Windows 7 - Tutorial Index
Page 1 of 7 123 ... LastLast
    Windows 7 Tutorials
    Quick Reference
    Index
    A - B - C - D - E - F - G - H - I - J - K - L - M - N - O - P - Q - R - S - T - U - V - W - X - Y - Z
    A:
    Abort Shortcut - Create
    How to Create an "Abort" Shortcut in Windows
    About Windows - Open
    How to Open "About Windows" in Windows 7
    Accessories - Cascading Desktop Context Menu
    How to Add a "Accessories" Cascading Desktop Context Menu in Windows 7
    Account Lockout - Audit Policy - Defining
    How to Set an Audit Policy for an Account Lockout in Windows 7 and Windows 8
    Account Lockout - Duration for Locked Out User Accounts
    How to Set Account Lockout Duration for Locked Out User Accounts in Windows 7 and Windows 8
    Account Lockout - Invalid Logon Attempts - Set Threshold
    How to Set Account Lockout Threshold for Invalid Logon Attempts in Windows 7 and Windows 8
    Account Lockout - Invalid Logon Counter - Reset
    How to Set the Reset Account Lockout Counter After Setting in Windows 7 and Windows 8
    Account Lockout - Unlock a Locked Out User Account
    How to Unlock a Locked Out User Account in Windows 7 and Windows 8
    Action Center - Message Settings - Change
    How to Change the Action Center Message Settings in Windows 7
    Action Center Shortcut - Create
    How to Create an "Action Center" Shortcut in Windows 7 and Windows 8
    Activate a Window by Hovering Over it with the Mouse - Enable or Disable
    How to Activate a Window by Hovering Over it with the Mouse Pointer
    Activate Office 2013
    How to Activate Office 2013
    Activate Windows 7 by Phone
    How to Activate Windows 7 by Phone
    Activate Windows 7 Online
    How to Activate Windows 7 Online
    Activation - Uninstall Product Key Number and Deactivate Windows
    How to Uninstall the Product Key Number and Deactivate Vista, Windows 7, or Windows 8
    Active Navigation Folder Icon - Change
    How to Change the Active Navigation Folder Icon in Windows 7
    "Add a Device" Wizard Shortcut - Create
    How to Create a "Add a Device" Shortcut in Windows 7
    Add and Remove Programs
    How to Uninstall or Change a Program in Windows 7
    Add Hardware Wizard Shortcut - Create
    How to Create a "Add Hardware" Wizard Shortcut in Windows 7
    Add Hardware Wizard - Install Driver
    How To Install a Driver in the "Add Hardware" Wizard
    "Add Network Location" Shortcut - Create
    How to Create a "Add Network Location" Shortcut in Windows 7 in Windows 8
    "Add Printer" Wizard - Install Driver
    How to Install a Driver in "Add Printer" Wizard
    Add Printer Wizard Shortcut - Create
    How to Create a "Add Printer" Wizard Shortcut in Windows 7 and Vista
    Additional Clocks - Add
    How to Add Additional Clocks in Windows 7 and Windows 8
    Additional Clocks Shortcut - Create
    How to Create a "Additional Clocks" Shortcut in Windows 7 and Vista
    Administrative Tools - Add or Remove from Start Menu
    How to Add or Remove Administrative Tools in Windows 7 Start Menu
    Administrative Tools - Cascading Desktop Context Menu
    How to Add a "Administrative Tools" Cascading Desktop Context Menu in Windows 7
    Administrative Tools - Restore Shortcuts
    How to Restore the Default Windows 7 Administrative Tools
    Administrative Tools Shortcut - Create
    How to Create a "Administrative Tools" Shortcut in Windows 7
    Administrator Account - Change Name
    How to Rename the Built-in Elevated "Administrator" Account in Windows 7 and Windows 8
    Administrator - Enable from WinRE
    How to Enable the Built-in Elevated "Administrator" Account from WinRE
    Administrator Account - Enable or Disable
    How to Enable or Disable the Built-in Elevated "Administrator" Account in Windows 7
    Administrator Account - Reset to Default
    How to Reset User Profile of Built-in Administrator Account to Default in Windows
    Administrator - Require a Password for UAC
    How to Configure UAC to Require a Password for Administrator
    Administrators - Elevate UAC Privilege Level
    How to Elevate All Administrator Accounts UAC Privilege Level
    Adobe Illustrator CS5 - Splash Screen - Change
    How to Change Adobe Illustrator Start Up Splash Screen
    Advanced Appearance Settings
    How to Change the Window Color and Appearance in Windows 7
    Advanced Appearance Settings - Backup and Restore in Windows
    How to Backup and Restore Advanced Appearance Settings in Windows
    Advanced Boot Options
    How to Boot to the Advanced Boot Options in Windows 7
    Advanced Power Options Shortcut - Create
    How to Create an "Advanced Power Options" Shortcut in Windows 7 and Windows 8
    Advanced Power Plan Settings - Change
    How to Change the Power Plan Settings in Windows 7
    Advanced System Properties - Add to "My Computer" Context Menu
    Add "Advanced System Properties" to "This PC" and "My Computer" Context Menu in Vista, Windows 7, and Windows 8
    Advanced System Properties Shortcut - Create
    Create an "Advanced System Properties" Shortcut in Vista, Windows 7, and Windows 8
    Advanced Tools - Open in Windows 7 and Windows 8
    How to Open Advanced Tools in Windows 7 and Windows 8
    Advanced User Accounts - Add to Control Panel
    How to Add "Advanced User Accounts" to the Control Panel
    Advanced User Accounts Shortcut - Create
    How to Create a Advanced User Accounts Shortcut in Windows 7
    Advanced Window Color and Appearance - Add to Desktop Context Menu
    How to Add or Remove "Advanced Window Color and Appearance" from Desktop Context Menu in Windows 7
    Aero Borders - Emulate
    How to Emulate Aero Borders
    Aero - Enable in Unsupported Editions of Windows 7
    How to Enable Aero in Unsupported Editions of Windows 7
    Aero Glass Transparency - Enable Full Clear Glass Transparency
    How to Enable Full Clear Glass Transparency in Windows 7
    Aero Glass Transparency - Enable or Disable
    How to Enable or Disable Windows 7 Transparency
    Aero Peek - Change Delay Time to Preview Desktop
    How to Change the Windows 7 Aero Peek Mouse Hover Delay Time to Preview Desktop
    Aero Peek - Turn On or Off
    How to Turn Aero Peek On or Off in Windows 7
    Aero Shake - Clear Desktop by Shaking a Window
    How to Clear the Desktop with Aero Shake in Windows 7 and Windows 8
    Aero Shake - Enable or Disable
    How to Enable or Disable Aero Shake in Windows 7 and Windows 8
    Aero - Slow Motion Effect - Enable
    How to Enable Slow Motion Effect with Aero in Windows
    Aero Snap a Window to a Side
    How to Use Aero Snap to Snap a Window to a Screen Side in Windows 7
    Aero Snap - Maximize and Restore Down a Window by Drag and Drop
    How to Use Aero Snap to Maximize and Restore Down a Window in Windows 7
    Aero Snap - Turn On or Off
    How to Turn Aero Snap and Aero Shake On or Off in Windows 7
    Aero Transparency - Enable or Disable
    Aero Troubleshoot Shortcut - Create
    How to Create a "Aero Troubleshoot" Shortcut in Windows 7
    Affinity - Add Set CPU Affinity to Context Menu
    How to Add or Remove "Run with CPU-# Affinity" to the Context Menu
    Affinity - Set for Applications
    How to Set Processor Affinity to an Application in Windows 7
    AHCI - Enable in Windows 7 and Vista
    How to Enable AHCI in Windows after Installation
    AHCI Link Power Management - Enable HIPM and DIPM
    How to Enable HIPM and DIPM for your SSD and HDD in Windows 7 and Windows 8
    ALT Key Codes for Special Characters List
    How to Type Special Characters with ALT Keyboard Sequences
    ALT+TAB - Press to Use Classic Icons or Default Thumbnails
    How to Use Classic Icons or Thumbnail Previews with ALT+TAB Keyboard Shortcut
    "Always use selected program" - Add or Remove in Open with
    How to Add or Remove "Always use selected program" in Open with
    "Always use selected program" - Always Checked or Unchecked
    How to Have "Always use selected program" Always Checked or Unchecked in "Open with"
    AMD CrossfireX - Disable ULPS (Ultra Low Power State)
    How to Disable ULPS (Ultra Low Power State) for Graphics Cards in AMD CrossfireX
    AMD Graphics Drivers - Install Without Catalyst Install Manager
    How to Install AMD Graphics Drivers Without Installing Catalyst Install Manager
    AMD/NVIDIA Video Card - Test with OCCT
    How to Test NVIDIA/AMD Performance with OCCT
    Android Phone or Tablet - Add to Homegroup
    How to Add an Android Phone or Tablet to a Homegroup in Windows 7 and Windows 8
    Animate controls and elements inside windows - On or Off
    How to Turn On or Off "Animate controls and elements inside windows"
    Animate Windows when Minimizing and Maximizing
    How to "Animate windows when minimizing and maximizing" in Vista, Windows 7, and Windows 8
    Animations in a Window - Allow or Prevent
    How to Allow or Prevent Window Animations in Windows 7
    Animations in the Taskbar and Start Menu - Enable or Disable
    How to Enable or Disable Animations in the Taskbar and Start Menu of Windows 7
    Animations - Turn off all unnecessary animations
    How to "Turn off all unnecessary animations" in Windows 7 and Vista
    Antivirus Program Uninstallers
    A List of Antivirus Program Uninstallers
    Anytime Upgrade - Enable or Disable
    How to Enable or Disable Windows Anytime Upgrade in Windows 7
    Anytime Upgrade - How to
    How to do a Windows Anytime Upgrade in Windows 7
    Continued on next post......
  1. Posts : 72,050
    Windows 7 Tutorial Index - A (2 of 2)
    A:
    App Passwords in your Microsoft Account - Create or Remove
    Create or Remove App Passwords in your Microsoft Account when Two-Step Verification is Turned On
    Application - Add to "Open with"
    How to Add a Program to "Open with" in Windows 7
    Application - Clean Up and Remove in Open with
    How to Clean Up and Remove Programs from the "Open with" Context Menu
    Application - Create Elevated Shortcut for without UAC Prompt
    How to Create a Elevated Program Shortcut without a UAC Prompt
    Application - Create Task to Run a Program at Startup and Log On
    How to Create a Task to Run a Program at Startup and Log On in Windows 7
    Application - Create Terminate Non-responding Application Shortcut
    How to Create a shortcut to Terminate a Non-responding Application in Windows 7
    Application - Disable Desktop Composition
    How to Disable Desktop Composition for a Program
    Application, File, or Folder - Create Shortcut Of
    How to Create a Shortcut of a File, Folder, Drive, or Program in Windows 7
    Application "Open" Toolbar and Context Menu Icon - Fix
    How to Fix the Windows Explorer "Open" Application Toolbar and Context Menu Icon in Windows 7
    Application - Pin Invisible Icon to Taskbar
    How to "Pin to Taskbar" Transparent Invisible Icons for Programs in Windows 7
    Application - Pin or Unpin to Start Menu
    How to Pin or Unpin a Program to the Windows 7 Start Menu
    Application - Pin or Unpin to Taskbar
    How to Pin or Unpin a Program to the Windows 7 Taskbar
    Application - Remove a Listed Program in Default Programs
    How to Remove a Listed Program in Default Programs for Windows 7 and Vista
    Application - Run as Different User Shortcut - Create for Specified Program and User
    How to Create a Shortcut to Run a Program as a Specified User
    Application - Run in Compatibility Mode
    How to Run a Program in Compatibility Mode in Windows 7
    Application - Set a Program's Default Associations in Default Programs
    How to Set Default Associations for a Program in Windows 7
    Applications and Documents - Run at User Logon
    How to Run Specific Programs and Documents at User Logon in Windows 7 and Vista
    Applications and Processes - Set Priority Level
    How to Set Priority Level for Applications and Processes in Windows 7
    Applications - Create "Install Program from Network" Shortcut
    How to Create a "Install Program from Network Shortcut" in Windows 7
    Applications - Pin to Taskbar - Enable or Disable
    How to Enable or Disable Windows 7 Taskbar Pinned Programs
    Applications - Prevent Running Specified Programs
    How to Prevent Users from Running Specified Programs in Windows
    Applications - Run Only Specified Programs in Windows
    How to Allow Users to Run Only Specified Programs in Windows
    Applications - Set Processor Affinity
    Applications - Start Multiple at Once Using a BAT File
    How to Use a Batch File to Run Multiple Programs
    Applications - Uninstall with Revo Uninstaller Freeware
    How to Uninstall Programs and their Leftovers using Revo Uninstaller Freeware
    AppLocker - Create New Rules
    How to Create New Rules in AppLocker in Windows 7 and Windows 8
    AppLocker - Enable DLL Rule Collection
    How to Enable DLL Rule Collection in AppLocker in Windows 7 and Windows 8
    "Apply to Folders" - Folder Views
    How to "Apply to Folders" a Specific Folder View to All Folders with the Same Folder Template in Windows 7
    Arrange by - Sort by - Group by - Change File and Folder View Arrangement
    How to Change the Group by, Sort by, and Arrange by Folder View in Windows 7 Explorer
    Audio CDs - Rip with Windows Media Player 12
    How to Rip Audio CDs using Windows Media Player 12
    Audio Device - Enable Hidden Devices
    How to Enable Hidden Audio Devices in Vista and Windows 7
    Audio or Video Files - Convert with Format Factory
    Audit (log) Access to Shared Folders
    How to Audit User Access to Shared Folders on Your Computer
    Audit Mode - How to Create a General System Image for New Installation
    Create a System Image with your software installed but without any user accounts or activation information
    Audit Mode with Sysprep - Customize Windows 7 Image
    How to Create, Customize, and Maintain Windows 7 Image in Audit Mode with Sysprep Tool
    Aurora Screen Saver - Change Settings
    How to Change "Aurora Screen Saver Settings" in Windows 7 and Windows 8
    Aurora Screen Saver - Restore
    How to Restore "Aurora Screen Saver" Back in Windows 7 and Windows 8
    Auto Arrange - Disable in Windows Explorer
    How to Disable Auto Arrange in Windows 7 Explorer to have Free Sorting
    AUTOCHK Initiation Countdown Time - Change
    How to Change AUTOCHK Initiation Countdown Time in Windows 7 and Windows 8
    AutoComplete - Turn On or Off in Internet Explorer
    How to Turn AutoComplete On or Off in Internet Explorer
    AutoComplete - Turn On or Off in Windows Explorer
    How to Turn AutoComplete On or Off in Windows Explorer
    AutoEndTask Apps Not Responding at Shutdown in Windows
    How to Turn On or Off to Automatically Close Apps not Responding at Shutdown in Windows
    Automatic Folder Type Discovery - Enable or Disable
    How to Set a Default Folder Template for All Folders in Windows 7
    Automatic Logon at Startup
    How to Automatically Log On a User Account at Windows 7 Startup
    Automatic Logon at Startup - Bypass in Windows
    How to Temporarily Bypass Automatic Logon at Startup in Windows
    AutoPlay - Enable or Disable for Drives
    How to Enable or Disable AutoPlay for Drives in Vista, Widows 7, and Windows 8
    AutoPlay - Enable or Disable for Non-volume Devices
    Enable or Disable AutoPlay for Non-volume Devices in Windows 7 and Windows 8
    AutoPlay - Enable or Disable Remembering User Choices
    Enable or Disable AutoPlay Remembering User Choices in Vista, Windows 7, and Windows 8
    AutoPlay Shortcut - Create
    How to Create a "AutoPlay" Shortcut in Windows 7
    AutoPlay - Turn On or Off
    How to Turn AutoPlay On or Off in Windows 7
    Autorun.inf Files - Completely Block and Disable
    How to Completely Block and Disable Autorun.inf Files in Windows
    Auto Suggest - Delete Typed Paths in Windows Explorer
    How to Delete Typed Paths in Windows Explorer Auto Suggest Drop Down List
    Auto Suggest - Delete Typed URLs in Internet Explorer
    How to Delete Typed URLs in Internet Explorer Auto Suggest Drop Down List
    Auto Suggest - Turn On or Off in Windows Explorer
    How to Turn Auto Suggest On or Off in Windows Explorer
    Avast - Uninstall Completely
    How to Completely Uninstall Avast Antivirus
    AVCHD Disc - How to Create
    How to Create a HD AVCHD DVD
    AVG - Uninstall Completely
    How to Completely Uninstall AVG
  2. Posts : 72,050
    Windows 7 Tutorial Index - B (1 of 2)
    B:
    Background Images Remove (where available)
    How to Remove Background Images to have Only Solid Colors (Black screen) in Windows 7
    Backup and Restore Shortcut - Create
    How to Create a Windows 7 "Backup and Restore" Shortcut
    Backup Complete Computer - Create a System Image Backup
    How to Create a System Image Backup in Windows 7
    Backup - Delete User and System Files Backups
    How to Delete Windows 7 User and System Backup Files
    Backup Error 0x81000019 - Fix
    How to Fix Backup Error 0x81000019 in Windows 7
    Backup Files - Enable or Disable Restoring
    How to Enable or Disable Restoring Backup Files in Windows 7
    Backup Files - in Windows Recovery Console
    How to Copy & Paste in Recovery Console on Windows 7 or Vista
    Backup Files Schedule - Turn On or Off
    How to Turn the Windows 7 Backup Files Schedule On or Off
    Backup - Make a "Create Incremental Backup" Shortcut
    How to Make a "Create Incremental Backup" Shortcut in Vista, Windows 7, and Windows 8
    Backup - Make a "Create New Backup" Shortcut
    How to Make a "Create New Backup" Shortcut in Vista, Windows 7, and Windows 8
    Backup - Manually Extract Files from Backup in Vista and Windows 7
    How to Manually Extract Files from a Backup in Vista and Windows 7
    Backup - Restore Files from Selected Backup Location - Create Shortcut
    How to Create a "Restore Files from Selected Backup Location" Shortcut
    Backup - Restore User and System Files - Enable or Disable
    Back up to CD or DVD - Enable or Disable
    How to Enable or Disable Backing up to a CD or DVD in Windows 7 and Windows 8
    Back up to Local Hard Disks - Enable or Disable
    How to Enable or Disable Backing up to Local Hard Disks in Windows 7 and Windows 8
    Back up to Network Location - Enable or Disable
    How to Enable or Disable Backing up to a Network Location in Windows 7 and Windows 8
    Backup User and System Data Files - Enable or Disable
    How to Enable or Disable to Backup Data Files in Windows 7
    Backup User and System Files
    How to Backup User and System Files in Windows 7
    Backup User and System Files - Create Shortcut
    How to Create a Windows 7 "Backup User and System Files" Shortcut
    Backup User and System Files - Create Restore Shortcut
    How to Create a Windows 7 "Restore Backup User and System Files" Shortcut
    Backup User and System Files - Delete Backups
    How to Delete Windows 7 User Data and System Image Backup Files
    Backup User and System Files - Reset to Default Configuration
    How to Reset Windows Backup Files Configuration in Windows 7 and Windows 8
    Backup User and System Files - Restore
    How to Restore Backup User and System Files in Windows 7
    Balloon Notifications - Enable or Disable
    How to Enable or Disable Balloon Notifications in Vista, Windows 7, and Windows 8
    Basic Disk to a Dynamic Disk
    How to Convert a Basic Disk to a Dynamic Disk
    BAT Files - Add "Open with" to Context Menu
    How to Add "Open with" to Context Menu of BAT Files in Windows 7 and Vista
    Batch File - Add to "New" Context Menu
    How to Add "New Batch File" to the Context Menu in Windows
    Batch Files - Create a Menu to Execute Commands
    How to Use a Batch File to Create a Command Prompt Menu to Execute Commands
    Batch Files - Start Multiple Programs At Once
    Battery - Change Notification, Level, and Action Settings in Windows
    How to Change Low and Critical Battery Notification, Level, and Action Settings in Windows 7, Windows 8, and Windows 10
    BCD (Boot Configuration Data) Store - Backup and Restore in Windows
    How to Backup and Restore Boot Configuration Data (BCD) Store in Windows
    BCDEDIT - How to Use
    How to Use the BCDEDIT Command Line Tool
    Bing Desktop - Enable or Disable to Run at Windows Startup
    How to Turn On or Off Bing Desktop to Run at Windows Startup
    Bing Desktop - Set Homepage Image as Desktop Background in Windows 7
    How to Set or Unset Bing Homepage Image in Bing Desktop as Desktop Background in Windows 7
    Bing Desktop Wallpaper Toolset - Turn On or Off in Windows
    How to Turn On or Off Bing Desktop Wallpaper Toolset in Windows
    Biometric Devices Shortcut - Create
    How to Create a "Biometric Devices" Shortcut in Windows 7
    BIOS and UEFI Firmware Version - Find in Windows
    How to Find the BIOS and UEFI Firmware Version in Windows
    BIOS Mode - See if Windows Boot in UEFI or Legacy Mode
    How to Check if Windows is Booted in UEFI or Legacy BIOS Mode
    BitLocker - Add Suspend BitLocker protection to Context Menu in Windows
    How to Add 'Suspend BitLocker protection' to Context Menu of Drives in Windows
    BitLocker Drive Encryption - Change Encryption Method and Cipher Strength
    How to Change Windows 7 BitLocker Drive Encryption Method and Cipher Strength
    BitLocker Drive Encryption - BitLocker To Go - Turn On or Off
    How to Turn Windows 7 BitLocker To Go On or Off for Removable Drives
    BitLocker Drive Encryption - Internal Data Hard Drives - Turn On or Off
    How to Turn Windows 7 BitLocker On or Off for Internal Data Hard Drives
    BitLocker Drive Encryption Shortcut - Create
    How to Create a Windows 7 "BitLocker Drive Encryption" Shortcut
    BitLocker Drive Encryption - Suspend or Resume Protection on Windows 7 Drive
    How to Suspend or Resume BitLocker Protection on Windows 7 Drive
    BitLocker Drive Encryption - Unlock a Locked Data or Removable Drive
    How to Unlock a Data or Removable Drive Locked by BitLocker Drive Encryption
    BitLocker Drive Encryption - Unlock a Locked OS Drive
    How to Unlock a Windows 7 Computer Locked by BitLocker Drive Encryption
    BitLocker Drive Encryption - Windows 7 Drive - Turn On or Off with no TPM
    How to Turn BitLocker On or Off without a TPM for Windows 7 Drive
    Bitlocker - Lock an Unlocked Drive
    How to Lock an Unlocked BitLocker Drive
    BitLocker - "Lock Drive" - Add to Context Menu of Encrypted Drives
    Add "Lock Drive" to Unlocked BitLocker Drives Context Menu in Windows 7 and Windows 8
    BitLocker Repair Tool - Recover Drive in Windows 7 and 8
    How to Use BitLocker Repair Tool to Recover a Drive in Windows 7 and Windows 8
    BitLocker Status - Check for Drive in Windows
    How to Check BitLocker Status of Drive in Windows 7 and Windows 8
    Blocked Files - Disable Downloaded Files from being Blocked in Windows
    How to Disable Downloaded Files from being Blocked in Windows
  3. Posts : 72,050
    Windows 7 Tutorial Index - B (2 of 2)
    B:
    Bluetooth Devices Shortcut - Create
    How to Create a "Bluetooth Devices" Shortcut in Windows 7
    Bluetooth File Transfer Shortcut - Create in Windows
    How to Create a "Bluetooth File Transfer" Shortcut in Vista, Windows 7, and Windows 8
    Bluetooth Notification Area Icon - Turn On or Off in Windows
    How to Turn On or Off Bluetooth Notification Area Icon in Windows
    Bluetooth Settings Shortcut - Create in Windows
    How to Create a "Bluetooth Settings" Shortcut in Vista, Windows 7, and Windows 8
    Boot Animation GUI - Enable or Disable in Windows
    How to Enable or Disable "GUI Boot" in Windows
    Boot Configuration Data (BCD) Store - Backup and Restore in Windows
    Boot - Create and Start VHD File at Boot
    How to Create a Windows 7 VHD at Boot to Start with from Boot
    Boot Failure - Troubleshooting in Windows 7
    Boot from a VHD File Using Windows 7
    How to Setup Windows 7 to Boot from a VHD (Virtual Hard Disk)
    Boot from ISO without Burning to Disk
    How to Make Windows Boot Manager Boot an ISO from your Hard Drive
    Boot Information
    How to See Vista or Windows 7 Boot Information at Startup
    Boot Log - Enable or Disable in Windows
    How to Enable or Disable the Boot Log in Windows
    Boot Manager - Change Default Operating System to Run at Startup
    How to Change the Default Operating System to Start in Windows 7
    Boot Manager - Change Display Time to List OS
    How to Change the Amount of Time to Display Operating Systems at Boot in Windows 7
    Boot Manager - Change Listed OS Arrangement Order
    How to Change the Listed OS Arrangement Order in Windows Boot Manager Screen
    Boot Manager - Change OS Name
    How to Change the OS Name in Windows Boot Manager
    Boot Manager - Delete a Listed Operating System
    How to Delete an Operating System Listed in Windows Boot Manager
    Boot Manager Screen - Add "Safe Mode" in Windows 7
    How to Add Windows 7 "Safe Mode" to Windows Boot Manager Screen
    Boot Manager Screen - Add "Safe Mode with Command Prompt" in Windows 7
    How to Add Windows 7 "Safe Mode with Command Prompt" to Windows Boot Manager Screen
    Boot Manager Screen - Add "Safe Mode with Networking" in Windows 7
    How to Add Windows 7 "Safe Mode with Networking" to Windows Boot Manager Screen
    Boot - Open a Command Prompt
    How to Open a Command Prompt at Boot in Windows 7
    Boot Times - Monitor with Event Viewer
    How to Monitor Boot Times in Event Viewer
    Bootable ISO - Create from Installation Files
    How to Create a Bootable ISO from Windows 7 Installation Files
    Bootable ISO - Create from an Older ISO
    How to Create a Bootable ISO from an Older ISO
    BootMGR Compressed Message at Boot Fix
    How to Fix the BootMGR is Compressed Message at Boot
    Bootmgr is missing - Fix
    How to Fix the "Bootmgr is missing" Error in Windows
    Bootmgr - Move to C:\ with EasyBCD
    Bootrec.exe Tool - Use in Windows Recovery Environment
    How to Use the Bootrec.exe Tool in Windows Recovery Environment
    Borders - Changing Width of Windows
    How to Change the Width of Window Borders
    Browse For Folders Dialog Boxes - Reset Size in Windows
    How to Reset Browse For Folders type Dialog Boxes to Default Size in Windows
    Browser Cache File Storage - Use RAM Disk
    How to Install a RAM Disk for Browser Cache File Storage
    BSOD Commands - WinDbg
    Command and Extensions for WinDbg
    BSOD - Configure Windows to Create Dump File
    How to Configure Windows to Create a Dump File when you get a BSOD
    BSOD Crash on Ctrl+Scroll Lock - Enable or Disable in Windows
    How to Enable or Disable BSOD Crash on Ctrl+Scroll Lock in Windows
    Bubbles Screen Saver - Change Settings
    How to Change the Bubbles Screen Saver Settings in Windows 7 and Windows 8
    Built-in Administrator Account - Change Name
    How to Rename the Windows 7 Built-in Elevated "Administrator" Account
    Built-in Administrator - Enable from WinRE
    Built-in Administrator Account - Enable or Disable
    Built-in Administrator Account - Reset to Default
    Burn Disc Image - ISO or IMG file to CD/DVD
    How to Burn a "ISO" or "IMF" Disc Image file to a CD/DVD in Windows 7 and Windows 8
    Burning to CD and DVD - Enable or Disable
    How to Enable or Disable Built-in CD and DVD Burning Features in Windows 7 and Windows 8
    Buttons and Windows Visual Styles- Turn On or Off
    How to Turn "Use visual styles on windows and buttons" On or Off
  4. Posts : 72,050
    Windows 7 Tutorial Index - C (1 of 4)
    C:
    CachedLogonsCount
    How to Change the Number of Domain Logon Cache Entries Saved in Windows
    Calculator - Change Modes
    How to Open and Change Calculator View in Windows 7
    Calendar from Vista - Import into Windows 7
    How to Import Windows Calendar from Vista into Windows 7
    Camera and Scanner Installation Wizard
    How to Open and Use the Windows 7 Scanner and Camera Installation Wizard
    Cameras and Scanners Shortcut - Create
    How to Create a "Scanners and Cameras" Shortcut in Windows 7
    Caps Lock - Num Lock - Scroll Lock - Enable or Disable at Windows Startup
    How to Enable or Disable a Toggle Key at Startup in Vista, Windows 7, and Windows 8
    CardSpace Shortcut - Create
    How to Create a "Windows CardSpace" Shortcut in Windows 7
    Caret Browsing - Restore Confirmation Prompt
    How to Restore the Caret Browsing Confirmation Prompt
    Caret Browsing - Turn On or Off
    How to Turn Caret Browsing On or Off within Webpages
    Case Power Button - Customize
    How to Customize your Case Power Button Settings
    Catalyst Control Center - Add or Remove from Desktop Context Menu
    How to Add or Remove "Catalyst Control Center" from Desktop Context Menu
    Catalyst Control Center Notification Icon - Add or Remove
    Add or Remove Catalyst Control Center Taskbar Notification Area Icon in Windows
    CCleaner - Delete Junk Files
    How to Use CCleaner to Clean Out Junk Files in Windows
    CD/DVD Tray - Eject and Close - Add to Desktop Context Menu
    How to Add "Eject/Close CD/DVD Tray" to the Context Menu in Windows
    CD and DVD Drive Burning Features - Enable or Disable
    CD and DVD Drive - Read and Write Access - Allow or Deny
    How to Deny or Allow Read and Write Access to CD and DVD Drives in Vista and Windows 7
    CD and DVD Drive - "You have files waiting to be burned to disc" - Stop Message
    How to Stop "You have files waiting to be burned to disc" Message in Windows
    Character Map
    How to Open and Use Character Map in Vista, Windows 7, and Windows 8
    Check Boxes - Select Items in Windows Explorer With
    How to Select Items with Check Boxes in Windows 7
    Check Disk (chkdsk)
    How to Run Check Disk in Windows 7
    Check Disk AUTOCHK Initiation Countdown Time - Change
    Check Disk (chkdsk) - Read Event Viewer Log
    How to Read the Event Viewer Log for Check Disk (chkdsk) in Vista, Windows 7, and Windows 8
    Check Disk - Reset
    How to Reset Check Disk to Not Run at Startup
    Chrome and Firefox - Display Internet Explorer Only Websites
    How to Display IE-only Pages in Firefox and Chrome
    Chrome App Launcher Menu - Pin to Taskbar in Windows
    How to Pin Chrome App Launcher to Windows Taskbar
    Chrome - Add Extensions
    How to Add Extensions to Google Chrome Browser
    Chrome - Applying a Theme
    How to Apply a Theme to your Google Chrome Browser
    Chrome - Change Default Download Location
    How to Change the Default Download Location in Google Chrome
    Chrome - DownTheMall Alternative
    How to Get a DownTheMall Alternative for Google Chrome
    Chrome Home Button - Hide or Show in Windows
    How to Hide or Show Home Button in Google Chrome for Windows
    Chrome Homepage - Change in Windows
    How to Change Homepage in Google Chrome for Windows
    Chrome - Import and Export Bookmarks
    How to Import and Export Bookmarks in Google Chrome Browser
    Chrome - Import Favorites from Internet Explorer
    How to Import Internet Explorer Favorites into Google Chrome Browser
    Chrome Prerendering - Enable or Disable
    How to Enable or Disable Prerendering in Google Chrome Browser
    Chrome Proxy Settings - Change to Speed Up
    How to Speed Up Google Chrome with Proxy Settings
    Chrome - Reopen Last Browsing Session
    How to Reopen the Last Browsing Session in Google Chrome Browser
    Chrome - Reset Theme to Default
    How to Reset to Default Theme in Google Chrome Browser
    Chrome - Reset to Default
    How to Reset Google Chrome Browser to Default
    Chrome Startup Page - Change in Windows
    How to Change Startup Page in Google Chrome for Windows
    Chrome - Turn Bookmarks Bar On or Off
    How to Turn the Bookmarks Bar On or Off in Google Chrome
    ChromeCast - Setup and use
    How to Setup and Use Google ChromeCast
    Chrome GPU Hardware Acceleration - Turn On or Off
    How to Turn GPU "Hardware Acceleration" On or Off in Chrome
    Google Chrome Website Notifications - Allow or Block in Windows
    How to Allow or Block Website Notifications in Google Chrome in Windows 7, Windows 8, and Windows 10
    Cipher Command - Overwrite Deleted Data in Windows
    How to Overwrite Deleted Data using the "Cipher" Command in Windows
    "Clean" and "Clean All" a Hard Disk with Diskpart Command
    How to "Clean" or "Clean All" a Disk with the Diskpart Command
    Clean Install : Factory COA Activation Key
    Clean Install Windows 7 to Remove Factory Bloatware
    How to Do a Clean Installation with Windows 7
    Clean Install Windows 7 : Ahead of Vista
    How to Install Windows 7 to a Partition Ahead of Installed Vista
    Clean Install Windows 7 : Ahead of XP
    How to Install Windows 7 to a Partition Ahead of Installed XP
    Clean Install Windows 10 Directly without having to Upgrade First
    How to Directly Clean Install Windows 10 without having to Upgrade First
    Clean Install Windows 7 from the Windows 7 Desktop
    How to Do a Clean Install of Windows 7 from the Windows 7 Desktop
    Clean Install Windows 7 from the Windows XP Desktop
    How to Do a Clean Install of Windows 7 from the Windows XP Desktop
    Clean Install Windows on MSATA (SSD) Drive
    How to Clean Install Windows on a MSATA (SSD) Drive
    Clean Install Windows on System with MSATA and ISRT
    How to Clean Install Windows on System with MSATA and ISRT
    Clean Install Windows 7 with UEFI (Unified Extensible Firmware Interface)
    How to Install Windows 7 Using "Unified Extensible Firmware Interface" (UEFI)
    Clean Install with an Upgrade Windows 7 Version
    How to Do a Clean Install with an Upgrade Windows 7 Version
    Clean Reinstall - Factory OEM Windows 7
    How to Clean Install an OEM Windows 7
    Clean Startup - Perform to Troubleshoot Application Conflicts
    How to Troubleshoot a Problem by Performing a Clean Startup in Windows 7 or Vista
    Clean Up Factory Bloatware
    Clear Clipboard - Add to Context Menu in Windows
    How to Add "Clear Clipboard" to the Context Menu in Windows
    Clear Clipboard Shortcut - Create in Windows
    How to Create a "Clear Clipboard" Shortcut in Windows
    Clear Recent Items and Documents on Exit of Windows 7
    How to Clear Recent Items and Documents on Exit of Windows 7
    ClearType Text Tuner
    How to Open and Use ClearType Text Tuner in Windows 7 and Windows 8
    CLFS transaction logs - Reset
    How to Reset the Common Log File System (CLFS) Logs
    Clicking Sound while Browsing Internet Explorer and Windows Explorer - Turn On or Off
    How to Change or Turn On or Off the Clicking Sound while Browsing Internet and Windows Explorer
    ClickLock - Change Time before Click is Locked
    How to Change the ClickLock Time Until Click is Locked in Windows 7
    ClickLock - Turn On or Off
    How to Turn ClickLock On or Off in Windows 7
    Clock - Add Additional Clocks
    CLSID Key (GUID) Shortcuts List for Windows 7
    Color and Appearance - Add to Control Panel in Windows
    How to Add Color and Appearance to Control Panel in Windows
    Color and Appearance - Change
    Color and Appearance - Enable or Disable Change
    How to Enable or Disable Changing Window Color and Appearance in Windows 7
    Color and Appearance Shortcut - Create
    How to Create a "Window Color and Appearance" Shortcut
    Color Bit Depth - Display Settings
    How to Change the Color Bit Depth in Windows 7
    Color Calibration
    How to Open and Use Display Color Calibration in Windows 7
    Color Management Shortcut - Create
    How to Create a "Color Management" Shortcut in Windows 7
    Columns in Windows Explorer - Add or Remove
    How to Add or Remove Windows Explorer Columns
    Columns in Windows Explorer - Change Width
    How to Change the Width of Columns in Windows Explorer
  5. Posts : 72,050
    Windows 7 Tutorial Index - C (2 of 4)
    C:
    Command Bar Buttons in Windows Explorer - Customize
    How to Add, Remove, or Rearrange Windows Explorer Toolbar Buttons in Windows 7
    Command Prompt
    How to Open a Command Prompt in Windows 7
    Command Prompt Colors - Customize in Windows
    How to Customize Command Prompt Colors in Windows 7, Windows 8, and Windows 10
    Command Prompt - Delete File
    How to Delete a File in Windows from the Command Prompt
    Command Prompt - Delete Folder
    How to Delete a Folder in Windows from the Command Prompt
    Command Prompt - Elevated
    How to Open a Elevated Command Prompt in Windows 7
    Command Prompt - Elevated Shortcut
    How to Create an Elevated Command Prompt Shortcut in Windows 7 and Windows 8
    Command Prompt - Enable Copy to Clipboard
    How to Enable Copy to Clipboard from the Windows 7 Command Prompt
    Command Prompt - Enable or Disable
    How to Enable or Disable the Command Prompt in Vista and Windows 7
    Command Prompt Font and Font Size - Change in Windows
    How to Change Command Prompt Font and Font Size in Windows 7, Windows 8, and Windows 10
    Command Prompt - Open at Startup
    Command Prompt - Personalize
    How to Personalize the Command Prompt Window
    Command Prompt QuickEdit Mode - Turn On or Off
    How to Turn On or Off Command Prompt QuickEdit Mode in Windows
    Command Prompt - Rename File and Folder
    How to Rename a File and Folder from the Command Prompt
    Command Prompt - Restore Default Personalization Settings
    How to Restore Command Prompt Default Personalization Settings in Windows
    Command Prompt Screen Buffer Size - Change in Windows
    How to Change Command Prompt Screen Buffer Size in Windows 7, Windows 8, and Windows 10
    Command Prompt - Uninstall Programs in Windows
    How to Uninstall Programs using Command Prompt in Windows
    Command Prompt Window Position - Customize in Windows
    How to Customize Command Prompt Window Position in Windows 7, Windows 8, and Windows 10
    Commands in Windows 7
    A List of Command Prompt Commands Used in Windows 7
    Common File Dialog Box - Customize Places Bar
    How to Customize Common Open File Dialog Box Places Bar in Windows
    Common Dialog Boxes - Clear Dropdown List of Recent Files History
    How to Reset and Clear Common Dialog Boxes Dropdown List of Recent Files History
    Common Dialog Boxes - Enable or Disable Dropdown List of Recent Files
    How to Enable or Disable Common Dialog Boxes Dropdown List of Recent Files
    Common Item Dialog Boxes for Open and Save As - Reset in Windows
    How to Reset Open and Save As Common Item Dialog Boxes to Default in Windows
    Communications Shortcut - Create
    How to Create a "Communications Sound" Shortcut in Windows 7
    Compare Windows 7 Editions
    Compatibility Assistant - Enable or Disable
    How to Enable or Disable Program Compatibility Assistant in Vista, Windows 7, and Windows 8
    Compatibility Mode
    Compatibility Tab - Add or Remove from Properties
    How to Add or Remove "Compatibility" Tab in Properties Page in Windows
    Complete Memory Dump Files - Configure Windows to Create on BSOD
    Compress a Folder or File
    How to Compress and Decompress a Folder or File with NTFS Compression in Vista and Windows 7
    Compress and Decompress - Add to File and Folder Context Menu
    How to Add NTFS "Compress" and "Decompress" to File and Folder Context Menu
    Compression - Disable or Enable
    How to Disable or Enable NTFS Compression in Vista and Windows 7
    Computer - Add or Remove "Advanced System Properties" from Context Menu
    Computer - Add or Remove "Device Manager" from Context Menu
    How to Add "Device Manager" to "My Computer" Context Menu in Vista and Windows 7
    Computer - Add or Remove "Devices and Printers"
    How to Add "Devices and Printers" to "Computer" or "This PC" in Windows 7 and Windows 8
    Computer - Add or Remove from Desktop Context Menu
    How to Add or Remove "Computer" Desktop Context Menu in Windows 7 and Windows 8
    Computer - Add or Remove from Navigation Pane
    How to Add or Remove Computer from the Windows 7 Navigation Pane
    Computer - Add or Remove "Search" from Context Menu
    How to Add "Search" to "My Computer" Context Menu in Vista and Windows 7
    Computer - Change or Restore Default Icon
    How to Change or Restore Default Windows 7 Desktop Icons
    Computer Description - Change
    How to Change Your Computer Description in Windows 7 and Windows 8
    Computer Folder Name - Change in Windows
    How to Change "Computer" Folder Name in Vista, Windows 7, and Windows 8
    Computer Maintenance Guide
    Keep Your PC Performing With Regular Maintenance
    Computer Maintenance - "System Maintenance Troubleshooter" Shortcut - Create
    How to Create a "System Maintenance Troubleshoot" Shortcut in Windows 7
    Computer Maintenance - System Maintenance Troubleshooter - Turn On or Off
    How to Turn the "System Maintenance Troubleshooter" On or Off in Windows 7
    Computer "Manage" Context Menu Item - Add or Remove
    How to Add or Remove Manage from Computer Context Menu
    Computer "Manage" Context Menu Item - Fix "File does not have a program associated"
    How to Fix Manage "File does not have a program associated with it" Error
    Computer Management - Add to Desktop Context Menu
    How to Add or Remove "Computer Management" to the Desktop Context Menu
    Computer Management MMC Snap-in - Enable or Disable
    How to Enable or Disable the Computer Management MMC Snap-in
    Computer Name Properties Shortcut - Create
    Create a "Computer Name Properties" Shortcut in Vista, Windows 7, and Windows 8
    Computer Name - View and Change
    How to View and Change the "Computer Name" in Windows 7
    Computer - Pin to Taskbar
    How to Create a "Computer" Shortcut and Pin it to the Windows 7 Taskbar
    Computer - Rename in Windows 7 Navigation Pane
    How to Rename "Computer" in the Windows 7 Explorer Navigation Pane
    Computer - Secure and Lock down against Unauthorised Access
    How to secure and Lock down your Computer against unauthorised access
    "Computer" Window - Add or Remove "Devices and Printers"
    How to Add "Devices and Printers" to "My Computer" in Windows 7
    Connect To - Change Default Icon in Start Menu
    How to Change the Default "Connect To" Icon in the Windows 7 Start Menu
    Connect To Shortcut - Create in Windows 7
    How to Create a "Connect To" Shortcut in Windows 7
  6. Posts : 72,050
    Windows 7 Tutorial Index - C (3 of 4)
    C:
    Connect to a Network Projector Shortcut - Create
    How to Create a "Connect to a Network Projector" Shortcut in Windows 7
    Connection to Workplace Troubleshoot Shortcut - Create
    How to Create a "Connection to Workplace using DirectAccess Troubleshoot" Shortcut in Windows 7
    Contacts and Contact Groups - Import into Windows Live Mail
    How to Import Vista and Windows 7 Contacts and Contact Groups into Windows Live Mail
    Contacts - Export and Import in Windows Live Mail
    How to Export and Import Contacts in Windows Live Mail
    Contacts- Import into Outlook 2010
    How to Import Windows Contacts into Outlook 2010
    Content Advisor - Hide or Show in Internet Options
    Hide or Show Content Advisor in Internet Options for IE10 and IE11
    Content Advisor in Internet Explorer - Allow or Block Specific Websites
    How to Allow or Block Specific Websites in Internet Explorer Content Advisor
    Content Advisor in Internet Explorer - Allow or Block Unrated Websites
    How to Allow or Block Unrated Websites with Internet Explorer Content Advisor
    Content Advisor in Internet Explorer - Change Ratings Level
    How to Change Ratings Level in Internet Explorer Content Advisor
    Content Advisor in Internet Explorer - Enable or Disable
    How to Enable or Disable Internet Explorer Content Advisor
    Content Advisor in Internet Explorer - Reset
    How to Reset Internet Explorer Content Advisor
    Content Advisor in Internet Explorer - Reset or Change Password
    How to Reset or Change Password of Internet Explorer Content Advisor
    Content Advisor Shortcut - Create
    How to Create a Internet Explorer "Content Advisor" Shortcut
    Context Menu - Add Cascading "Administrative Tools" to Desktop Context Menu
    Context Menu - Add "Compress" and "Decompress" Files and Folders
    Context Menu - Add "Copy To Folder" and "Move To Folder"
    How to Add "COPY TO FOLDER" and "MOVE TO FOLDER" to Context Menu in Windows 7 and Windows 8
    Context Menu - Add "Empty Folder and Subfolders"
    How to Add "Empty Folder and Subfolders" to Context Menu in Windows
    Context Menu - Add "Encrypt and Decrypt"
    How to Add "Encrypt and Decrypt" to Context Menu in Windows 7 and Windows 8
    Context Menu - Add "Defragment"
    How to Add "Defragment" to Context Menu in Windows 7 and Vista
    Context Menu - Add "Hide or Unhide a File or Folder"
    How to Add "Hide" and "Unhide" to File and Folder Context Menu in Vista, Windows 7, and Windows 8
    Context Menu - Add "Pin to Start Menu" to Folders, Drives, and Libraries
    How to Pin a Folder, Drive, and Library to the Start Menu in Windows 7
    Context Menu - Add "Play all"
    How to Add "Play all" to the Context Menu in Windows 7
    Context Menu - Add "Print File Directory" and "View File Directory"
    Add "View File Directory" and "Print File Directory" to Context Menu in Vista, Windows 7, and Windows 8
    Context Menu - Add or Remove "Clear Clipboard"
    Context Menu - Add or Remove "Copy Content to Clipboard"
    How to Add "Copy Content to Clipboard" to Context Menu in Vista, Windows 7, and Windows 8
    Context Menu - Add or Remove "Create Restore Point"
    How to Add "Create Restore Point" to Context Menu in XP, Vista, Windows 7, and Windows 8
    Context Menu - Add or Remove "Delete Files in Folder" and "Empty Folder"
    Add "Delete Files in Folder" and "Empty Folder" to Context Menu of Folders in Windows
    Context Menu - Add or Remove Drives in "Send To"
    How to Remove or Show Drives in the Vista and Windows 7 "Send To" Context Menu
    Context Menu - Add or Remove "Disk Cleanup"
    How to Add "Disk Cleanup" to Context Menu of Drives in Vista, Windows 7, and Windows 8
    Context Menu - Add or Remove "Enable/Disable Thumbnails"
    Add "Enable/Disable Thumbnails" to Context Menu in Vista, Windows 7, and Windows 8
    Context Menu - Add or Remove "Include in Library"
    How to Add or Remove "Include in library" in Context Menu in Windows 7 and Windows 8
    Context Menu - Add or Remove "List Hidden Files"
    How to Add "List Hidden Files" to Context Menu in Vista, Windows 7, and Windows 8
    Context Menu - Add or Remove "List Read-only Files"
    How to Add "List Read-only Files" to Context Menu in Vista, Windows 7, and Windows 8
    Context Menu - Add or Remove "Lock Drive" of BitLocker Drives
    Context Menu - Add or Remove "Open File Location" and "Open Folder Location"
    How to Add or Remove "Open File Location" and "Open Folder Location" from the Context Menu
    Context Menu - Add or Remove "Open in New Process"
    How to Add or Remove "Open in new process" from Context Menu in Windows 7 and Windows 8
    Context Menu - Add or Remove "Open with"
    How to Add or Remove the "Open with" Context Menu Item in Windows
    Context Menu - Add or Remove "Open with Notepad" for Files
    How to Add or Remove "Open with Notepad" from the Context Menu of Files
    Context Menu - Add or Remove "Open with" for BAT Files
    Context Menu - Add or Remove "Open with" for URL Files
    How to Add "Open with" to Context Menu of URL Files in Windows
    Context Menu - Add or Remove "Permanently Delete"
    How to Add "Permanently Delete" to the Context Menu of Files and Folders
    Context Menu - Add or Remove "Pin to Start Menu"
    How to Add or Remove "Pin to Start Menu" from Context Menu in Windows 7
    Context Menu - Add or Remove "Pin to Taskbar"
    How to Add or Remove "Pin to Taskbar" from Context Menu in Windows 7 and Windows 8
    Context Menu - Add or Remove "Register and Unregister" for DLL and OCX Files
    How to Add a Register and Unregister Context Menu to DLL and OCX Files in Windows
    Context Menu - Add or Remove "Run as administrator"
    How to Add or Remove "Run as Administrator" from Context Menu in Windows 7 and Windows 8
    Context Menu - Add or Remove "Run as Different User"
    How to Add or Remove "Run as Different User" in Windows 7 Context Menu
    Context Menu - Add or Remove "Run with Priority" for EXE Files
    How to Add or Remove "Run with Priority" to Context Menu of EXE Files in Windows
    Context Menu - Add or Remove "Run with CPU Affinity"
    How to Add or Remove "Run with CPU Affinity" to the Context Menu
    Context Menu - Add or Remove "Scan with Microsoft Security Essentials"
    How to Add or Remove "Scan with Microsoft Security Essentials" from Context Menu in Windows
    Context Menu - Add or Remove "Search" in Windows 7 and Windows 8
    How to Add "Search" to Context Menu in Windows 7 and Windows 8
    Context Menu - Add or Remove "Send to"
    How to Add or Remove "Send to" from Context Menu
    Context Menu - Add or Remove "Set as desktop background"
    How to Add or Remove "Set as desktop background" from Context Menu in Windows 7 and Windows 8
    Context Menu - Add or Remove "Share with"
    How to Add or Remove "Share with" Context Menu Item in Windows 7 and Windows 8
    Context Menu - Add or Remove "Slide show"
    How to Add Windows Photo Viewer "Slide show" to Context Menu in Windows 7 and Windows 8
    Context Menu - Add or Remove "Take Ownership"
    Add "Take Ownership" to Context Menu of Files, Folders, and Drives
    Context Menu - Add or Remove "Troubleshoot compatibility"
    How to Add or Remove "Troubleshoot compatibility" from Context Menu in Windows 7 and Windows 8
    Context Menu - Add "Restart Explorer" to Desktop Context Menu
    How to Add "Restart Explorer" to the Desktop Context Menu
    Context Menu - Add "Run as administrator" to VBS Files
    How to Add "Run as administrator" to VBS File Context Menu
    Context Menu - Add "Select all"
    How to Add "Select all" to the Context Menu in Windows 7
    Context Menu - Add Set CPU Affinity
    Context Menu - Add "Set and Unset a File or Folder as Read-only"
    How to Add "Set and Unset as Read-only" to File and Folder Context Menu in Windows 7
    Context Menu - Add Shortcuts with Icons
    How to Add Shortcuts to the Windows 7 Context Menu with Icons
    Context Menu - Add "Show - Hide Hidden Files"
    How to Add "Show/Hide Hidden Files" to Context Menu in Vista, Windows 7, and Windows 8
    Context Menu - Add "Show/Hide Known File Extensions"
    Add "Show/Hide Known File Extensions" to Context Menu in Vista, Windows 7 and Windows 8
    Context Menu - Add "Slide show"
    How to Add "Slide show" to the Context Menu in Windows 7
    Context Menu - Advanced
    Create your Own Custom Functions in the Context Menu
    Context Menu - Change Default Program of "Edit" Context Menu Item in Windows
    How to Change the Default Program of the "Edit" Context Menu in Windows
    Context Menu - Create Cascading Menu of Multiple Layers
    How to Create a Desktop Cascade Context Menu of Multiple Layers in Windows
    Context Menu - Customize in Games Explorer Folder
    How to Customize the Windows 7 Games Explorer Context Menu
    Context Menu Items Missing - Fix when more than 15 Files are Selected
    Restore Missing "Open", "Print", and "Edit" Context Menu Items when more than 15 Files are Selected
    Context Menu of Computer - Add or Remove "Manage"
    Context Menu of MSI Files - Add "Extract ALL"
    How to Add "Extract All" to the Context Menu of MSI Files
    Context Menu of MSI Files - Add "Run as administrator"
    How to Add "Run as administrator" to MSI File Context Menu
  7. Posts : 72,050
    Windows 7 Tutorial Index - C (4 of 4)
    C:
    Context Menu - Open Command Window Here
    How to Use "Open Command Window Here" in Windows 7
    Context Menu - Open Command Window Here - Add or Remove
    How to Add or Remove "Open Command Window Here" from the Context Menu
    Context Menu - Open Command Window Here - Add or Remove Shift + Right Click
    How to Use "Open Command Window Here" Context Menu Item without Shift+ Right Click
    Context Menu - Open Command Window Here as Administrator
    Add or Remove "Open Command Window Here as Administrator" to the Context Menu
    Context Menu - Open in New Process - With or Without Shift+Right Click
    How to Use "Open in New Process" Context Menu Item With or Without Shift+Right Click
    Context Menu - Open with - Clean Up and Remove Programs
    Context Menu - "Pin to Taskbar" and "Pin to Start" Menu Missing Fix
    How to Restore Missing "Pin to Taskbar" and "Pin to Start Menu" Context Menu Items in Windows 7 Shortcuts
    Context Menu - Print and View File Directory
    How to Add "View and Print File Directory" to the Context Menu in Vista and Windows 7
    Context Menu - Right Click vs Shift Right Click
    How to Expand the Windows 7 Context Menu for More Options
    Context Menu - Run as Different User - With or Without Shift+Right Click
    How to Use "Run as different user" Context Menu Item With or Without Shift+Right Click
    Context Menu of Windows Explorer - Enable or Disable
    How to Enable or Disable Explorer Context Menu in Windows 7 and Windows 8
    Context Menus and Dragging and Dropping - Disable or Enable in Start Menu
    How to Disable or Enable Context Menus and Dragging and Dropping in the Start Menu
    Context Menus - Enable or Disable for Taskbar
    How to Enable or Disable the Windows 7 Taskbar Context Menus
    Control Panel - Add or Remove "Advanced User Accounts"
    How to Add "Advanced User Accounts" to the Control Panel in Vista and Windows 7
    Control Panel - Add or Remove Disk Management
    How to Add Disk Management to Control Panel in Windows 7, 8, and 10
    Control Panel - Add or Remove "All Tasks" (God Mode)
    How to Add or Remove "All Tasks" (God Mode) from Control Panel in Windows
    Control Panel - Add or Remove Color and Appearance in Windows
    Control Panel - Add or Remove "Local Group Policy Editor"
    How to Add "Local Group Policy Editor" to the Control Panel in Windows
    Control Panel - Add or Remove from Desktop Context Menu
    How to Add or Remove "Control Panel" from Desktop Context Menu in Windows
    Control Panel - Add or Remove from Navigation Pane
    How to Add or Remove Control Panel from the Windows 7 Navigation Pane
    Control Panel - Add or Remove "Registry Editor"
    How to Add or Remove "Registry Editor" from Control Panel in Windows
    Control Panel - Add or Remove "Services"
    How to Add or Remove "Services" from Control Panel in Windows
    Control Panel - Add or Remove "System Configuration" (msconfig)
    How to Add or Remove "System Configuration" (msconfig) from Control Panel in Windows
    Control Panel All Tasks List Shortcut
    How to Create a Control Panel "All Tasks List" "God Mode" Shortcut in Windows 7 and Windows 8
    Control Panel Category View Shortcut - Create
    How to Create a Control Panel Shortcut that Always Opens to Category View in Windows 7 and Windows 8
    Control Panel - Change Default Icon
    How to Change the Default Control Panel Icon in Windows 7
    Control Panel - Change Default Icons
    How to Change the Default Icons in the Windows 7 Control Panel
    Control Panel - Enable or Disable
    How to Enable or Disable the Control Panel in Vista and Windows 7
    Control Panel Icons View Shortcut - Create
    How to Create a Control Panel Shortcut that Always Opens to Icons View in Windows 7 and Windows 8
    Control Panel Items - Hide in Windows
    How to Hide Specified Control Panel Items in Windows 7, Windows 8, and Windows 10
    Control Panel Items - Show Only Specified Items in Windows
    How to Show Only Specified Control Panel Items in Windows 7, Windows 8, and Windows 10
    Control Panel - Pin to Taskbar
    How to Pin the Control Panel to the Windows 7 Taskbar
    Control Panel - Rename in Navigation Pane
    How to Rename "Control Panel" in Navigation Pane in Windows 7 and Windows 8
    Control Panel View - Category or Icons
    How to Change the Windows 7 Default Control Panel View
    Convert a Dynamic Disk to a Basic Disk
    How to Convert a Dynamic Disk to a Basic Disk
    Convert FAT or FAT32 Volume to NTFS
    How to Convert a FAT or FAT32 Volume to NTFS in Windows 7
    Convert GPT Disk to MBR Disk
    How to Convert a GPT Disk to a MBR Disk
    Convert MBR Disk to GPT Disk
    How to Convert a MBR Disk to a GPT Disk
    Convert REG files to BAT files
    How to Convert Registry Files to their Batch File Equivalents
    Convert a VHD File to a ISO File
    How to Convert a VHD File to a ISO File
    Cookies - Allow or Block in Internet Explorer
    How to Allow or Block Cookies in Internet Explorer in Vista and Windows 7
    Cookies - Delete
    How to Delete Cookies in Windows 7 and Vista
    Cookies - Enable or Disable DOM Storage Cookies
    How to Enable or Disable DOM Storage "Cookies" in Internet Explorer and Firefox
    Cookies - Import and Export in Internet Explorer
    How to Import and Export Cookies in Internet Explorer
    Copy & Paste - in Windows Recovery Console
    Copy as Path - Add or Remove from Context Menu
    How to Add or Remove "Copy as Path" from the Vista and Windows 7 Context Menu
    Copy as Path - File and Folder
    How to Copy the Full Path of a File or Folder in Vista and Windows 7
    Copy a CD/DVD with only one CD/DVD Drive
    How to Copy a CD/DVD with only one CD/DVD Drive in Windows
    Copy Content to Clipboard - Add to Context Menu
    Copy Name Extension Template - Change in Windows
    How to Change Default Copy Name Extension Template in Windows 7, 8, and 10
    CPU Affinity - Add Set Affinity to Context Menu
    CPU Affinity Shortcut for a Program - Create in Windows
    How to Create a Shortcut to Run an Application with a Set CPU Affinity in Windows
    CPU - Diagnose
    How to Diagnose Intel CPU with Intel Processor Diagnostic Tool
    CPU Name - Change
    How to Change the Displayed Name of the Processor in Windows 7, XP, and Vista
    CPU Priority Level - Add or Remove "Run with Priority" for EXE Files
    CPU Priority Level - Set for Applications and Processes
    CPU Priority Shortcut for a Program - Create in Windows
    How to Create a Shortcut to Run an Application with a Specific CPU Priority in Windows
    CPU - Stress Test Using IntelBurnTest
    Test your CPU Stability with IntelBurnTest
    CPU - Stress Test with Prime95
    How to Stress Test your Hardware for Stability and Heat Problems with Prime95
    Crash Reports - Read
    How to Read Crash Reports
    Credential Manager Shortcut - Create
    How to Create a "Credential Manager" Shortcut in Vista, Windows 7, and Windows 8
    Credential Manager - View and Remove Stored Passwords by IE11
    How to View and Remove Stored Passwords for Websites by Internet Explorer 11 (IE11)
    Cross Platform LAN Error Fix
    How to Fix LAN Error 0x8007046a between XP and Windows 7 PCs
    CrossfireX for AMD Graphics Cards - Disable ULPS (Ultra Low Power State)
    CTRL+ALT+DEL - Require to Press to Approve UAC Elevation
    How to Require Users to Press CTRL+ALT+DEL to Approve UAC Elevation
    CTRL+ALT+DEL Screen - Add or Remove Change Password
    How to Add or Remove Change Password from the CTRL+ALT+DEL Screen
    CTRL+ALT+DEL Screen - Add or Remove Lock Computer
    How to Add or Remove Lock Computer from the CTRL+ALT+DEL Screen
    CTRL+ALT+DEL Screen - Add or Remove Log Off
    How to Add or Remove Log Off from the CTRL+ALT+DEL Screen
    CTRL + ALT + DELETE - Secure Logon
    How to Enable or Disable Secure Logon CTRL+ALT+DELETE in Windows 7
    Ctrl+Alt+Del and Start Menu - Add or Remove Switch User
    How to Add or Remove Switch User from CTRL+ALT+DEL Screen and Start Menu
    CTRL+ALT+DEL Screen - Add or Remove Task Manager
    How to Add or Remove Task Manager from the CTRL+ALT+DEL Screen
    Currency Format - Change
    How to Change the Currency Format in Windows 7 and Windows 8
    Cursor Blink Rate - Set
    How to Set the Cursor Blink Rate in Vista, Windows 7, and Windows 8
    Cursor - Set Thickness Width
    How to Set the Thickness Width of the Blinking Cursor in Windows 7 and Windows 8
    Cursor Pointers - Allow or Prevent Changing
    How to Allow or Prevent Changing Mouse Pointers in Windows 7
    Cursor Pointers - Allow or Prevent Themes to Change
    How to Prevent or Allow Themes to Change Windows 7 Mouse Pointers
    Cursor Pointers - Change
    How to Change the Mouse Pointers in Windows 7
    Custom Install Windows 7
    How to Do a Custom Installation of Windows 7
    Custom Power Plan - Create or Delete
    How to Create or Delete a Custom Power Plan in Windows 7
    Custom Windows 7 Installations with vLite
    How to Use vLite to Trim Down Windows 7 for a Custom Installation
    Customer Experience Improvement Program - Join or Unjoin
    Join or Unjoin Customer Experience Improvement Program in Windows 7 and Windows 8
    Customize Tab - Add or Remove from Properties
    How to Add or Remove the Customize Tab from Properties in Vista, Windows 7, and Windows 8
  8. Posts : 72,050
    Windows 7 Tutorial Index - D (1 of 4)
    D:
    Darik's Boot and Nuke - Use to Secure Wipe a Hard Drive
    How to Securely Wipe a Hard Disk with "Darik's Boot and Nuke"
    Data Partition
    Date and Time - Allow or Prevent Users and Groups from Changing
    How to Allow or Prevent Specific Users and Groups from Changing the Date and Time in Windows
    Date and Time - Change
    How to Change the Date and Time in Windows 7
    Date and Time Formats - Enable or Disable Changing in Windows
    How to Enable or Disable Changing Date and Time Formats in Windows 7, Windows 8, and Windows 10
    Date and Time of Windows Installation - Find
    See Original Installation Date and Time of Windows 7 and Windows 8
    Date and Time Shortcut - Create
    How to Create a "Date and Time" Shortcut in Vista, Windows 7, and Windows 8
    Date Format - Change
    How to Change the Date Format in Windows 7
    Date Format for Taskbar System Tray - Show Full Day and Month Names
    How to Show Full Day and Month Names in Date on Taskbar System Tray in Windows
    Debug Diagnostic Tool
    Download Debug Diagnostic Tool v2 Update 1
    Decrypt or Encrypt a Folder or File
    How to Encrypt or Decrypt a Folder or File in Vista and Windows 7
    Default Location Shortcut - Create
    How to Create a "Default Location" Shortcut in Windows 7
    Default Operating System - Change Default Boot OS
    How to Change the Default Operating System to Start in Windows 7 and Vista
    Default Programs - Associate a File Type or Protocol
    How to Associate a File Type or Protocol Default Program to Open with in Windows 7
    Default Programs - Change Default Icon in Start Menu
    How to Change the Default "Default Programs" Icon in the Windows 7 Start Menu
    Default Programs - Change using "Open with"
    How to Change the Default Program a File Type Opens with in Windows 7
    Default Programs - Remove a Listed Program
    Default Programs - Restore or Remove "Internet Explorer"
    How to Restore or Remove Internet Explorer from Default Programs
    Default Programs - Restore or Remove "Windows Media Center"
    How to Restore or Remove "Windows Media Center" from Default Programs
    Default Programs - Restore or Remove "Windows Media Player"
    How to Restore or Remove "Windows Media Player" from Default Programs
    Default Programs - Restore Default File Type Associations
    Restore Default Windows 7 File Extension Type Associations
    Default Programs - Set a Program's Default Associations
    Default Programs Shortcut - Create
    How to Create a "Default Programs" Shortcut in Windows 7
    Default Programs - Unassociate a File Extension Type
    How to Unassociate a File Extension Type in Vista, Windows 7, and Windows 8
    Defragment - Add to Context Menu
    How to Add "Defragment" to Context Menu of Drives in Windows 7 and Vista
    Delete Button - Add to Windows 7 Explorer Toolbar
    How to Add a "Delete" Button to the Windows 7 Explorer Toolbar (Command Bar)
    Delete Confirmation Dialog Prompt Details - Customize in Windows
    How to Customize Delete Confirmation Dialog Prompt Details in Windows
    Delete Confirmation to Recycle Bin - Turn On or Off
    How to Turn the Recycle Bin Delete Confirmation On or Off in Windows
    DEP - Enable or Disable
    How to Enable or Disable DEP in Vista, Windows 7, and Windows 8
    DEP System Properties Shortcut - Create
    How to Create a "DEP System Properties" Shortcut
    DEP - Turn On or Off for Programs
    How Turn DEP On or Off for a Program in Vista and Windows 7
    Desktop - Add or Remove Gadgets from
    How to Add or Remove Desktop Gadgets in Windows 7
    Desktop Background - Add or Remove "Set as desktop background" Context Menu
    Desktop Background - Allow or Prevent Changing
    How to Allow or Prevent Changing Desktop Background in Vista, Windows 7, and Windows 8
    Desktop Background - Change
    How to Change the Windows 7 Desktop Background
    Desktop Background - Change in Windows 7 Starter and Home Basic
    How to Change the Desktop Background in Windows 7 Starter and Home Basic Editions
    Desktop Background - Play a Music Video
    How to Play a Music Video as the Desktop Background
    Desktop Background - Remove Picture Location History
    How to Remove the Desktop Background Picture Location History in Windows 7 and Windows 8
    Desktop Background - Remove Images (where available)
    Desktop Background - Set to Bing Daily Homepage Image in Windows 7
    Desktop Background Shortcut - Create
    How to Create a Change "Desktop Background" Shortcut in Vista and Windows 7
    Desktop Background - Specify and Prevent Change
    How to Specify a Desktop Background for Users in Vista, Windows 7, and Windows 8
    Desktop - Clear by Shaking a Window
    Desktop Composition - Disable for a Program
    Desktop Composition - Enable or Disable
    How to Enable or Disable Desktop Composition in Windows 7 and Vista
    Desktop Context Menu - Add Cascading "Accessories"
    How to Add a "Accessories" Cascading Desktop Context Menu in Windows 7
    Desktop Context Menu - Add Cascading "Administrative Tools"
    Desktop Context Menu - Add Cascading "Microsoft Security Essentials"
    How to Add a "Microsoft Security Essentials" Cascading Desktop Context Menu in Windows 7
    Desktop Context Menu - Add Cascading "System Tools"
    How to Add a "System Tools" Cascading Desktop Context Menu in Windows 7
    Desktop Context Menu - Add or Remove "Display"
    How to Add or Remove "Display" from Desktop Context Menu in Windows 7 and Windows 8
    Desktop Context Menu - Add "Empty Recycle Bin"
    How to Add "Empty Recycle Bin" to Desktop Context Menu in Windows 7 and Windows 8
    Desktop Context Menu - Add "Flip 3D"
    How to Add "Flip 3D" to the Desktop Context Menu in Vista and Windows 7
    Desktop Context Menu - Add or Remove "Advanced Window Color and Appearance"
    Desktop Context Menu - Add or Remove "Catalyst Control Center"
    Desktop Context Menu - Add or Remove "Choose Power Plan"
    How to Add "Choose Power Plan" to Desktop Context Menu in Windows 7 and Windows 8
    Desktop Context Menu - Add or Remove "Computer"
    Desktop Context Menu - Add or Remove "Computer Management"
    Desktop Context Menu - Add or Remove "Control Panel"
    Desktop Context Menu - Add or Remove "Create Restore Point"
    Desktop Context Menu - Add or Remove "Edit HOSTS File"
    How to Add "Edit HOSTS file" to Desktop Context Menu in Vista, Windows 7, and Windows 8
    Desktop Context Menu - Add or Remove "Eject and Close CD/DVD Tray"
    Desktop Context Menu - Add or Remove "Extended Disk Cleanup"
    How to Add "Extended Disk Cleanup" to Desktop Context Menu in Windows 7 and Windows 8
    Desktop Context Menu - Add or Remove "Gadgets"
    How to Add or Remove "Gadgets" from Desktop Context Menu in Windows 7
    Desktop Context Menu - Add or Remove "Kill Not Responding Tasks"
    How to Add "Kill Not Responding Tasks" to Desktop Context Menu in Windows
    Desktop Context Menu - Add or Remove "Lock Computer"
    How to Add "Lock Computer" to the Desktop Context Menu in Windows 7
    Desktop Context Menu - Add or Remove "Lock Computer and Turn Off Monitor"
    How to Add "Lock Computer and Turn Off Monitor" to the Context Menu in Windows
    Desktop Context Menu - Add or Remove "Log Off"
    How to Add "Log Off" Computer to the Desktop Context Menu in Windows 7
    Desktop Context Menu - Add or Remove "Next Desktop Background"
    Add or Remove "Next desktop background" from Desktop Context Menu in Windows 7 and Windows 8
    Desktop Context Menu - Add or Remove "NVIDIA Control Panel"
    How to Add or Remove "NVIDIA Control Panel" from Desktop Context Menu
    Desktop Context Menu - Add or Remove Expanding "Personalize"
    How to Add or Remove Expanding "Personalize" Desktop Context Menu in Windows 7 and Windows 8
    Desktop Context Menu - Add or Remove "Personalize"
    How to Add or Remove "Personalize" from Desktop Context Menu in Windows 7 and Windows 8
    Desktop Context Menu - Add or Remove "Recycle Bin"
    How to Add or Remove "Recycle Bin" from Desktop Context Menu
    Desktop Context Menu - Add or Remove "Restart Computer"
    How to Add "Restart" Computer to the Desktop Context Menu in Windows 7
  9. Posts : 72,050
    Windows 7 Tutorial Index - D (2 of 4)
    A - B - C - D - E - F - G - H - I - J - K - L - M - N - O - P - Q - R - S - T - U - V - W - X - Y - Z
    D:
    Desktop Context Menu - Add or Remove "Restart Explorer"
    Desktop Context Menu - Add or Remove "Safe Mode" Cascading Menu
    How to Add "Safe Mode" to Desktop Context Menu in Windows 7 and Windows 8
    Desktop Context Menu - Add or Remove "Safely Remove Hardware"
    How to Add "Safely Remove Hardware" to the Desktop Context Menu
    Desktop Context Menu - Add or Remove "Screen resolution"
    How to Add or Remove "Screen resolution" from Desktop Context Menu in Windows
    Desktop Context Menu - Add or Remove - Screen Saver Toggle On or Off
    How to Add "Enable/Disable Screen Saver" to Desktop Context Menu
    Desktop Context Menu - Add or Remove "Search" in Windows 7 and Windows 8
    Desktop Context Menu - Add or Remove "Shut Down Computer"
    How to Add "Shut Down" Computer to the Desktop Context Menu in Windows 7
    Desktop Context Menu - Add or Remove "Turn Off Display"
    How to Add or Remove "Turn Off Display" Desktop Context Menu in Windows 7 and Windows 8
    Desktop Context Menu - Add or Remove "User Folder"
    How to Add or Remove "User Folder" from Desktop Context Menu in Windows
    Desktop Icon Labels - Turn Drop Shadows On or Off
    How to Turn Drop Shadows On or Off for Desktop Icons in Windows
    Desktop Icon Settings Shortcut - Create
    How to Create a "Desktop Icon Settings" Shortcut in Windows
    Desktop Icon Text - Hide or Show
    Hide or Show File Names of Shortcuts and Folders in Windows 7 and Windows 8
    Desktop Icons - Add or Remove
    How to Add or Remove a Default Desktop Icon in Windows 7
    Desktop Icons - Add or Remove "HomeGroup" Icon
    How to Add or Remove the "HomeGroup" Desktop Icon in Windows 7
    Desktop Icons - Add or Remove "Internet Explorer" in Windows 7
    How to Create a "Internet Explorer" Desktop Icon in Windows 7
    Desktop Icons - Add or Remove "Libraries" Icon
    How to Add or Remove the "Libraries" Desktop Icon in Windows 7
    Desktop Icons - Allow or Prevent Themes to Change
    How to Prevent or Allow Themes to Change Desktop Icons in Windows 7 and Windows 8
    Desktop Icons - Change or Restore Default Icon
    Desktop Icons - Custom Size
    How to Change Desktop Icons Size in Windows
    Desktop Icons - Enable or Disable Changing
    How to Enable or Disable Changing Default Desktop Icons in Windows 7
    Desktop Icons - Hide or Show
    How to Hide or Show Desktop Icons in Windows 7 and Windows 8
    Desktop Gadgets - Hide or Show
    How to Hide or Show Desktop Gadgets in Windows 7
    Desktop Shortcuts Disappear Fix - System Maintenance Troubleshooter - Turn Off
    Desktop - "Show Desktop" Shortcut - Create
    How to Create a "Show Desktop" Shortcut in Windows 7 and Windows 8
    Desktop Slideshow
    How to Create a Desktop Slideshow in Windows 7
    Desktop Slideshow - Shuffle Images in Multiple Folders
    How to Have a Windows 7 Desktop Slideshow Shuffle Images in Multiple Folders
    Desktop Toolbar on Taskbar - Add or Remove
    How to Add or Remove the Desktop Toolbar on the Windows 7 Taskbar
    Detailed Status Messages - Logon, Logoff, and Shutdown
    Enable or Disable Detailed Verbose Logon, Logoff, Startup, and Shutdown Status Messages in Vista and Windows 7
    Details Pane - Change Size
    How to Change the Size of the Details Pane in Windows 7
    Details Pane - Customize Preview Details in Windows
    How to Customize Preview Details in Details Pane of File Explorer in Vista. Windows 7, Windows 8. and Windows 10
    Details Pane - Enable or Disable in Windows 7
    How to Enable or Disable the Windows Explorer "Details Pane" in Windows 7
    Details Pane Size - Reset in Vista and Windows 7
    How to Reset Details Pane Size to Default in Vista and Windows 7
    Details Pane - Turn On or Off
    How to Turn the Details Pane On or Off in Windows
    Details Properties of a File - Add, Change, or Remove
    How to Add, Change, or Remove File Details Properties in Windows 7
    Details Tab - Add or Remove from File Properties
    How to Add or Remove "Details" Tab in File Properties in Windows
    deviantART - Customize Custom Themes from
    How to Customize a Custom Theme from deviantART
    Device - "Add a Device" Wizard Shortcut - Create
    How to Create a "Add a Device" Shortcut in Windows 7
    Device - Eject with Safely Remove Hardware
    How to Use Safely Remove Hardware to Eject a Device in Windows 7 and Windows 8
    Device Installation Settings
    How to Change Device Driver and Information Installation Settings in Windows 7 and Windows 8
    Device Installation Settings Shortcut - Create in Windows
    How to Create a "Device Installation Settings" Shortcut in Windows 7 and Windows 8
    Device Manager - Add or Remove from "My Computer" Context Menu
    Add "Device Manager" to "My Computer" Context Menu in Vista, Windows 7, and Windows 8
    Device Manager - Finding Unknown Devices
    How to Find and Identify Unknown Devices through Device Manager
    Device Manager - Hidden Devices
    How to View Hidden Devices in Windows
    Device Manager - Roll Back Driver
    How to Roll Back a Device Driver in Device Manager
    Device Manager Shortcut - Create
    How to Create a "Device Manager" Shortcut in Vista, Windows 7, and Windows 8
    Device Manager MMC Snap-in - Enable or Disable
    How to Enable or Disable the "Device Manager" MMC Snap-in
    Device - Uninstall in Windows
    How to Uninstall a Device in Windows 7 and Windows 8
    Devices - Allow or Prevent to Wake Up Computer
    How to Allow or Prevent Devices to Wake Up Computer
    Devices and Hardware Troubleshoot Shortcut - Create
    How to Create a "Hardware and Devices Troubleshoot" Shortcut in Windows 7
    Devices and Printers - Add to My Computer
    Devices and Printers - Change Default Icon in Start Menu
    How to Change the Default "Devices and Printers" Icon in the Windows 7 Start Menu
    Devices and Printers - Change Device Icons with Custom Icons
    How to Change Icons in Devices and Printers with Custom Icons
    Devices and Printers - Device Stage
    How to Open "Devices and Printers" in Windows 7 and Windows 8
    Devices and Printers Shortcut - Create
    How to Create a "Devices and Printers" Shortcut in Windows 7 and Windows 8
    Devices and Printers Troubleshoot Shortcut - Create
    How to Create a "Devices and Printers Troubleshoot" Shortcut in Windows 7
    Devices - Enable Hidden Audio Devices
    Devices - Enable or Disable Write-Caching
    How to Enable or Disable Write-Caching for a Storage Device in Windows 7 and Windows 8
    Devices - See Devices that are able to Wake Up the Computer
    How to See a List of Devices that are able to Wake Up the Computer
    Dialog Boxes - Customize Places Bar
    How to Customize Default Places Bar in Windows Common File Dialog Boxes
    DIPM and HIPM - Enable in AHCI Link Power Management
    How to Enable HIPM and DIPM for your SSD and HDD in Windows 7
    DirectX Diagnostic Tool
    How to Open and Use the DirectX Diagnostic Tool in Vista and Windows 7
    Disconnect Network Drive and Map Network Drive - Add or Remove
    How to Add or Remove "Map Network Drive" and "Disconnect Network Drive" Options
    Continued on next page......
Page 1 of 7 123 ... LastLast
