Windows 7 - Tutorial Index
Page 5 of 7 FirstFirst ... 34567 LastLast
  1. Posts : 72,052
       #40
    Windows 7 Tutorial Index - P (2 of 4)
    A - B - C - D - E - F - G - H - I - J - K - L - M - N - O - P - Q - R - S - T - U - V - W - X - Y - Z
    P:
    Picture - Change User Display Picture
    How to Change Your User Account Logon Picture in Windows 7
    Picture File Tags - Add, Change, or Remove
    How to Add, Change, or Remove File Details Properties in Windows 7
    Pictures Library - Create Shortcut in Windows
    How to Create a "Pictures Library" Shortcut in Windows 7 and Windows 8
    Pin to Start Menu - Add or Remove from Context Menu in Windows 7
    How to Add or Remove "Pin to Start Menu" from Context Menu in Windows 7
    Pin to Start Menu - Add to Context Menu of Folders, Drives, and Libraries
    How to Pin a Folder, Drive, and Library to the Start Menu in Windows 7
    Pin to Start Menu - Enable or Disable
    How to Enable or Disable Pin to Start Menu in Vista and Windows 7
    Pin to Taskbar - Add or Remove from Context Menu in Windows
    How to Add or Remove "Pin to Taskbar" from Context Menu in Windows 7 and Windows 8
    "Pin to Taskbar" and "Pin to Start" Menu Missing from Context Menu Fix
    How to Restore Missing "Pin to Taskbar" and "Pin to Start Menu" Context Menu Items in Windows 7 Shortcuts
    Places Bar - Customize in Common File Dialog Box
    How to Customize Common Open File Dialog Box Places Bar in Windows
    Play a Music Video as Desktop Background
    Play all - Add to Context Menu in Windows 7
    How to Add "Play all" to the Context Menu in Windows 7
    Playback Shortcut - Create
    How to Create a "Playback Sound" Shortcut in Windows 7
    Playing Audio Troubleshoot Shortcut - Create
    How to Create a "Playing Audio Troubleshoot" Shortcut in Windows 7
    Point to Select in Single-Click Mode - Enable or Disable
    How to Enable or Disable Point to Select using Single-click to Open an Item
    Pointer - Show location with CTRL Key - Enable or Disable
    How to Enable or Disable Show Pointer Location with CTRL Key
    Pointer - Snap To Default Button
    How to Set Mouse Pointer to Automatically Move to Default Button in Windows 7 and Windows 8
    Pointers - Allow or Prevent Changing
    How to Allow or Prevent Changing Mouse Pointers in Windows 7
    Pointers - Allow or Prevent Themes to Change
    How to Prevent or Allow Themes to Change Windows 7 Mouse Pointers
    Pointers - Change
    How to Change the Mouse Pointers in Windows 7
    Pop-up Descriptions - Change Text in Start Menu
    How to Change Start Menu Descriptive Text Pop-up Information in Vista and Windows 7
    Pop-up Descriptions - Enable or Disable
    How to Enable or Disable Pop-up Descriptions in Windows 7 and Windows 8
    Portable OS - Carry your OS on an External Drive
    How to Create a Portable OS on an External Drive
    Post a File or Screenshot in Seven Forums
    How to Upload and Attach Files and Screenshots to a Post in Seven Forums
    Post Template: Create at Seven Forums
    Power Availability Requests - Manage in Windows
    How to View and Override Power Availability Requests in Windows
    Power Button - Enable or Disable "Install Updates and Shut Down"
    How to Enable or Disable "Install Updates and Shut Down" Option in Windows 7
    Power Button - Start Menu
    How to Change the Default Windows 7 Start Menu Power Button Action
    Power Efficiency Diagnostics Report
    How to Run a Power Efficiency Diagnostics Report in Windows 7 and Windows 8
    Power Management - AHCI Link Power Management - Enable HIPM and DIPM
    How to Enable HIPM and DIPM for your SSD and HDD in Windows 7 and Windows 8
    Power Management - Allow or Prevent Devices to Wake Up Computer
    How to Allow or Prevent Devices to Wake Up Computer
    Power Management - Enable or Disable Windows Media Center Updates from Waking Computer
    How to Enable or Disable Windows Media Center Updates to Wake Up the Computer
    Power Mangement - Lastwake Command
    How to See What Woke Up Your Computer Last
    Power Management - See Available Sleep States
    How to See Available Sleep States on Your System
    Power Management - See Devices that are able to Wake Up the Computer
    How to See a List of Devices that are able to Wake Up the Computer
    Power Management - Unattended Wake Up Return to Sleep Timout Period - Change
    How to Change the Return to Sleep Timeout for a Unattended Wake Up in Windows 7
    Power Options - Add or Remove "Allow Away Mode Policy"
    How to Add or Remove "Allow Away Mode Policy" in Power Options in Windows
    Power Options - Add or Remove "Allow sleep with Remote Opens"
    How to Add or Remove "Allow sleep with Remote Opens" in Power Options in Windows 7 and 8
    Power Options - Add or Remove "Allow wake timers"
    How to Add or Remove "Allow wake timers" in Power Options in Windows
    Power Options - Add or Remove "Dim display after"
    How to Add or Remove "Dim display after" in Power Options in Windows
    Power Options - Add or Remove "Enable forced button/lid shutdown"
    How to Add or Remove "Enable forced button/lid shutdown" in Power Options
    Power Options - Add or Remove "Hard disk burst ignore time"
    How to Add or Remove "Hard disk burst ignore time" in Power Options
    Power Options - Add or Remove "Hibernate after"
    How to Add or Remove "Hibernate after" in Power Options in Windows
    Power Options - Add or Remove Internet Explorer in Windows
    How to Add or Remove Internet Explorer in Power Options in Windows
    Power Options - Add or Remove Link State Power Management
    How to Add or Remove PCIe "Link State Power Management" in Power Options in Windows
    Power Options - Add or Remove "Min/Max processor state"
    How to Add or Remove "Minimum processor state" and "Maximum processor state" in Power Options in Windows
    Power Options - Add or Remove "Slide Show"
    How to Add or Remove Desktop Background "Slide Show" in Power Options in Windows
    Power Options - Add or Remove "System cooling policy"
    How to Add or Remove "System cooling policy" in Power Options in Windows
    Power Options - Add or Remove "System unattended sleep timeout"
    How to Add or Remove "System unattended sleep timeout" in Power Options
    Power Options - Add or Remove "Turn off hard disk after"
    How to Add or Remove "Turn off hard disk after" in Power Options in Windows
    Power Options - Add or Remove USB Selective Suspend
    How to Add or Remove "USB selective suspend setting" in Power Options in Windows
    Power Options - Add or Remove "When sharing media"
    How to Add or Remove "When sharing media" in Power Options in Windows
    Power Options - Add or Remove Wireless Adapter Settings
    How to Add or Remove Wireless Adapter Settings "Power Saving Mode" in Windows
    Power Options - "Advanced Power Options" Shortcut - Create
    How to Create an "Advanced Power Options" Shortcut in Windows 7 and Windows 8
    Power Options and Sleep Mode Problems - Troubleshoot
    How to Troubleshoot a Vista or Windows 7 Sleep Mode Problem
    Power Options Shortcut - Create
    How to Create a "Power Options" Shortcut in Windows 7 and Windows 8
    Power Options - Turn Off Hard Disk After Idle or Never
    How to Turn Off Hard Disk After so many Minutes of being Idle or Never
    Power Plan - Choose from Desktop Context Menu in Windows
    How to Add "Choose Power Plan" to Desktop Context Menu in Windows 7 and Windows 8
    Power Plan - Create or Delete Custom Power Plan
    How to Create or Delete a Custom Power Plan in Windows 7
    Power Plan - Create Shortcut to Change Power Plan
    How to Create a Shortcut to Change Power Plans in Windows 7 and Windows 8
    Power Plan - Rename
    How to Rename a Power Plan Name in Windows 7 and Windows 8
    Power Plan - Restore Default Settings
    How to Restore the Default Power Plan Settings in Windows 7
    Continued on next post......
  2. Posts : 72,052
       #41
    Windows 7 Tutorial Index - P (3 of 4)
    P:
    Power Plan - Select
    How to Select a Power Plan Scheme in Windows 7 and Windows 8
    Power Plan Settings - Change
    How to Change the Power Plan Settings in Windows 7
    Power Plan Settings - Internet Explorer 9 JavaScript Timer Frequency
    How to Change the IE9 JavaScript Timer Frequency Power Option Setting in Windows 7
    Power Plan Settings - View in Text File in Windows
    How to View Power Plan Settings in a Text File in Windows
    Power Plan - Specify a Default for All Users
    How to Specify a Default Power Plan for All Users in Vista, Windows 7, and Windows 8
    Power Plans - Export and Import
    How to Export and Import Power Plans in Windows 7 and Windows 8
    PowerPoint - Create Picture Show
    How to Create a PowerPoint Picture Show
    PowerPoint – Embed MP3 files
    PowerShell 7.0 - Install in Windows
    How to Install PowerShell 7.0 in Windows 7, Windows 8, and Windows 10
    Power Troubleshoot Shortcut - Create
    How to Create a "Power Troubleshoot" Shortcut in Windows 7
    Presentation Mode - Change
    How to Change the Windows 7 Display Presentation Mode
    Presentation Settings - Enable or Disable
    How to Enable or Disable Presentation Settings in Windows 7 and Windows 8
    Presentation Settings Shortcut - Create
    How to Create a "Presentation Settings" Shortcut in Windows 7 and Windows 8
    Presentation Settings - Turn On or Off
    How to Turn Presentation Settings On or Off in Windows 7 and Windows 8
    Previous Version of Windows - Go Back in Windows 10
    How to Go Back to Previous Version of Windows in Windows 10
    Previous Versions - Hide or Show from Backup Location
    How to Hide or Show Previous Versions of Files from a Backup Location
    Previous Versions - Hide or Show from File Shares
    How to Hide or Show Previous Versions of Files from File Shares
    Previous Versions - Restore Files and Folders
    How to Restore Files and Folders in Windows 7 with Previous Versions
    Previous Versions Tab - Restore or Remove from Properties
    How to Restore or Remove Previous Versions Tab from Properties
    Preview Pane - Enable or Disable in Windows 7
    How to Enable or Disable the Windows Explorer "Preview Pane" in Windows 7
    Preview Pane - Hide or Show Preview Handlers in Windows
    How to Hide or Show Preview Handlers in Preview Pane in Windows
    Preview Pane Size - Reset in Vista and Windows 7
    How to Reset Preview Pane Size to Default in Vista and Windows 7
    Preview Pane - Turn On or Off
    How to Turn the Preview Pane On or Off in Windows 7
    Print and View File Directory - Add to Context Menu
    Add "View File Directory" and "Print File Directory" to Context Menu in Vista, Windows 7, and Windows 8
    Print - Open - Edit : Fix Missing in Context Menu when more than 15 Files are Selected
    Restore Missing "Open", "Print", and "Edit" Context Menu Items when more than 15 Files are Selected
    Print Queue Shortcut - Create in Windows 7 and Windows 8
    How to Create a "Print Queue" Shortcut in Windows 7 and Windows 8
    Print Spooler Queue - Clear and Reset
    How to Clear and Reset the Print Spooler Queue in Vista, Windows 7, and Windows 8
    Print to XPS File - Microsoft XPS Document Writer
    How to Print to the Microsoft XPS Document Writer in Vista, Windows 7, and Windows 8
    Printer - "Add Printer" Wizard Shortcut - Create
    How to Create a "Add Printer" Wizard Shortcut in Windows 7 and Vista
    Printer - Install Driver in Add Printer Wizard
    How To Install A Driver in Add Printer Wizard
    Printer Migration Wizard Shortcut - Create
    How to Create a "Printer Migration Wizard" Shortcut in Vista, Windows 7, and Windows 8
    Printer - Rename in Windows
    How to Rename a Printer in Windows 7 and Windows 8
    Printer Switching - Location Aware Printing
    How to Automatically Switch Default Printers with Location Aware Printing in Vista, Windows 7, and Windows 8
    Printers and Devices - Device Stage
    How to Open Devices and Printers in Windows 7
    Printers and Devices Shortcut - Create
    How to Create a "Devices and Printers" Shortcut in Windows 7
    Printers and Devices Troubleshoot Shortcut - Create
    How to Create a "Devices and Printers Troubleshoot" Shortcut in Windows 7
    Printers - Backup and Restore in Windows
    How to Backup and Restore Printers in Windows 7, Windows 8, and Windows 10
    Printers Shortcut - Create
    How to Create a "Printers" Folder Shortcut in Vista, Windows 7, and Windows 8
    Printing Troubleshooting Shortcut - Create
    How to Create a "Printing Troubleshoot" Shortcut in Windows 7
    Priority Level - Add or Remove "Run with Priority" for EXE Files
    How to Add or Remove "Run with Priority" to Context Menu of EXE Files in Windows
    Priority Level - Set for Applications and Processes
    How to Set Priority Level for Applications and Processes in Windows 7
    Private Character Editor
    How to Open and Use Private Character Editor in Vista, Windows 7, and Windows 8
    Problem Reports and Solutions - Change Problem Reporting Settings
    How to Change "Problem Reporting Settings" in Windows 7 and Windows 8
    Problem Reports and Solutions - Clear History
    How to Clear Your Windows 7 Problem Report History
    Problem Reports and Solutions - View History Details
    How to Review Reliability and Problems History Details in Windows 7 and Windows 8
  3. Posts : 72,052
       #42
    Windows 7 Tutorial Index - P (4 of 4)
    P:
    Problem Reports Shortcut - Create
    How to Create a "Problems Reports" Shortcut in Windows 7 and Windows 8
    Problem Steps Recorder
    How to Use Problem Steps Recorder in Windows 7
    Problem Steps Recorder - Enable or Disable
    How to Enable or Disable Problem Steps Recorder in Windows 7
    Process - End Task in Vista and Windows 7
    How to End a Process Task in Vista Windows 7
    Process Explorer + VirusTotal (to check all processes with 50+ AV's)
    Process - See if running as administrator (elevated)
    How to See if Process is running as administrator (elevated) in Vista and Windows 7
    Processes - Add "Kill Not Responding Tasks" to Desktop Context Menu
    How to Add "Kill Not Responding Tasks" to Desktop Context Menu in Windows
    Processor Affinity - Add Set Affinity to Context Menu
    How to Add or Remove "Run with CPU Affinity" to the Context Menu
    Processor Affinity - Set for Applications
    How to Set Processor Affinity to an Application in Windows 7
    Processor Affinity Shortcut for a Program - Create in Windows
    How to Create a Shortcut to Run an Application with a Set CPU Affinity in Windows
    Processor Name - Change
    How to Change the Displayed Name of the Processor in Windows 7, XP, and Vista
    Processor Priority Shortcut for a Program - Create in Windows
    How to Create a Shortcut to Run an Application with a Specific CPU Priority in Windows
    Processor Scheduling - Adjust for Performance in Windows
    How to Adjust Processor Scheduling for Best Performance in Vista, Windows 7, and Windows 8
    Processor - Stress Test with Prime95
    How to Stress Test your CPU for Stability and Heat Problems
    Processors - Limit Number Used by Windows 7
    How to Set the Number of Processors or Cores to be Used by Windows 7
    Product Key - Clear from Registry in Windows
    How to Clear Product Key from Registry in Windows
    Product Key Number - Change
    How to Change the Product Key Number in Windows 7
    Product Key Number for Windows 7 - Find and See
    How to Find and See the Windows 7 Product Key Number
    Product Key Number - Uninstall and Deactivate in Windows
    How to Uninstall the Product Key Number and Deactivate Vista, Windows 7, or Windows 8
    Program - Add to "Open with"
    How to Add a Program to "Open with" in Windows 7
    Program - Clean Up and Remove in Open with
    How to Clean Up and Remove Programs from the "Open with" Context Menu
    Program Compatibility Assistant - Enable or Disable
    How to Enable or Disable Program Compatibility Assistant in Vista, Windows 7, and Windows 8
    Program Compatibility Troubleshoot Shortcut - Create
    How to Create a Program Compatibility Troubleshooter Shortcut in Windows 7 and Windows 8
    Program - Create Elevated Shortcut for without UAC Prompt
    How to Create a Elevated Program Shortcut without a UAC Prompt
    Program - Create Task to Run a Program at Startup and Log On
    How to Create a Task to Run a Program at Startup and Log On in Windows 7
    Program - Create Terminate Non-responding Application Shortcut
    How to Create a shortcut to Terminate a Non-responding Application in Windows 7
    Program - Disable Desktop Composition
    How to Disable Desktop Composition for a Program
    Program, File, Folder, or Drive - Create Shortcut of in Windows
    How to Create a Shortcut of a File, Folder, Drive, or Program in Vista, Windows 7, and Windows 8
    Program Install and Uninstall Troubleshooter in Windows
    How to Download and Use Program Install and Uninstall Troubleshooter in Windows 7, Windows 7, and Windows 10
    Program - Pin Invisible Icon to Taskbar
    How to "Pin to Taskbar" Transparent Invisible Icons for Programs in Windows 7
    Program - Pin or Unpin to Start Menu
    How to Pin or Unpin a Program to the Windows 7 Start Menu
    Program - Pin or Unpin to Taskbar
    How to Pin or Unpin a Program to the Windows 7 Taskbar
    Program - Remove a Listed Program in Default Programs
    How to Remove a Listed Program in Default Programs for Windows 7 and Vista
    Program - "Run as administrator" - Create Shortcut for Standard User
    How to Create a Elevated Program Shortcut Any User is able to Run in Windows 7 and Windows 8
    Program - Run as Different User Shortcut - Create for Specified Program and User
    How to Create a Shortcut to Run a Program as a Specified User
    Program - Run in Compatibility Mode
    How to Run a Program in Compatibility Mode in Windows 7
    Program - Set a Program's Default Associations in Default Programs
    How to Set Default Associations for a Program in Windows 7
    Programs and Documents - Run at User Logon
    How to Run Specific Programs and Documents at User Logon in Vista, Windows 7, and Windows 8
    Programs and Features - Create Shortcut
    How to Create a "Programs and Features" Shortcut in Windows 7 and Windows 8
    Programs and Features - Enable or Disable
    How to Enable or Disable Programs and Features in Windows 7
    Programs and Features - Remove Uninstall Entry
    How to Remove an Uninstall Entry in Programs and Features for Vista, Windows 7, and Windows 8
    Program and Features - Restore Uninstall Confirmation Prompt
    How to Restore the Uninstall Confirmation Prompt in Programs and Features
    Programs and Features - Uninstall, Change, or Repair a Program
    How to Uninstall, Change, or Repair a Program in Windows 7 and Windows 8
    Programs - Create "Install Program from Network" Shortcut
    How to Create a "Install Program from Network Shortcut" in Windows 7
    Programs - Pin to Taskbar - Enable or Disable
    How to Enable or Disable Windows 7 Taskbar Pinned Programs
    Programs - Prevent Running Specified Applications
    How to Prevent Users from Running Specified Programs in Windows
    Programs - Run Only Specified Applications in Windows
    How to Allow Users to Run Only Specified Programs in Windows
    Programs - Start Multiple at Once Using a BAT File
    How to Use a Batch File to Run Multiple Programs
    "Programs still need to close" - Specify WaitToKillAppTimeout for Shutdown
    How to Specify WaitToKillAppTimeout to Speed Up Shut Down Time in Windows
    Programs - Uninstall using Command Prompt in Windows
    How to Uninstall Programs using Command Prompt in Windows
    Programs - Uninstall with Revo Uninstaller Freeware
    How to Uninstall Programs and their Leftovers using Revo Uninstaller Freeware
    Project My Screen in Windows Phone 8.1 to PC
    How to "Project My Screen" in Windows Phone 8.1 to a Windows PC
    Project My Screen Touch Dot in Windows Phone 8.1
    How to Turn On or Off Project My Screen Touch Dot in Windows Phone 8.1
    Projector - Create "Connect to a Network Projector" Shortcut
    How to Create a "Connect to a Network Projector" Shortcut in Windows 7
    Properties - Add or Remove from Computer Context Menu
    How to Add or Remove "Properties" from Computer Context Menu
    Properties - Add or Remove from Recycle Bin Context Menu
    How to Add or Remove "Properties" from Recycle Bin Context Menu in Windows
    PST Data Files - Backup
    How to Backup Outlook PST Data Files
    PST Data File - Move
    How to Move your Outlook PST Data File to a New Location
    PST File Corrupted - Repair
    How to Repair a Corrupted Outlook PST File
    PSU - Jump Start
    How to Jump Start a Power Supply to Create a Test PSU
    PSU - Test DC Output Voltage
    How to Test PSU DC Output Voltages to Determine if Faulty
    Public Folder Sharing - Turn On or Off in Windows 7
    How to Turn Public Folder Sharing On or Off in Windows 7
    Public Folders - Restore
    How to Restore the Windows 7 Public Folders
  4. Posts : 72,052
       #43
    Windows 7 Tutorial Index - Q (1 of 1)
    Q:
    Quick Launch - Add to "Send to" Context Menu in Windows 8
    How to Add Quick Launch to the "Send to" Context Menu in Vista, Windows 7, and Windows 8
    Quick Launch - Enable or Disable
    How to Enable or Disable Quick Launch in Windows 7
    Quota Entries for Disk - Export and Import
    How to Export and Import User Disk Quota Entries in Windows
    Quota for Disk - Set Space Limits for Users
    How to Set Disk Quota Limits for Users in Windows
  5. Posts : 72,052
       #44
    Windows 7 Tutorial Index - R (1 of 3)
    R:
    Ralink based Belkin Network Adapters - Install
    How to Install Ralink based Belkin Network Adapters
    RAM - Change (Laptop)
    How to Change Ram in a laptop
    RAM Disk - Install for Browser Cache File Storage
    How to Install a RAM Disk for Browser Cache File Storage
    RAM - Set Maximum Amount Used by Windows
    How to Set Maximum Memory to be Used by Windows 7 and Windows 8
    RAM - Test with Memtest86+
    How to Test and Diagnose RAM Issues with Memtest86+
    Read-only - Add "List Read-only Files" to Context Menu
    How to Add "List Read-only Files" to Context Menu in Vista, Windows 7, and Windows 8
    Read-only - Add "Set and Unset as Read-only" to File and Folder Context Menu
    How to Add "Set and Unset as Read-only" to File and Folder Context Menu in Windows 7 and 8
    Read-only File and Folder Attribute
    How to Set and Unset the Read-only File and Folder Attribute in Vista, Windows 7, and Windows 8
    Read-only for Disk - Enable or Disable in Windows
    How to Enable or Disable Write Protection for a Disk Drive in Windows
    ReadyBoost - Setup and Use
    How to Setup and Use ReadyBoost in Windows 7
    Recent Items and Documents - Clear on Exit of Windows 7
    How to Clear Recent Items and Documents on Exit of Windows 7
    Recent Items - Change Default Icon in Start Menu
    How to Change the Default "Recent Items" Icon in the Windows 7 Start Menu
    Recent Items - Change Maximum Number to Display in Start Menu
    How to Change the Maximum Number of Recent Items to Display in Start Menu
    Recent Items - Change Number to Display in Jump Lists
    How to Change the Number of Recent Items to Display in Windows 7 Jump Lists
    Recent Items - Enable or Disable
    How to Enable or Disable Recent Items in Vista, Windows 7, and Windows 8
    Recent Items List - Clear
    How to Clear Recent Items List in Windows 7
    Recent Items - Reset and Clear All Items in Jump Lists
    How to Reset and Clear All Items in Windows 7 Jump Lists
    Recent Items - Turn On or Off
    How to Turn Recent Items On or Off in Windows 7
    Recent Programs - Enable or Disable
    How to Enable or Disable Recent Programs in Windows 7
    Recent Programs - Turn On or Off
    How to Turn Recent Programs On or Off in Windows 7
    Recent Search Box Suggestions - Edit or Reset
    How to Edit or Reset Windows 7 Explorer Recent Search Box Suggestions
    Recent Search Box Suggestions - Enable or Disable
    How to Enable or Disable Windows 7 Explorer Recent Search Box Suggestions
    Recording Audio Troubleshoot Shortcut - Create
    How to Create a "Recording Audio Troubleshoot" Shortcut in Windows 7
    Recording Shortcut - Create
    How to Create a "Recording Sound" Shortcut in Windows 7
    Record "What U Hear" - Enable
    How to Enable Whut U Hear Recording
    Recovery Option - Enable or Disable
    How to Disable the "Recovery" Option in Windows 7
    Recovery Partition - Create
    How to Create a Windows 7 Recovery Partition
    Recovery Shortcut - Create
    How to Create a "System Recovery" Shortcut in Windows 7
    Recycle Bin - Add "Empty Recycle Bin" to Desktop Context Menu
    How to Add "Empty Recycle Bin" to Desktop Context Menu in Windows 7 and Windows 8
    Recycle Bin - Add or Remove from Desktop Context Menu
    How to Add or Remove "Recycle Bin" from Desktop Context Menu
    Recycle Bin - Add or Remove from Navigation Pane
    How to Add or Remove the Recycle Bin from the Windows 7 Navigation Pane
    Recycle Bin - Add to Favorites in Navigation Pane
    How to Add or Remove Recycle Bin from Favorites in Navigation Pane in Windows
    Recycle Bin - Change or Restore Default Icon
    How to Change or Restore Default Windows 7 Desktop Icons
    Recycle Bin Corrupted - Fix in Windows
    How to Fix Corrupted Recycle Bin in Windows 7, Windows 8, and Windows 10
    Recycle Bin Delete Confirmation Dialog Prompt Details - Customize in Windows
    How to Customize Delete Confirmation Dialog Prompt Details in Windows
    Recycle Bin Delete Confirmation - Turn On or Off
    How to Turn the Recycle Bin Delete Confirmation On or Off in Windows
    Recycle Bin - Fix For Custom Icons Not Refreshing
    How to Fix Custom Icons For the Recycle Bin Not Automatically Refreshing in Windows 7
    Recycle Bin - Fix for Default Icon Not Refreshing
    How to Fix the Recycle Bin Icon Not Refreshing When Emptied
    Recycle Bin Icon - Allow or Prevent to Display
    How to Allow or Prevent the Windows 7 Recycle Bin Icon to Display
    Recycle Bin - Permanently Delete Items Automatically
    Set Recycle Bin to Permanently Delete Items Immediately in Windows
    Recycle Bin - Pin to Taskbar
    How to Pin the Recycle Bin to the Windows 7 Taskbar
    Recycle Bin Properties - Add or Remove
    Refresh Rate of Screen - Custom for NVIDIA Brand
    How to Create a Custom Screen Refresh Rate with NVIDIA Control Panel in Windows
    Recycle Bin Storage Size - Change
    How to Change Recycle Bin Maximum Storage Size in Vista, Windows 7, and Windows 8
    Refresh Rate of Screen - Display Settings
    How to Change the Screen Refresh Rate in Windows 7 and Windows 8
    REG files - Convert to BAT files
    How to Convert Registry Files to their Batch File Equivalents
    Region and Language "Administrative" Tab - Add or Remove
    How to Add or Remove the "Administrative" Tab in Region and Language
    Region and Language - Change Numbers and Measurements Format
    How to Change Numbers and Measurements Format in Windows 7 and Windows 8
    Region and Language - Change Regional Format Language
    How to Change the Regional Format Language in Windows 7 and Windows 8
    Region and Language "Formats" Tab - Add or Remove
    How to Add or Remove the "Formats" Tab in Region and Language
    Region and Language "Location" Tab - Add or Remove
    How to Add or Remove the "Location" Tab in Region and Language
    Region and Language - Restore Default Formats
    How to Restore the Default Regional Format Settings in Windows 7 and Windows 8
    Region and Language Settings - Copy to New Users and Welcome Screen
    How to Copy Your Region and Language Settings to New Users and Welcome Screen
    Region and Language Shortcut - Create
    How to Create a "Region and Language" Shortcut in Windows 7
    Register and Unregister Context Menu for DLL and OCX Files
    How to Add a Register and Unregister Context Menu to DLL and OCX Files in Windows
    Registered Owner and Organization - Change
    How to Change Registered Owner and Organization Information in Vista, Windows 7, and Windows 8
    Registry - Backup and Restore
    How to Backup and Restore the Registry in Windows 7 and Vista
    Registry Editor - Add to Control Panel
    How to Add or Remove Registry Editor from the Vista and Windows 7 Control Panel
    Registry Editor - Enable or Disable
    How to Enable or Disable Regedit in Vista and Windows 7
    Registry Editor - Find and Find Next
    How to Use "Find and Find Next" in Registry Editor in Vista, Windows 7, and Windows 8
    Registry Favorites - Add or Remove in Windows
    How to Add, Remove, Export, and Merge Registry Favorites in Windows
    Registry File - Add to "New" Context Menu
    How to Add "New Registry File" to the Context Menu in Windows
    Registry Key, File, Folder, or Drive - Take Ownership of
    How to Take Ownership of a Item in Vista and Windows 7
    Reliability Monitor
    View Reliability and Problem History with Reliability Monitor in Windows 7 and Windows 8
  6. Posts : 72,052
       #45
    Windows 7 Tutorial Index - R (2 of 3)
    R:
    Reliability Monitor - Reset
    How to Reset the Reliability Monitor in Windows 7 and Windows 8
    Reliability Monitor Shortcut
    How to Create a "Reliability Monitor" Shortcut in Windows 7 and Windows 8
    RemoteApp and Desktop Connections Shortcut - Create
    How to Create a "RemoteApp and Desktop Connections" Shortcut in Windows 7 and Windows 8
    Remote Assistance Shortcut - Create
    How to Create a "Windows Remote Assistance" Shortcut in Windows 7 and 8
    Remote Assistance - Use in Windows
    How to Use Windows Remote Assistance in Windows 7, 8, and 8.1
    Remote Computer Clients - Uninstall Product Key Number and Deactivate Windows
    How to Uninstall the Product Key Number or Deactivate Windows 7 and Vista
    Remote Desktop Connection Automatic Log On - Allow or Prevent
    Allow or Prevent Remote Desktop Connection Clients to Automatically Log On to Host Computer
    Remote Desktop Connection Automatic Log On - Turn On or Off
    How to Turn On or Off Automatic Log On for a Remote Desktop Connection
    Remote Desktop Connection - Clear History in Windows
    How to Reset and Clear Remote Desktop Connection History in Windows 7 and Windows 8
    Remote Desktop Connection Credentials - Delete in Windows
    How to Delete Credentials of a Remote Desktop Connection in Windows 7 and Windows 8
    Remote Desktop Connection (RDC) - Network
    How to Enable Windows to Make and Accept a Remote Desktop Connection
    Remote Desktop Connection Settings - Save to RDP File in Windows
    How to Save Remote Desktop Connection Settings to RDP File in Windows 7, Windows 8, and Windows 10
    Remote Desktop Connection Shortcut - Create for Specific Computer
    How to Create a "Remote Desktop Connection" Shortcut to a Specific Computer
    Remote Desktop - Set Time Limit for Active Sessions
    How to Set Time Limit for Active Remote Desktop Sessions
    Remote Desktop - Set Time Limit for Idle Sessions
    How to Set Time Limit for Idle Remote Desktop Sessions
    Remote Desktop - Terminate Session when Time Limits are Reached
    How to Terminate Remote Desktop Session when Active or Idle Time Limits are Reached
    Remote Desktop Users - Add or Remove in Windows
    How to Add or Remove Remote Desktop Users in Windows 7, Windows 8, and Windows 10
    Remote Server Administration Tools for Windows
    Download Remote Server Administration Tools (RSAT) for Windows
    Remote Shutdown Dialog Shortcut - Create
    How to Create a "Remote Shutdown Dialog" Shortcut
    Remote System Properties Shortcut - Create
    Create a "Remote System Properties" Shortcut in Vista, Windows 7, and Windows 8
    Removable Drives - Allow or Deny All Access
    How to Deny or Allow Access to All Removable Drives in Vista and Windows 7
    Removable Hard Disk Drives - Allow or Deny Read and Write Access
    How to Deny or Allow Read and Write Access to Removable Hard Drives in Vista and Windows 7
    Removable Media Shortcuts
    How To Place Removable Media Shortcuts in Windows 7
    Remove Background Images (where available)
    How to Remove Background Images to have Only Solid Colors (Black screen) in Windows 7
    Rename File and Folder in Command Prompt
    How to Rename a File and Folder from the Command Prompt
    Repair Install
    How to Do a Repair Install to Fix Windows 7
    Reset Permissions Context Menu - Add in Windows
    How to Add Reset Permissions to Context Menu in Windows 7, Windows 8. and Windows 10
    Resource Monitor
    How to Open Resource Monitor in Windows 7 and Windows 8
    Resource Monitor - Troubleshoot Unresponsive Program
    How to Use Resource Monitor to Troubleshoot Unresponsive Applications in Windows 7 and Windows 8
    Resource Monitor - View Handles and Modules
    How to Use Resource Monitor to View Handles and Modules in Windows 7 and Windows 8
    Restart - Add to Desktop Context Menu
    How to Add "Restart" Computer to the Desktop Context Menu in Windows 7
    Restart Automatically on System Failure - Enable or Disable
    How to Enable or Disable Automatic Restart on System Failure in Windows
    Restart Computer - Allow or Prevent Users and Groups
    How to Allow or Prevent Users and Groups to Hibernate, Restart, Shut Down, and Sleep the PC
    Restart Computer Shortcut - Create
    How to Create a "Restart Computer" Shortcut in Windows
    Restart - Perform an Emergency Restart in Windows
    How to Perform an Emergency Restart in Vista, Windows 7, and Windows 8
    Restart, Shut Down, Sleep, and Hibernate Commands - Add or Remove
    How to Add or Remove the Shut Down, Restart, Sleep, and Hibernate Commands in Windows 7
    Restart Time of Windows 7
    How to See What Your Windows Restart Time is
    Restart - View Details of Last Shutdown and Restart of Computer
    How to See the Last Shutdown and Restart Time of Your Vista, Windows 7, or Windows 8 PC
    Restore Backup Files - Enable or Disable
    How to Enable or Disable Restoring Backup Files in Windows 7
    Restore Backup User and System Files
    How to Restore Backup User and System Files in Windows 7
    Restore Backup User and System Files - Create Shortcut
    How to Create a "Restore Backup User and System Files" Shortcut in Windows 7 and Windows 8
    Restore Files from Selected Backup Location - Create Shortcut
    How to Create a "Restore Files from Selected Backup Location" Shortcut
    Restore Point - Add "Create Restore Point" to Context Menu in Windows
    How to Add "Create Restore Point" to Context Menu in XP, Vista, Windows 7, and Windows 8
    Restore Point Automatic Creation - Disable in Windows
    How to Enable or Disable Automatic System Restore Point Creation in Windows
    Restore Point - Create
    How to Create a System Restore Point in Windows 7
    Restore Point : Create at System Startup
    How to Automatically Create A System Restore Point at Startup
  7. Posts : 72,052
       #46
    Windows 7 Tutorial Index - R (3 of 3)
    R:
    Restore Point Shortcut
    How to Make a "Create System Restore Point" Shortcut in XP, Vista, Windows 7, and Windows 8
    Restore Points - Delete
    How to Delete System Protection Restore Points in Windows 7
    Restore Points - Manually Extract Files and Folders
    How to Extract Files and Folders from System Restore Points in Windows 7 and Vista
    Restore Points - Stop XP Dual Boot Delete
    How to Stop System Restore Points from being Deleted in Vista and Windows 7 when Dual Booting with XP
    Restore Previous Folder Windows at Logon
    How to "Restore Previous Folder Windows at Logon"
    Revo Uninstaller Freeware - Uninstall Programs
    Ribbons Screen Saver - Change Settings
    How to Change the Ribbons Screen Saver Settings in Windows 7 and Windows 8
    Right Click using Keyboard in Windows
    How to Right Click using Keyboard in Windows 7, Windows 8, and Windows 10
    ROBOCOPY - Create Backup Script
    How to Create a Backup Script Using the ROBOCOPY Command
    Rocketdock - Create Office Toolbar
    How to Use Rocketdock to Create an Office Toolbar
    Router - Configure Multi Router Network
    How to Set Up a Network Using 2 (or more) Routers
    Router - Find IP Address to Log into with
    How to Find the IP Address to Log into a Router
    RSS Feeds - Import and Export in Internet Explorer
    How to Import and Export RSS Feeds in Internet Explorer
    RSS Feeds - Setup Windows Media Center to Read
    How to Read RSS Feeds with Windows Media Center
    RSS Feeds - Subscribe or Unsubscribe in Internet Explorer
    How to Subscribe or Unsubscribe to a RSS Feed in Internet Explorer
    Run as Administrator
    How to Run a Program as an Administrator in Windows 7
    Run as Administrator - Add or Remove from Context Menu in Windows
    How to Add or Remove "Run as Administrator" from Context Menu in Windows 7 and Windows 8
    Run as administrator - Add to MSI File Context Menu
    How to Add "Run as administrator" to MSI File Context Menu
    Run as administrator - Add to VBS File Context Menu
    How to Add "Run as administrator" to VBS File Context Menu
    "Run as administrator" Program Shortcut - Create for Standard User
    How to Create a Elevated Program Shortcut a Standard User is able to Run in Windows 7
    "Run as administrator" Program Shortcut without UAC Prompt - Create
    Run as administrator - See if Process is Running Elevated
    How to Run a Program as a Different User in Windows 7 and Windows 8
    Run as Different User - Add or Remove from Context Menu
    How to Add or Remove "Run as Different User" from Context Menu in Windows 7 and Windows 8
    Run as Different User - See Run as User Name for Program
    How to See What User Name a Program is Running As in Windows 7
    Run as Different User - With or Without Shift+Right Click Context Menu
    How to Use "Run as different user" Context Menu Item With or Without Shift+Right Click
    Run "Auto Suggest" History - Delete in Windows
    How to Delete your Run Dialog Auto Suggest History in Windows
    Run - Change Default Icon in Start Menu
    How to Change the Default "Run" Icon in the Windows 7 Start Menu
    Run Command - Add or Remove from Start Menu
    How to Add or Remove Run Command from the Windows 7 Start Menu
    Run Command - Add "Run in Separate Memory Space"
    Add "Run in Separate Memory Space" to Windows 7 Run Command
    Run Command - Create Shortcut
    How to Create a "Run" Command Dialog Box Shortcut in Windows 7 and Windows 8
    Run Command - Enable or Disable
    How to Enable or Disable Run Command Box in Windows 7
    Run Commands - Create
    How to Create Custom Run Commands
    Run Commands for Windows 7
    A List of Run Commands for Windows 7
    "Run" Dialog Auto Suggest - Turn On or Off
    How to Turn Auto Suggest On or Off in Run and Windows Explorer
  8. Posts : 72,052
       #47
    Windows 7 Tutorial Index - S (1 of 6)
    S:
    Safe Internet Browsing
    How to safely operate on the internet and stay free from malware infections
    Safe Mode
    How to Start Windows 7 in Safe Mode
    Safe Mode - Add to Desktop Context Menu in Windows
    How to Add "Safe Mode" to Desktop Context Menu in Windows 7 and Windows 8
    Safe Mode - Add to Windows Boot Manager Screen in Windows 7
    How to Add Windows 7 "Safe Mode" to Windows Boot Manager Screen
    Safe Mode with Command Prompt - Add to Windows Boot Manager Screen
    How to Add Windows 7 "Safe Mode with Command Prompt" to Windows Boot Manager Screen
    Safe Mode with Networking - Add to Windows Boot Manager Screen
    How to Add Windows 7 "Safe Mode with Networking" to Windows Boot Manager Screen
    SafeHouse Explorer - Create Password Protected USB
    How to Create Password Protected USB Flash Drive with SafeHouse Explorer
    Safely Remove Hardware - Add to Desktop Context Menu
    How to Add "Safely Remove Hardware" to the Desktop Context Menu
    Safely Remove Hardware - Eject Device
    How to Use Safely Remove Hardware to Eject a Device in Windows 7 and Windows 8
    Safely Remove Hardware Shortcut - Create
    How to Create a "Safely Remove Hardware" Shortcut in Vista, Windows 7, and Windows 8
    SATA Driver - Load in Windows 7 or Vista Setup
    How to Load SATA Driver in Windows 7 or Vista Setup
    SATA Driver - Load in Windows Recovery Options
    How to Load SATA Driver in Windows System Recovery Options
    SATA Driver - Load in Windows System Image Recovery
    How to Load SATA Drivers in Windows System Image Recovery
    SATA Driver - Load in Windows XP Setup on Dual Boot
    How to Load SATA Driver in Windows XP Setup on Dual Boot PC
    SATA Driver - Load Using Shift+F10 to Open CMD
    How to Load SATA Driver Using Shift+F10 to Open Command Prompt
    SATA Driver - Slipstream into Windows XP CD
    How to Slipstream SATA driver into Windows XP setup CD with Dual Boot of Windows 7 or Vista
    SATA DVD CD Drive - How to Install
    How to Install a SATA DVD CD Drive in a Desktop PC
    SATA Hard Drive - How to Install and Setup
    How to Install and Setup a SATA Hard Drive
    Save a Search
    How to Save a Search in Windows 7 and Windows 8
    Save As and Open Common Item Dialog Boxes - Reset in Windows
    How to Reset Open and Save As Common Item Dialog Boxes to Default in Windows
    Save Taskbar Thumbnail Previews - Enable or Disable
    How to Enable or Disable "Save Taskbar Thumbnail Previews" in Windows 7
    Scan and Fix Removable Disk Prompt - Disable in Windows
    How to Disable "Do you want to scan and fix Removable Drive" Prompt in Windows
    "Scan with Microsoft Security Essentials" - Add or Remove Context Menu
    How to Add or Remove "Scan with Microsoft Security Essentials" from Context Menu in Windows
    Scanner and Camera Installation Wizard
    How to Open and Use the "Scanner and Camera Installation Wizard" in Windows 7 and Windows 8
    Scanner - Create a "Windows Fax and Scan" Shortcut
    How to Create a "Windows Fax and Scan" Shortcut in Windows 7
    Scanners and Cameras Shortcut - Create
    How to Create a "Scanners and Cameras" Shortcut in Windows 7 and Windows 8
    Screen Capture and Video Editing in High Quality
    Screen Orientation Sequence Settings - Change in Windows
    How to Change Screen Orientation Sequence Settings in Windows
    Screen Refresh Rate - Custom for NVIDIA Brand
    Screen Refresh Rate - Display Settings
    Screen Resolution - Add or Remove from Desktop Context Menu
    How to Add or Remove "Screen resolution" from Desktop Context Menu in Windows
    Screen Resolutions and Refresh Rates - Force with DVI or HDMI
    How to Force DVI or HDMI Resolutions and Refresh Rates in Windows 7
    Screen Resolution - Display Settings
    How to Change the Screen Resolution in Windows 7
    Screen Resolution Display Settings - Enable or Disable
    Enable or Disable Changing "DPI" and "Screen Resolution" Display Settings in Windows 7 and Windows 8
    Screen Resolution Shortcut - Create
    How to Create a Windows 7 "Screen Resolution" Shortcut
    Screen Saver - Allow or Prevent Changing
    How to Allow or Prevent Changing Screen Saver in Windows 7 and Windows 8
    How to Change the Screen Saver in Windows 7 and Windows 8
    Screen Saver - Change Aurora Settings
    How to Change "Aurora Screen Saver" Settings in Windows 7 and Windows 8
    Screen Saver - Change Bubbles Settings
    How to Change the Bubbles Screen Saver Settings in Windows 7 and Windows 8
    Screen Saver - Change Mystify Settings
    How to Change the Mystify Screen Saver Settings in Windows 7 and Windows 8
    Screen Saver - Change Ribbons Settings
    Screen Saver - Enable or Disable
    How to Enable or Disable Screen Savers in Vista, Windows 7, and Windows 8
    Screen Saver - Enable or Disable at Log On
    How to Enable or Disable the Windows 7 Log On Screen Saver
    Screen Saver Grace Period to Bypass Password - Change in Windows
    How to Change Screen Saver Grace Period to Bypass Password Protection in Windows
    Screen Saver Password Protection - Enable or Disable
    How to Enable or Disable Screen Saver Password Protection in Windows 7 and Windows 8
    Screen Saver - Restore Aurora
    How to Restore "Aurora Screen Saver" Back in Windows 7 and Windows 8
    Screen Saver - Restore Windows Energy
    How to Restore "Windows Energy Screen Saver" Back in Windows 7 and Windows 8
    Screen Saver - Restore Windows Logo
    How to Restore "Windows Logo Screen Saver" Back in Windows 7 and Windows 8
    Screen Saver Settings Shortcut - Create
    How to Create a "Screen Saver Settings" Shortcut in Vista, Windows 7, and Windows 8
    Screen Saver Shortcut - Create in Windows
    How to Create a Screen Saver Shortcut in Vista, Windows 7, and Windows 8
    Screen Saver - Specify a Default for All Users
    How to Specify a Default Screen Saver for All Users in Windows 7
    Screen Saver Timeout Period - Set or Change
    How to Set or Change the Screen Saver Timeout Period in Windows 7
    Screen Saver - Toggle On or Off - Add to Desktop Context Menu
    How to Add "Enable/Disable Screen Saver" to Desktop Context Menu
    Screen Saver - Turn On or Off
    How to Turn Screen Saver On or Off in Windows 7
    Screenshot - Create with Media Player Classic
    How to Create a Screenshot Using Media Player Classic
    Screenshot using MWSnap
    Screenshot with Paint
    How to Take and Create a Screenshot with Windows 7 Paint
    How to Upload and Post a Screenshot and File in Seven Forums
    Scroll Lock - Num Lock - Caps Lock - Enable or Disable at Windows Startup
    How to Enable or Disable a Toggle Key at Startup in Vista, Windows 7, and Windows 8
    Search - Add or Remove from "My Computer" Context Menu
    How to Add "Search" to "My Computer" Context Menu in Vista and Windows 7
    Search - Add to Context Menu in Windows 7 and Windows 8
    How to Add "Search" to Context Menu in Windows 7 and Windows 8
    Search and Indexing Troubleshoot Shortcut - Create
    How to Create a "Search and Indexing Troubleshoot" Shortcut in Windows 7
    Search Box Recent Suggestions - Edit or Reset
    Search Box Recent Suggestions - Enable or Disable
    Search - Configure and Use in Windows 7
    How to Configure and Fully Utilize Windows 7 Search
    Search Engine Shortcut - Create
    How to Create a Shortcut to Search the Web for a File/Folder Name from Windows Explorer
    Search Federation Providers
    Windows 7 OpenSearch Federation Providers
    Search - Find More with Filters and Operators
    How to Use Windows Search Filters and Operators to get better Search Results in Windows 7
    Search from Internet Explorer 8 Address Bar
    How to Enable or Disable Search from Internet Explorer 8 Address Bar
    Search - Have More Accurate Search Results
    How to Have More Accurate Search Results in Windows 7 and Vista
    Search in Windows 7
    How to Search in Windows 7
  9. Posts : 72,052
       #48
    Windows 7 Tutorial Index - S (2 of 6)
    S:
    Search Indexer Backoff - Enable or Disable in Windows 7
    How to Enable or Disable Search "Indexer Backoff" in Windows 7
    Search Indexing - Enable or Disable in Windows
    How to Enable or Disable Search Indexing in Windows 7, Windows 8, and Windows 10
    Search Inside Certain File Types with Indexing Disabled
    Search Internet Link - Add or Remove from Start Menu
    How to Add Search Internet to the Windows 7 Start Menu
    Search Options - Change or Restore
    How to Change or Restore Default Search Options in Windows 7 and Windows 8
    Search - Save in Windows 7 and Windows 8
    Search Shortcut - Create
    How to Create a Search Shortcut in Windows 7
    Search - Turn On or Off
    How to Turn Search On or Off in Windows 7
    Searches Library - Create
    How to Create a "Searches" Library with Correct Icon in Windows 7 and Windows 8
    SeaTools for DOS and Windows - How to Use
    How to Use SeaTools for DOS and Windows Disk Check Utility
    Secure and Lock down Computer against Unauthorised Access
    How to secure and Lock down your Computer against unauthorised access
    Secure Boot - Enable or Disable in UEFI
    How to Enable or Disable Secure Boot in UEFI
    Secure Erase / Wipe : Definition and Methods
    What is a Secure Erase / Wipe and How To Do One
    Secure Logon - Press CTRL + ALT + DELETE to log on
    How to Enable or Disable Secure Logon CTRL+ALT+DELETE in Windows 7
    Security Policy Editor - Open
    How to Open the Local Security Policy Editor in Windows 7 and Windows 8
    Security Tab - Add or Remove from Properties
    How to Add or Remove the Security Tab from Properties in Vista, Windows 7, and Windows 8
    Select all - Add to Context Menu in Windows 7
    How to Add "Select all" to the Context Menu in Windows 7
    Select Items with Check Boxes in Windows Explorer
    How to Select Items with Check Boxes in Windows 7
    Select more then 15 Items - Fix Missing Context Menu Items
    Selection Rectangle - Turn Translucent On or Off
    How to Turn On or Off "Translucent Selection Rectangle" in Vista, Windows 7, and Windows 8
    Send to - Add or Remove from Context Menu
    How to Add or Remove "Send to" from Context Menu
    Send To Context Menu - Add "Google Drive"
    How to Add Google Drive to "Send To" Context Menu in Windows
    Send To Context Menu - Add "Quick Launch" in Windows
    Send To Context Menu - Customize
    How to Customize the Send To Context Menu in Vista, Windows 7, and Windows 8
    Send To Context Menu - Remove or Restore Default Items
    How to Remove and Restore Default "Send To" Context Menu Items in Windows 7 and Windows 8
    Send To Context Menu - Remove or Show Drives
    How to Remove or Show Drives in "Send To" Context Menu in Vista, Windows 7, and Windows 8
    Serial Number - Find for Windows PC
    How to Find Serial Number of Windows PC
    Serial Number of Hard Drive - Find in Windows
    How to Find Serial Number of Hard Drive in Windows 7, Windows 8, and Windows 10
    Service - Delete in Windows
    How to Delete a Service in Windows 7, Windows 8, and Windows 10
    Service Pack 1 (SP1) Beta, RC, and RTM for Windows 7 - Uninstall
    How to Uninstall Windows 7 Service Pack 1 (SP1) Beta, RC, and RTM
    Service Pack 1 (SP1) Disk Cleanup Tool
    How Use the Windows 7 SP1 Disk Cleanup Tool to Recover Lost Disk Space
    Services - Add or Remove from Control Panel
    How to Add or Remove "Services" from Control Panel in Windows
    Services - Customize View of Window
    How to Customize and Save the View in the Services Window in Windows 7
    Services MMC Snap-in - Enable or Disable
    How to Enable or Disable the Services MMC Snap-in
    Services - Restore Default Services in Windows 7
    How to Restore Default Services in Windows 7
    Services - Start or Disable
    How to Start or Disable Services in Windows 7
    "Set as desktop background" - Add or Remove in Windows
    How to Add or Remove "Set as desktop background" from Context Menu in Windows 7 and Windows 8
    Set Program Access and Computer Defaults - Enable or Disable
    How to Enable or Disable the "Set Program Access and Computer Defaults" Page
    Set Program Access and Computer Defaults Shortcut - Create
    How to Create a "Set Program Access and Computer Defaults" Shortcut in Windows
    "Set up a Network" Wizard Shortcut - Create
    How to Create a "Set up a Network" Wizard Shortcut in Windows 7
    How to Repair Windows 7 System Files with System File Checker
    SFC /SCANNOW : Run in Command Prompt at Boot
    How to Run the System File Checker in a Command Prompt at Boot
    SF Diagnostic Tool - Using for Troubleshooting
    Using SF Diagnostic Tool for Troubleshooting
    SF IE Restorator - Troubleshooting General Issues with IE
    Shadow Copies - Delete
    How to Delete Shadow Copies in Vista and Windows 7
    Shadow Copies - "Previous Versions" - Hide or Show from Backup Location
    Shadow Copies - "Previous Versions" - Hide or Show from File Shares
    Shadow Copies - "Previous Versions" - Restore Files and Folders
    Shadow Copies - "Previous Versions" Tab - Restore or Remove from Properties
    ShadowExplorer - Recover Lost Files and Folders
    How to Recover Lost Files and Folders with ShadowExplorer
    Shared Folder Creation Wizard Shortcut - Create
    How to Create a "Shared Folder Creation Wizard" Shortcut in Windows 7 and Windows 8
    Shared Folders - Audit (log) Access
    How to Audit User Access to Shared Folders on Your Computer
    Shared Folders Shortcut - Create in Windows
    How to Create a Shared Folders Shortcut in Vista, Windows 7, and Windows 8
    Shared Folders Troubleshoot Shortcut - Create
    How to Create a "Shared Folders Troubleshoot" Shortcut in Windows 7
    Share with - Restore when Missing in Context Menu
    How to Add or Remove "Share with" Context Menu Item in Windows 7 and Windows 8
    SHARING PCs AND PRINTERS ON WIN 7 AND WIN 98 NETWORK
    Shell Command
    How to Use and See All Windows 7 Shell Commands
  10. Posts : 72,052
       #49
    Windows 7 Tutorial Index - S (3 of 6)
    S:
    Shortcut Arrow - Change, Remove, or Restore
    How to Change, Remove, or Restore the Shortcut Arrow Overlay Icon in Windows
    Shortcut - Assign Keyboard Shortcut To
    How to Create a Keyboard Shortcut for a Program in Vista and Windows 7
    Shortcut - Change Icon
    How to Change the Icon of a Shortcut in Vista, Windows 7, and Windows 8
    Shortcut - Create Custom Comment Pop-up Description in Windows
    How to Create a Custom Shortcut Comment Pop-up Description in Windows
    Shortcut - Create for a File, Folder, Drive, or Program in Windows
    Shortcut - Create with Relative Path
    How to Create Shortcut with Relative Path
    Shortcut Extension - Remove or Restore
    How to Remove or Restore the "Shortcut" Name Extension in Windows 7 and Windows 8
    Shortcut Keys for Windows 7
    A List of Shortcut Keys for Windows 7
    Shortcut Name Extension Template - Change in Windows
    How to Change Default Shortcut Name Extension Template in Windows 7, 8, and 10
    Shortcut - Open Normal window, Minimized, or Maximized
    Always Open Shortcut Minimized, Maximized, or Normally in Vista, Windows 7, and Windows 8
    Shortcut or Folder Icon - Hide
    How to Hide a Folder or Shortcut Icon in Vista and Windows 7
    Shortcut Tooltip Details - Customize in Windows
    How to Customize Details of Shortcut Tooltips in Windows
    Show Desktop
    How to Use Show Desktop in Windows 7
    "Show Desktop" Shortcut - Create
    How to Create a "Show Desktop" Shortcut in Windows 7 and Windows 8
    Show - Hide Hidden Files - Add to Context Menu
    How to Add "Show/Hide Hidden Files" to Context Menu in Vista and Windows 7
    Show - Hide Known File Extensions - Add to Context Menu
    Add "Show/Hide Known File Extensions" to Context Menu in Vista, Windows 7, and Windows 8
    Show Translucent Selection Rectangle
    How to Turn the "Translucent Selection Rectangle" On or Off in Windows 7 and Vista
    Show Window Contents or Outline While Dragging
    Show Window Contents or Outline While Dragging in Vista, Windows 7, and Windows 8
    "Show Windows Stacked" or "Show Windows Side by Side" - Create Shortcuts
    How to Create a Shortcut for "Show Windows Stacked" or "Show Windows Side by Side"
    Shut Down - Add to Desktop Context Menu
    How to Add "Shut Down" Computer to the Desktop Context Menu in Windows 7
    Shut Down Computer - Allow or Prevent Users and Groups
    How to Allow or Prevent Users and Groups to Shut Down the Computer
    Shut Down Computer Shortcut - Create
    How to Create a Force "Shut Down Computer" Shortcut in Windows
    Shut Down - Enable or Disable Shut Down without Logging On
    How to Enable or Disable Shut Down without Having to Log On
    Shut Down PC Automatically Task - Create in Task Scheduler
    How to Create a Task that will Shut Down the PC Automatically
    Shut Down, Restart, Sleep, and Hibernate Commands - Add or Remove
    Shut Down - Speed Up
    How to Set WaitToKillServiceTimeout to Speed Up Shut Down Time in Windows
    Shut Down - View Details of Last Shutdown of Computer
    Shut Down Windows Alt+F4 Window - Change Default Action
    How to Change the Default Action of the Windows 7 Alt+F4 Shut Down Window
    Shut Down Windows - Change "Install Updates and Shut Down" as Default
    How to Change "Install Updates and Shut Down" as Default Choice in Shut Down Windows Dialog
    Shut Down Windows - Enable or Disable "Install Updates and Shut Down"
    Shut Down Windows Shortcut
    How to Create a "Shut Down Windows" Shortcut in Windows 7
    Shutting down... Text Message - Change
    How to Change the "Shutting down..." Text Message at Shut Down in Windows 7 and Vista
    SID (Security Identifier) of User - Find in Windows
    How to Find Security Identifier (SID) of User in Windows
    Sidebar - Vista Sidebar on Windows 7
    How to Reinstate the Vista Sidebar on Windows 7
    SideShow Shortcut - Create
    How to Create a "Windows SideShow" Shortcut in Windows 7
    Signature at SevenForums - Create with or without an Image
    How to Create a Signature at Seven Forums with or without an Image
    Single-Click Mode Point to Select - Enable or Disable
    Single-Click or Double-Click to Open an Item
    How to Open Items with a Single-Click or Double-Click in Windows 7 and Windows 8
    "SkyDrive" is now called "OneDrive"
    SkyDrive - Map Drive
    How to Map Windows Live Skydrive in Windows Explorer
    SkyDrive - Upload to from Windows 7 Desktop
    How to Upload to Windows Live SkyDrive from Windows 7 Desktop
    Sleep : Disable in Shut Down Menu
    Disable the Sleep Function in the Shut Down Menu
    Sleep Mode and Power Options Problems - Troubleshoot
    Sleep Return Timeout for Unattended Wake Up
    Sleep Shortcut - Create
    How to Create a "Sleep" Shortcut in Windows
    Sleep States - See Available Sleep States
    How to See Available Sleep States on Your System in Windows 7
    Slide show - Add to Context Menu in Windows
    How to Add Windows Photo Viewer "Slide show" to Context Menu in Windows 7 and Windows 8
    Slideshow
    How to Create a Desktop Slideshow in Windows 7
    Slideshow - Shuffle Images in Multiple Folders
    How to Have a Windows 7 Desktop Slideshow Shuffle Images in Multiple Folders
    Sliptream Office 2010 with Service Pack 1
    How to Slipstream Office 2010 with Service Pack 1 (SP1)
    Continued on next page......
