 100 dn 5 up
Edge, IE11, Chrome
Laptop specs: HP g7-1365dx /
RAM: Crucial 8Gb (2x4Gb) /
GFX: AMD Radeon HD 6520G /
OS: Windows 10 Pro x64
Pleasure dude.
Give rep if you like.
Asus
I5 875K Unlocked
P7P55D-E-PRO
Onboard Via 1828S
Samsung T240 HD
Noctua NH-U12P
MS
MS
Fast enough
Win 10 Pro x64
Asrock P67 Extreme4
auria eq2367
1TB WD Blue
1TB Hitachi
Edge, IE11, Chrome
Thanks Derek.
Happy you like it.
Asus
I5 875K Unlocked
P7P55D-E-PRO
Onboard Via 1828S
Samsung T240 HD
Noctua NH-U12P
MS
MS
Fast enough
@echo off
echo.
goto theEnd
:do_clear
echo clearing %1
wevtutil.exe cl %1
goto :eof
:noAdmin
:theEnd
pause>NUL
This is way better than the first batch file that was posted!!!! Thanks lightningltd!!!
Win7 x64Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz16GB Dual-ChannelNVIDIA GeForce GTS 450
Dell XPS 8300
Win7 x64
16GB Dual-Channel
Viewsonic VX2753mh-LED 27" HDMI
Thanks Randy, but if you read the whole post, I have a modified one in shorter than that and it does the same job.
Asus
I5 875K Unlocked
P7P55D-E-PRO
Onboard Via 1828S
Samsung T240 HD
Noctua NH-U12P
MS
MS
Fast enough
