Peppermint Live CD/DVD/USB - Create for Emergency Backup
Page 7 of 11 FirstFirst ... 56789 ... LastLast
  1. Posts : 22
    Nevada
       #60
    Okay, I downloaded it.
    Same options?
    Thanks for sticking through with this.
    Attached Thumbnails Attached Thumbnails Peppermint Live CD/DVD/USB - Create for Emergency Backup-capture.png
  2. Posts : 19,383
       #61
    Yes, keep going.
  3. Posts : 22
    Nevada
       #62
    Okay, it's done.
    Now I'm gonna try to boot it.
    EDIT: Okay, I got it to boot.
    But now I'm starting to think it might be because I'm using a different USB.. does it matter which program I use?
  4. Posts : 19,383
       #63
    Nope, as long as you can use the file manager to copy across your critical files, it doesn't matter.
  5. Posts : 22
    Nevada
       #64
    Fantastic! Now, how exactly do I use it...?
  6. Posts : 19,383
       #65
    Youre still trying to copy your critical files to another USB right?
    Follow the steps in the tutorial - they will be similar, but not exactly the same as its Debian. Look at image here:
    http://afb.users.sourceforge.net/debian/
  7. Posts : 22
    Nevada
       #66
    Okay, so I just installed Peppermint onto the new usb for shits and giggles and it actually started working!
    Sorry for all the trouble and thank you for your patience!
    Cheers!
  8. Posts : 19,383
       #67
    OK.
  9. Posts : 22
    Nevada
       #68
    My last question is:
    Is there anyway to just transfer all the files at once?
    EDIT: So I started tranferring the files and I'm starting to get
    "Error Splicing File: Input/Output Error - Cannot Copy"
    On the most random files. I don't see a pattern of any sort.. any ideas?
  10. Posts : 24,479
    Windows 7 Ultimate X64 SP1
       #69
    I put Peppermint 3 on a USB stick using YUMI and ran it form the stick. I have 3 physical drives, OS, Data (Users),and storage.
    The file manager doesn't see the Data drive, only the SSD with OS and the storage drive.
    Does it have to be installed to a HDD?
