Windows 7 - Tutorial Index
Page 6 of 7 FirstFirst ... 4567 LastLast
  1. Posts : 72,050
       #50
    Windows 7 Tutorial Index - S (4 of 6)
    A - B - C - D - E - F - G - H - I - J - K - L - M - N - O - P - Q - R - S - T - U - V - W - X - Y - Z
    S:
    Slipstream Windows 7 SP1 into a Installation DVD or ISO File
    How to Slipstream Windows 7 SP1 and Updates to Create a Bootable USB, Installation DVD, or ISO File
    Slow Motion Aero Animation Effect - Enable
    How to Enable Slow Motion Effect with Aero in Windows
    Small Memory Dump Files - Configure Windows to Create on BSOD
    How to Configure Windows to Create a Dump File when you get a BSOD
    SMB1 File Sharing Protocol - Enable or Disable in Windows
    How to Enable or Disable SMB1 File Sharing Protocol in Windows 7, Windows 8, Windows 8.1, and Windows 10
    Smooth Edges of Screen Fonts - Enable or Disable
    How to Enable or Disable "Smooth Edges of Screen Fonts" in Windows
    Snap a Window to a Side
    How to Use Aero Snap to Snap a Window to a Screen Side in Windows 7
    SnapShot Sound for PrintScreen Key - Add or Remove in Windows
    How to Add or Remove SnapShot Sound for PrintScreen Key in Windows
    Snipping Tool
    How to use the Snipping Tool in Vista and Windows 7
    Snipping Tool - Enable or Disable in Windows
    How to Enable or Disable Snipping Tool in Windows 7, Windows 8, and Windows 10
    Solid Colors - Remove Background Images (where available)
    How to Remove Background Images to have Only Solid Colors in Vista and Windows 7
    Sort by - Group by - Arrange by - Change File and Folder View Arrangement
    How to Change the Group by, Sort by, and Arrange by Folder View in Windows 7 Explorer
    Sound - Create "Playback" Shortcut
    How to Create a "Playback Sound" Shortcut in Windows 7
    Sound - Create "Playing Audio Troubleshoot" Shortcut
    How to Create a "Playing Audio Troubleshoot" Shortcut in Windows 7
    Sound Recorder - Enable or Disable
    How to Enable or Disable "Sound Recorder" in Windows 7 and Vista
    Sound Recorder - Open and Use
    How to Open and Use Windows 7 Sound Recorder
    Sound Shortcuts - Create
    How to Create Sound Shortcuts in Windows 7 and Windows 8
    Sounds - Allow or Prevent Changing
    How to Allow or Prevent Changing Sounds in Windows 7 and Windows 8
    Sounds - Change
    How to Change the Event Sound Effects in Windows 7 and Windows 8
    Sounds - Custom "Windows Logon" that Speaks What You Like
    How to Create a Custom Logon Sound that Speaks What You Like
    SP1 (Service Pack 1) Beta, RC, and RTM - Uninstall
    How to Uninstall Windows 7 Service Pack 1 (SP1) Beta, RC, and RTM
    SP1 (Service Pack 1) Disk Cleanup Tool
    How Use the Windows 7 SP1 Disk Cleanup Tool to Recover Lost Disk Space
    SP1 (Service Pack 1) - Slipstream into a Installation DVD or ISO File
    How to Slipstream Windows 7 SP1 to Create a Bootable USB, Installation DVD, or ISO File
    Speccy - Advanced System Information Tool
    How to Use Speccy to View Your System Information in Windows
    Speccy - Publish Snapshot of your System Specs
    How to Use Speccy in Windows to Publish your Complete System Specifications
    Speech Recognition - Language Configuration is Not Supported Error Fix
    How to Fix the Speech Recognition "Language Configuration is Not Supported" Error
    Speech Recognition Shortcut - Create
    How to Create a "Speech Recognition" Shortcut in Windows 7
    Speed Up the Performance of Windows 7
    How to Speed Up the Performance of Windows 7
    SSD Alignment
    SSD / HDD : Optimize for Windows Reinstallation
    How to Ready an SSD to Re-Install an Operating System
    SSD - Install and Transfer the Operating System
    How to Physically Install a SSD and Transfer the Operating System
    SSD TRIM Support - Check and Enable or Disable
    How to Check and Enable or Disable SSD TRIM Support in Windows 7 and Windows 8
    SSD Tweaks and Optimizations in Windows 7
    Real world Windows 7 SSD tweaks and optimization
    Standalone System Sweeper
    How to Use the Microsoft Standalone System Sweeper
    Start Button - Create a Rectangular Start Button
    How to Create a New Rectangular Windows 7 Start Menu Button
    Start Menu - Add Libraries to Search in Start Menu
    How to Pin Libraries to Search and See More Results in Start Menu
    Start Menu - Add or Remove Run Command
    How to Add or Remove Run Command from the Windows 7 Start Menu
    Start Menu - Add or Remove Search Box
    How to Turn Windows 7 Search On or Off
    Start Menu - Add or Remove "Search" Button
    How to Add or Remove the Search Button in the Windows 7 Start Menu
    Start Menu - Add or Remove "See more results" Link in Search Box
    How to Add or Remove "See more results" Link in Start Menu Search Box
    Start Menu - Add Run Button
    How to Add the Run command Button to the Windows 7 Start Menu
    Start Menu - Add Search Connectors to Start Menu Search
    How to Pin Search Connectors to Search and See More Results in Start Menu
    Start Menu - Add Search Internet Link
    How to Add Search Internet to the Windows 7 Start Menu
    Start Menu All Programs - Add or Delete Shortcuts
    How to Add or Delete Start Menu All Programs Shortcuts in Windows 7
    Start Menu All Programs List - Enable or Disable
    How to Enable or Disable Start Menu "All Programs" in the Vista and Windows 7
    Start Menu All Programs in Windows 7 - Restore Default Shortcuts
    How to Restore Missing Default Shortcuts in the Windows 7 Start Menu
    Start Menu and Taskbar - Animations - Enable or Disable
    How to Enable or Disable Animations in the Taskbar and Start Menu of Windows 7
    Start Menu and Taskbar Properties - Enable or Disable
    How to Enable or Disable "Taskbar and Start Menu Properties" in Vista and Windows 7
    Start Menu Auto Arrange by Name - Enable or Disable
    How to Enable or Disable Start Menu Auto Arrange by Name in Vista and Windows 7
    Start Menu - Back Up and Restore Pinned Items in Windows 7
    How to Back Up and Restore Pinned Start Menu Items in Windows 7
    Start Menu Button - Change
    How to Change the Start Menu Button in Windows 7
    Start Menu - Change Descriptive Text Pop-up Information
    How to Change Start Menu Descriptive Text Pop-up Information in Vista and Windows 7
    Start Menu - Change Height
    How to Change the Height of the Windows 7 Start Menu
    Start Menu - Change Maximum Number of Recent Items to Display
    How to Change the Maximum Number of Recent Items to Display in Start Menu
    Start Menu - Change Number of Recent Programs to Display
    How to Change the Number of Recent Programs to Display in Windows 7 Start Menu
    Start Menu - Clear Recent Items List
    How to Clear Recent Items List in Windows 7
    Start Menu Common Program Groups - Add or Remove in Windows
    How to Add or Remove Common Program Groups from Start Menu in Windows 7, Windows 8, and Windows 10
    Start Menu "Computer" Context Menu - Add or Remove "Properties"
    How to Add or Remove "Properties" from Computer Context Menu
    Start Menu - "Connect To" Button - Change Default Icon
    How to Change the Default "Connect To" Icon in the Windows 7 Start Menu
    Start Menu - Context Menus and Dragging and Dropping - Disable or Enable
    How to Disable or Enable Context Menus and Dragging and Dropping in the Start Menu
    Start Menu - "Control Panel" Button - Change Default Icon
    How to Change the Default Control Panel Icon in Windows 7
    Start Menu - Customize
    How to Open and Set the "Customize Start Menu" Settings in Windows 7
    Start Menu - "Default Programs" Button - Change Default Icon
    How to Change the Default "Default Programs" Icon in the Windows 7 Start Menu
    Start Menu - "Devices and Printers" Button - Change Default Icon
    How to Change the Default "Devices and Printers" Icon in the Windows 7 Start Menu
    Start Menu - Enable Folder and Library Pin to Start Menu
    How to Enable or Disable Pin Folders and Libraries to Windows 7 Start Menu
    Start Menu - Enable or Disable Log off
    How to Enable or Disable "Log off" in the Start Menu of Windows 7
    Start Menu - "Games" Button - Change Default Icon
    How to Change the Default "Games" Explorer Icon in the Windows 7 Start Menu
    Start Menu - "Help and Support" Button - Change Default Icon
    How to Change the Default "Help and Support" Icon in the Windows 7 Start Menu
    Start Menu - "HomeGroup" Button - Change Default Icon
    How to Change the Default HomeGroup Icon in Windows 7
    Start Menu - Pin or Unpin a Folder, Drive, and Library
    How to Pin a Folder, Drive, and Library to the Start Menu in Windows 7
    Start Menu - Pin or Unpin a Program to
    How to Pin or Unpin a Program to the Windows 7 Start Menu
    Start Menu - Pin to Start Menu - Enable or Disable
    How to Enable or Disable Pin to Start Menu in Vista and Windows 7
    Start Menu Power Button - Change
    How to Change the Default Windows 7 Start Menu Power Button Action
    Start Menu Properties Shortcut - Create
    How to Create a "Start Menu Properties" Shortcut in Windows 7 and Vista
    Start Menu - "Recent Items" Button - Change Default Icon
    How to Change the Default "Recent Items" Icon in the Windows 7 Start Menu
    Start Menu - Reset Pin To Area
    How to Reset the Pin To Start Menu Area in Windows 7
    Start Menu - "Run" Button - Change Default Icon
    How to Change the Default "Run" Icon in the Windows 7 Start Menu
    Start Menu Shortcut Program
    Download a Shortcut that Opens the Start Menu in Windows
    Start Menu User Folder Buttons - Open to Users Instead of Libraries
    How to Make Windows 7 Start Menu User Folder Buttons Open to Users Instead of Libraries Location
    Start Menu - Use Small or Large Icons
    How to Use Small or Large Icons on the Windows 7 Taskbar
    Start Orb Image - Create Custom
    How to Create Custom Start Orb Image
    Startup - Enable or Disable Maginifier from Running
    How to Enable or Disable Windows 7 Magnifier Starts at Startup
    Startup - Log On Automatically at
    How to Automatically Log On a User Account at Windows 7 Startup
    Startup - Open Command Prompt
    How to Open a Command Prompt at Boot in Windows 7
    Continued on next post......
  2. Posts : 72,050
       #51
    Windows 7 Tutorial Index - S (5 of 6)
    S:
    Startup Programs - Change
    How to Change, Add, or Remove Startup Programs in Windows 7
    Startup Repair
    How to Run a Startup Repair in Windows 7
    How to Recover from an Infinitely Looping Startup Repair Loop without Reinstalling Windows
    Startup Repair - Run 3 Separate Times
    Startup Repair - Run 3 Separate Times to Repair Boot Issues
    Startup Sound - Change in Windows 7
    How to Change the Windows 7 Startup Sound
    Startup Sound - Enable or Disable
    How to Enable or Disable the Startup Sound in Vista, Windows 7, and Windows 8
    Static Routes - Create or Remove
    How to Create or Remove Static Routes in Windows 7 and 8
    Status Bar - Turn On or Off
    How to Turn the Windows Explorer Status Bar On or Off in Windows 7
    Status Messages - Verbose or Normal Logon, Logoff, and Shutdown
    Enable or Disable Detailed Verbose Logon, Logoff, Startup, and Shutdown Status Messages in Vista and Windows 7
    Steam Games - Add to Games Explorer Folder
    How to Add Steam Games to Windows 7 Games Explorer Folder
    Sticky Notes - Backup and Restore
    How to Back Up and Restore Sticky Notes in Windows 7 and Windows 8
    Sticky Notes - Change Color
    How to Change the Color of a Sticky Note in Windows 7 and Windows 8
    Sticky Notes - Change Default Font
    How to Change the Default Font in Sticky Notes in Windows 7 and Windows 8
    Sticky Notes: Change Default look
    How to Customize Sticky Notes in Windows 7 and Windows 8
    Sticky Notes - Change Text Format
    How to Format Text in a Windows 7 Sticky Note and Windows 8
    Sticky Notes - Create and Delete
    How to Create and Delete Sticky Notes in Windows 7 and Windows 8
    Sticky Notes Delete Confirmation - Enable or Disable in Windows 7 & 8
    How to Enable or Disable Sticky Notes Delete Confirmation in Windows 7 and Windows 8
    Stored User Names and Passwords Shortcut - Create
    How to Create a "Stored User Names and Passwords" Shortcut in Vista, Windows 7, and Windows 8
    Student Windows 7 Download - Create Bootable ISO from
    SuperFetch - Change Prefetch Data to be Cached
    How to Change what Files are Cached by SuperFetch
    SuperFetch - Enable or Disable in Windows
    How to Enable or Disable SuperFetch in Windows 7, Windows 8, and Windows 10
    Suspend BitLocker protection - Add to Context Menu in Windows
    How to Add 'Suspend BitLocker protection' to Context Menu of Drives in Windows
    Switch Between Windows - Flip 3D Shortcut
    How to Create a Flip 3D Switch Between Windows Shortcut in Windows 7
    Switch User - Add or Remove in Ctrl+Alt+Del and Start Menu
    How to Add or Remove Switch User from CTRL+ALT+DEL Screen and Start Menu
    Switch User - Enable or Disable
    How to Enable or Disable Fast User Switching in Vista and Windows 7
    Switch User Shortcut - Create
    How to Create a "Switch User" Shortcut in Windows 7
    Sync Center Shortcut - Create
    How to Create an Offline Files "Sync Center" Shortcut in Windows 7 and Windows 8
    Sync Conflicts Shortcut - Create
    How to Create an Offline Files "Sync Conflicts" Shortcut in Windows 7 and Windows 8
    Sync Offline Files
    How to Manually Sync Your Offline Files in Windows 7 and Windows 8
    Sync Results Shortcut - Create
    How to Create an Offline Files "Sync Results" Shortcut in Windows 7 and Windows 8
    Sync Setup Shortcut - Create
    How to Create an Offline Files "Sync Setup" Shortcut in Windows 7 and Windows 8
    SyncToy - Backup User Data
    How to Use SyncToy for Data Backups
    Synergy - One mouse & keyboard to control up to 15 computers
    How to Use One Mouse & Keyboard on up to 15 PCs using Synergy without Additional Hardware
    SysKey - Create USB Key to Lock or Unlock Windows
    How to Create a USB Startup Key to Lock or Unlock Windows
    SysKey - Set Startup Password to Lock or Unlock Windows
    How to Set a Startup Password to Lock or Unlock Windows
    System Boot Process of BIOS
    BIOS Boot Sequence Explained
    System Configuration - Add or Remove from Control Panel
    How to Add or Remove "System Configuration" (msconfig) from Control Panel in Windows
    System Configuration (msconfig) Shortcuts - Create
    How to Create System Configuration (msconfig) Shortcuts in Windows
    System Failure Automatic Restart - Enable or Disable
    How to Enable or Disable Automatic Restart on System Failure in Windows
    System Files and Drivers - Verify if Digitally Signed in Windows
    How to Verify if System Files and Drivers are Digitally Signed in Windows 7, Windows 8, and Windows 10
    System Health Report - Generate
    How to Generate a System Health Report in Vista and Windows 7
    System Icons - Enable or Disable
    How to Enable or Disable Notification Area System Icons in Windows 7 and Windows 8
    System Icons and Notifications - Hide or Show
    How to Hide or Show System Icons and Notifications in Windows 7 and Windows 8
    System Icons Shortcut - Create
    How to Create a "System Icons" Settings Shortcut in Windows 7 and Windows 8
    System Icons - Turn On or Off
    How to Turn System Icons On or Off in Windows 7 and Windows 8
    System Image Backup - Create
    How to Create a System Image Backup in Windows 7
    System Image Backup - "Create a System Image Shortcut"
    How to Create a "Create a System Image" Shortcut in Windows 7
    System Image Backup - "Do you want to create a system repair disc?" Message - Hide or Show
    How to Hide or Show "Do you want to create a system repair disc?" Message
    System Image Backup - Enable or Disable
    How to Enable or Disable the Ability to Create a System Image in Windows 7 and Windows 8
    System Image - Create General System Image in Audit Mode for New Installation
    Create a System Image with your software installed but without any user accounts or activation information
    System Image - Extract Files Using Disk Management
    How to Extract Windows 7 System Image Files Using Disk Management
    System Image - Extracting Files from using Virtual PC
    How to Extract Files from Windows 7 System Image using Virtual PC
    System Image - Recover a Broken Windows 7 System Image
    How to Restore your System with a Broken Windows 7 System Image
    System Image Recovery
    How to Do a System Image Recovery in Windows 7
    System Info - See Your System Specs
    How to See Your System Specs with "System Info"
    System Information
    How to See System Information in Vista and Windows 7
    System Information File - Create in Windows
    How to Create a System Information File in Windows
    System Locale Language for Non-Unicode Programs - Change in Windows
    How to Change the Language for Non-Unicode Programs in Windows
    System Logo : How to Change
    How to Change the Windows Logo on the System Properties Page
    System Maintenance Troubleshooter Shortcut - Create
    How to Create a "System Maintenance Troubleshooter" Shortcut in Windows 7
  3. Posts : 72,050
       #52
    Windows 7 Tutorial Index - S (6 of 6)
    S:
    System Maintenance Troubleshooter - Turn On or Off
    How to Turn the "System Maintenance Troubleshooter" On or Off in Windows 7
    System OEM Support Information
    How to Add and Change the "System" OEM Support Information in Windows 7
    System Performance Report - Generate and View in Windows
    How to Generate and View a System Performance Report in Windows
    System Preparation Tool - Use to Customize Windows
    How to Use Sysprep to Customize Windows 7 and Windows 8
    System Properties - "Advanced" Tab Shortcut - Create
    How to Create a "Advanced System Properties" Shortcut in Windows 7
    System Protection - System Restore and Shadow Copies - Change Disk Space Usage
    How to Change Maximum Disk Space Used by System Protection and System Images in Windows 7
    "System Protection Properties" Shortcut - Create
    Create a "System Protection Properties" Shortcut in Vista, Windows 7, and Windows 8
    System Protection Restore Points - Delete
    How to Delete System Protection Restore Points in Windows 7
    System Protection - System Restore and Shadow Copies - Turn On or Off
    How to Turn System Protection (System Restore and Shadow Copies) On or Off in Windows 7
    System Recovery Options
    How to Boot to the System Recovery Options in Windows 7
    System Recovery Shortcut - Create
    How to Create a System Recovery Shortcut in Windows 7
    System Repair Disc - Boot from USB Using Grub4Dos
    How to Boot Windows 7 System Repair Disc from a USB Pen Drive or External Hard Disk Using Grub4Dos
    System Repair Disc - Create
    How to Create a Windows 7 System Repair Disc
    System Reserved : Create for Dual Boot
    Create the System Reserved for Dual Boot use
    System Reserved : Create Using Disk Management
    How to Create the Windows 7 System Reserved Partition after Installation
    System Reserved : Multi Boot from Logical Partitions
    How to Multi Boot Windows from Logical Partitions
    System Reserved Partition - Delete
    How to Delete the Windows 7 100MB System Reserved Partition
    System Restore
    How to Do a System Restore in Windows 7
    System Restore Configuration - Enable or Disable
    How to Enable or Disable System Restore Configuration in Windows 7 and Windows 8
    System Restore - Enable or Disable
    How to Enable or Disable System Restore in Windows 7 and Windows 8
    System Restore General Troubleshooting to Fix Issues
    System Restore Point - Add "Create Restore Point" to Context Menu in Windows
    How to Add "Create Restore Point" to Context Menu in XP, Vista, Windows 7, and Windows 8
    System Restore Point Automatic Creation - Disable in Windows
    How to Enable or Disable Automatic System Restore Point Creation in Windows
    System Restore Point - Create
    How to Create a System Restore Point in Windows 7
    System Restore Point : Create at System Startup
    How to Automatically Create System Restore Points in Windows 7 and Windows 8
    System Restore Points - Delete
    How to Delete System Protection Restore Points in Windows 7 and Windows 8
    System Restore Point Shortcut
    How to Make a "Create System Restore Point" Shortcut in XP, Vista, Windows 7, and Windows 8
    System Restore Points - Manually Extract Files and Folders
    How to Extract Files and Folders from System Restore Points in Windows 7 and Vista
    System Restore Points - Stop XP Dual Boot Delete
    How to Stop System Restore Points from being Deleted in Vista and Windows 7 when Dual Booting with XP
    System Restore - Undo
    How to Undo the Last System Restore in Vista and Windows 7
    System Shortcut - Create
    How to Create a "System" Shortcut in Windows 7
    System Sounds Auto Leveling - Disable
    How to Disable Auto System Sounds Leveling in Windows 7
    System Support Information
    Add and Change System OEM Support Information in Windows 7 and Windows 8
    System Tools - Cascading Desktop Context Menu
    How to Add a "System Tools" Cascading Desktop Context Menu in Windows 7
    System Tray - Add or Remove
    How to Add or Remove Notification Area from Taskbar in Windows 7 and Windows 8
    System Tray - Minimize Windows Live Mail to in Windows 7
    How to Minimize Windows Live Mail to the System Tray in Windows 7
    System Type - 32-bit (x86) or 64-bit (x64)
    How to Tell if Windows 7 is a 32-bit or 64-bit System Type
    System Update Readiness Tool - CheckSur.log File Analyzis
    How to Anaylze the System Update Readiness Tool CheckSur.log File
    System Uptime
    How to See what the System "Up Time" is in Vista and Windows 7
  4. Posts : 72,050
       #53
    Windows 7 Tutorial Index - T (1 of 4)
    T:
    Tablet PC Settings Shortcut - Create
    How to Create a "Tablet PC Settings" Shortcut in Windows 7 and Windows 8
    Tags of a Picture and Video File - Add, Change, or Remove
    How to Add, Change, or Remove File Details Properties in Windows 7
    Take Ownership - Allow or Prevent Users and Groups To
    How to Allow or Prevent Users and Groups to Take Ownership
    Take Ownership of a File, Folder, Drive, or Registry Key
    How to Take Ownership of a Item in Vista and Windows 7
    Take Ownership Shortcut
    Add "Take Ownership" to Context Menu of Files, Folders, and Drives
    Tape Drives - Allow or Deny Read and Write Access
    How to Deny or Allow Read and Write Access to Tape Drives in Vista and Windows 7
    Task - Create to Run a Program at Startup and Log On
    How to Create a Task to Run a Program at Startup and Log On in Windows 7
    Task - End Process in Vista and Windows 7
    How to End a Process Task in Vista Windows 7
    Task Management
    How to Kill Wayward Programs and Processes
    Task Manager - Add or Remove Columns
    How to Add or Remove Columns in Windows 7 Task Manager
    Task Manager - Add or Remove from CTRL+ALT+DEL Screen
    How to Add or Remove Task Manager from the CTRL+ALT+DEL Screen
    Task Manager - Allow or Deny Access Permission
    How to Allow or Deny Access of Task Manager for a Specific User
    Task Manager - Create Elevated Shortcut
    How to Create a "Elevated Task Manager" Shortcut in Windows 7
    Task Manager - Enable or Disable
    How to Enable or Disable Task Manager in Vista and Windows 7
    Task Manager - See if Process is Running as administrator (elevated)
    How to See if Process is running as administrator (elevated) in Vista and Windows 7
    Task Manager Users - Log Off a Local User
    How to Log Off a Local User in Vista and Windows 7
    Task Manager Users - Send Message to a User
    How to Send a Message to Another User in Vista and Windows 7
    Task Manager - Show Services Running under svchost.exe
    How to See Services Running Under svchost.exe Process in Windows 7
    Task Manager - Small Footprint Mode
    How to Switch Between Normal and Small Footprint Mode in Vista and Windows 7 Task Manager
    Task Manager - Turn "Always On Top" On or Off
    How to Turn Task Manager "Always On Top" On or Off
    Task Scheduler - Create Elevated Program Shortcut without UAC Prompt
    How to Create a Elevated Program Shortcut without a UAC Prompt
    Task Scheduler - Create New Task
    How to Create a Automated Task that Runs at a Set Time in Windows 7
    Task Scheduler : Create Shut Down PC Automatically Task
    How to Create a Task that will Shut Down the PC Automatically
    Task Scheduler - Create Task to Display a Message Reminder
    How to Display a Message Reminder in Windows with Task Scheduler
    Task Scheduler - Create Task to Wake Up Computer
    How to Create a Task to Wake up the Computer to Run in Vista and Windows 7
    Task Scheduler Error (Event ID 404) - Fix
    How to Fix Task Scheduler Error (Event ID 404)
    Task Scheduler - Put Computer into Standby Mode
    How to Use Task Scheduler to Put Computer into Standby Mode
    Taskbar - Add or Remove Desktop Toolbar
    How to Add or Remove the "Desktop Toolbar" on the Windows 7 Taskbar
    Taskbar - Add or Remove Show Desktop Button
    How to Add or Remove Show Desktop Taskbar Button in Windows 7
    Taskbar and Start Menu - Animations - Enable or Disable
    Taskbar and Start Menu Properties - Enable or Disable
    Taskbar Auto-hide - Turn On or Off
    How to Turn Auto-hide Taskbar On or Off in Windows 7
    Taskbar - Back Up and Restore Pinned Items in Windows 7
    How to Back Up and Restore Pinned Taskbar Items in Windows 7
    Taskbar Button: Change Color of Orange Flashing Button
    How to Change the Orange Flashing Taskbar Button Color in Windows 7
    Taskbar Button Flash - Change Flash Count
    How to Change Count of Flashes for Activated Window on Taskbar
    Taskbar Button Grouping - Allow or Prevent
    How to Allow or Prevent Taskbar Button Grouping in Windows 7
    Taskbar Button Grouping - Enable or Disable
    How to Enable or Disable Taskbar Button Grouping in Windows 7
    Taskbar - Center Icons
    How to Center the Taskbar Icons in Windows 7
    Taskbar - Change Icon Button Width Size
    How to Change the Windows 7 Taskbar Icon Width Size
    Taskbar - Change Pinned Windows Explorer Icon Open To Target
    How to Change the Windows 7 Pinned Windows Explorer Taskbar Icon Open To Target
    Taskbar Context Menus - Enable or Disable
    How to Enable or Disable the Windows 7 Taskbar Context Menus
    Taskbar - Customize Skin
    How to Customize the Windows 7 Taskbar Skin
    Taskbar - Date Format - Show Full Day and Month Names
    How to Show Full Day and Month Names in Date on Taskbar System Tray in Windows
    Taskbar - Enable or Disable Moving
    How to Enable or Disable Moving the Taskbar in Windows 7
    Taskbar Grouped Icon Button - Cascade All Windows
    How to Cascade All Windows from a Grouped Taskbar Button in Windows 7 and Windows 8
    Taskbar Grouped Icon Button - Close All Windows
    How to Close All Windows from a Grouped Taskbar Button in Windows 7 and Windows 8
    Taskbar Grouped Icon Button - Restore All Windows
    How to Restore All Windows from a Grouped Taskbar Button in Windows 7 and Windows 8
  5. Posts : 72,050
       #54
    Windows 7 Tutorial Index - T (2 of 4)
    T:
    Taskbar Grouped Icon Button - Windows Stacked or Side by Side
    How to Show Windows Stacked or Side by Side from a Grouped Taskbar Button in Windows 7 and Windows 8
    Taskbar Icons Size - Change to Small or Large Icons
    Taskbar Last Active Click - Enable or Disable
    How to Enable or Disable Taskbar Last Active Click in Windows 7 and Windows 8
    Taskbar List or Thumbnail Previews Mode - Change
    How to Change Taskbar Thumbnail and List Mode Threshold in Windows 7 and Windows 8
    Taskbar - Lock or Unlock
    How to Lock or Unlock the Windows 7 Taskbar
    Taskbar - Move Location on Desktop Screen
    How to Move the Windows 7 Taskbar Location on the Desktop
    Taskbar - Notification Area - Add or Remove
    Taskbar - Notification Area Balloon Messages - Enable or Disable
    How to Enable or Disable Balloon Notifications in Vista, Windows 7, and Windows 8
    Taskbar - Notification Area Icons - Customize
    How to Customize the Notification Area Icons in Windows 7
    Taskbar - Notification Area Icons - Hide or Show System Icons and Notifications
    Taskbar - Notification Area Icons - Reset
    How to Reset the Notification Area Icons Cache in Windows 7 and Vista
    Taskbar - Notification Area Icons Shortcut - Create
    How to Create a "Notification Area Icons" Shortcut in Windows 7
    Taskbar - Notification Area System Icons - Enable or Disable
    Taskbar - Notification Area System Icons - Turn On or Off
    Taskbar -Notifications - Change How Long to Stay Open
    How to Change How Long Windows 7 Notifications Stay Open
    Taskbar - Notifications - Enable or Disable Message Balloons
    How to Enable or Disable Windows 7 Balloon Notifications
    Taskbar - Pin Invisible Icon for a Program
    How to "Pin to Taskbar" Transparent Invisible Icons for Programs in Windows 7
    Taskbar - Pin or Unpin a Drive
    How to Pin or Unpin a Drive to Taskbar in Windows 7 and Windows 8
    Taskbar - Pin or Unpin a Folder
    How to Pin or Unpin a Folder to Taskbar in Windows 7 and Windows 8
    Taskbar - Pin or Unpin a Program
    How to Pin or Unpin a Program to the Windows 7 Taskbar
    Taskbar - Pin or Unpin Computer
    How to Create a "Computer" Shortcut and Pin it to the Windows 7 Taskbar
    Taskbar - Pin or Unpin Control Panel
    How to Pin the Control Panel to the Windows 7 Taskbar
    Taskbar - Pin Recycle Bin
    How to Pin the Recycle Bin to the Windows 7 Taskbar
    Taskbar - Pin "User Files" Folder
    How to Pin Your User Files Folder to the Windows 7 Taskbar
    Taskbar Pinned Icons - Change
    How to Change the Icons of Programs Pinned to the Taskbar
    Taskbar Pinned Items - Reset and Clear in Windows 7
    How to Reset and Clear All Pinned Items on the Taskbar in Windows 7
    Taskbar Pinned Programs - Enable or Disable
    How to Enable or Disable Windows 7 Taskbar Pinned Programs
    Taskbar Properties Shortcut - Create
    How to Create a "Taskbar Properties" Shortcut in Windows 7
    Taskbar - Resize
    How to Resize the Taskbar in Vista and Windows 7
    Taskbar - Resize - Enable or Disable
    How to Enable or Disable Resizing the Taskbar in Vista and Windows 7
    Taskbar - Separate Pinned Programs
    How to Sort Pinned Programs into Categories on the Taskbar
    Taskbar System Icons - Enable or Disable
    How to Enable or Disable Windows 7 Notification System Icons
    Taskbar System Icons - Turn On or Off
    Taskbar Thumbnail Live Preview - Change Delay Time
    How to Change Taskbar Thumbnail Live Preview Delay Time in Windows 7 and Windows 8
    Taskbar Thumbnail Live Previews - Enable or Disable in Windows 7
    How to Enable or Disable Taskbar Thumbnail Live Previews in Windows 7
    Taskbar Thumbnail Previews - Change Delay Time
    How to Change Taskbar Thumbnail Previews Delay Time to Display in Windows 7 and Windows 8
    Taskbar Thumbnail Previews - Change Margin Size
    How to Change Margin Size of Taskbar Thumbnail Previews in Windows 7 and Windows 8
    Taskbar Thumbnail Previews - Change Size
    How to Change Size of Taskbar Thumbnail Previews in Windows 7 and Windows 8
    Taskbar Thumbnail Previews - Change Space Size Between
    How to Change Space Between Taskbar Thumbnail Previews in Windows 7 and Windows 8
    Taskbar Thumbnail Previews - Enable or Disable
    How to Enable or Disable Taskbar Thumbnail Previews in Windows 7 and Windows 8
    Taskbar Thumbnail Previews - Save
    How to Enable or Disable "Save Taskbar Thumbnail Previews" in Windows 7 and Windows 8
    Taskbar Thumbnail Previews - Show Previews for Individual Tabs in Internet Explorer
    How to Enable or Disable Internet Explorer Individual Tabbed Browsing Taskbar Preview Windows
    Taskbar Toolbars - Add or Remove
    How to Add or Remove a Toolbar on the Taskbar in Vista and Windows 7
    Taskbar Toolbars - Back Up and Restore
    How to Back Up and Restore Taskbar Toolbars in Vista and Windows 7
    Taskbar Toolbars - Disable Adding or Removing
    How to Enable or Disable Adding and Removing Taskbar Toolbars in Vista and Windows 7
    Taskbar Toolbars - Enable or Disable
    How to Enable or Disable Taskbar Toolbars in Vista, Windows 7, and Windows 8
    Taskbar Toolbars - How to Use in Windows 7 and Vista
    How to Use Taskbar Toolbars in Windows 7 and Vista
    Taskbar Toolbars - Reset and Clear in Vista and Windows 7
    How to Reset and Clear All Taskbar Toolbars in Vista and Windows 7
    Taskbar - Windows Explorer Taskbar Icon - Change Open To Target
    Taskbar - Windows Live Mail - Minimize to System Tray in Windows 7
    Taskbar - Windows Media Player 11 Toolbar - Enable
    How to Add Windows Media Player 11 Taskbar Toolbar Back in Windows 7
    Taskbar - Windows Media Player 12 Toolbar - Enable
    How to Add the Windows Media Player Taskbar Toolbar in Windows 7
    Temp Files - Set Disk Cleanup Last Access Limit to Delete
    How to Set Disk Cleanup to Delete Vista or Windows 7 Temporary Files Less than a Week Old
    Temporary Files Folder - Change Location in Windows
    How to Change Default Location of Temporary Files Folder in Vista, Windows 7, and Windows 8
    Temporary Internet Files of Internet Explorer - Browse
    How to Browse the "Temporary Internet Files" of Internet Explorer
    Temporary Internet Files of Internet Explorer - Disk Space Usage
    How to Change Disk Space to be Used by Internet Explorer "Temporary Internet Files"
    Temporary Profiles - Enable or Disable Log On Users with in Windows
    How to Enable or Disable Log On Users with Temporary Profiles in Windows 7, Windows 8, and Windows 10
    Terminate Non-responding Application - Create Shortcut
    How to Create a shortcut to Terminate a Non-responding Application in Windows 7
    “Test Mode Windows 7 Build 7601" Watermark - Remove from Desktop
    How to Remove “Test Mode Windows 7 Build 7601" Watermark from Desktop
    Text Services and Input Languages shortcut - Create in Windows
    How to Create a Text Services and Input Languages shortcut in Windows 7, Windows 8, and Windows 10
    Text to Speech Shortcut - Create
    How to Create a "Text to Speech" Shortcut in Windows 7
    The User Profile Service failed the logon. User profile cannot be loaded.
    Fix "The User Profile Service failed the logon. User profile cannot be loaded." Error in Windows 7
  6. Posts : 72,050
       #55
    Windows 7 Tutorial Index - T (3 of 4)
    T:
    Theme - Allow or Prevent Changing
    How to Allow or Prevent Changing Theme in Windows 7
    Theme - Allow or Prevent to Change Desktop Icons
    How to Prevent or Allow Themes to Change Desktop Icons in Windows 7 and Windows 8
    Theme - Allow or Prevent to Change Mouse Pointers
    How to Prevent or Allow Themes to Change Mouse Pointers in Windows 7 and Windows 8
    Theme - Change or Save
    How to Change or Save a Windows 7 Theme
    Theme - Customize Custom Themes
    How to Customize a Custom Theme from deviantART
    Theme - How to Apply Custom Themes
    How to Apply Custom Themes in Windows 7
    Theme Pack - Create, Save, Install, and Delete
    How to Make your own Windows 7 Theme Pack
    Theme - Specify Default Theme to Load for New Users
    How to Specify a Default Theme to Load for New Users in Windows 7
    Themes - Customize Information, Settings, and Name
    How to Change the Information of a Theme
    Themes - Enabling Custom Themes in Windows 7
    How to Enable Custom Themes without Modifying System Files
    Themes - Regional
    How to Use the Regional Themes in Windows 7
    "These files can't be opened" Windows Security Error - Fix
    How to Fix the Error "Your internet security settings prevented one or more file from being opened"
    Thumbnail Cache - Clear and Reset
    How to Clear and Reset the Thumbnail Cache in Windows
    Thumbnail Cache - Enable or Disable
    How to Enable or Disable the Thumbnail Cache in Windows
    Thumbnail Cache - Prevent Windows from Deleting
    How to Stop and Prevent Windows from Deleting the Thumbnail Cache
    Thumbnail Previews - Change Border
    How to Change Thumbnail Previews Border in Windows 7 and Windows 8
    How to Enable or Disable Explorer Thumbnail Previews in Windows 7 and Windows 8
    Thumbnails - Enable or Disable - Add to Context Menu
    Add "Enable/Disable Thumbnails" to Context Menu in Vista, Windows 7, and Windows 8
    Time and Date - Allow or Prevent Users and Groups from Changing
    How to Allow or Prevent Specific Users and Groups from Changing the Date and Time in Windows
    Time and Date - Change
    How to Change the Date and Time in Windows 7
    Time Format - Change
    How to Change the Time Format in Windows 7
    Time Synchronization
    How to Use "Internet Time" Synchronization in Vista, Windows 7, and Windows 8
    Time Synchronization Update Interval
    How to Change the Internet Time Synchronization Update Interval in Vista, Windows 7, and Windows 8
    Time Zone - Allow or Prevent Users and Groups from Changing
    How to Allow or Prevent Specific Users and Groups from Changing the Time Zone in Windows
    Time Zone - Change
    How to Change the Time Zone in Windows 7
    Time Zones - Restore Missing Default Time Zones
    How to Restore Missing Default Time Zones in Windows 7
    Toggle Keys at Startup - Enable or Disable
    How to Enable or Disable a Toggle Key at Startup in Vista, Windows 7, and Windows 8
    Toggle Keys Tone - Turn On or Off
    How to Turn Toggle Keys Tone On or Off in Windows 7 and Windows 8
    Toolbar Buttons in Windows Explorer - Customize
    How to Add, Remove, or Rearrange Toolbar Buttons in Windows 7 Explorer
    Toolbars Properties Shortcut - Create
    How to Create a "Toolbars Properties" Shortcut in Windows 7
    Touch and Pen Displays - Configure in Windows
    How to Configure Pen and Touch Displays in Windows 7 and Windows 8
    Touch and Pen Screen - Calibrate or Reset in Windows
    How to Calibrate or Reset Screen for Pen or Touch in Windows 7 and Windows 8
    Touch Screen - Enable or Disable Touch by Finger
    How to Enable or Disable Touch by Finger on Touch Screen in Windows 7 and Windows 8
    Touchpad PalmCheck - Turn On or Off in Windows
    How to Turn PalmCheck On or Off for Touchpad in Windows
    Transfer Windows 7 Installation to a New Computer
    How to Transfer your Complete Windows 7 Installation to a New Computer
    Translucent Selection Rectangle
    How to Turn On or Off "Translucent Selection Rectangle" in Vista, Windows 7, and Windows 8
    Transparency - Enable Full Clear Glass Transparency
    How to Enable Full Clear Glass Transparency in Windows 7
    Transparency - Enable or Disable
    How to Enable or Disable Transparency in Windows 7
    TRIM Support for SSD - Check and Enable or Disable
    Troubleshoot Aero Shortcut - Create
    How to Create a "Aero Troubleshoot" Shortcut in Windows 7
    Troubleshoot Application Conflicts by Performing a Clean Startup
    How to Troubleshoot a Problem by Performing a Clean Startup in Windows 7 or Vista
    Troubleshoot compatibility - Add or Remove from Context Menu
    How to Add or Remove "Troubleshoot compatibility" from Context Menu in Windows 7 and Windows 8
    Troubleshoot Connection to Workplace Shortcut - Create
    How to Create a "Connection to Workplace using DirectAccess Troubleshoot" Shortcut in Windows 7
    Troubleshoot Devices and Printers Shortcut - Create
    How to Create a "Devices and Printers Troubleshoot" Shortcut in Windows 7
    Troubleshoot Hardware and Devices Shortcut - Create
    How to Create a "Hardware and Devices" Troubleshoot Shortcut in Windows 7
    Troubleshoot HomeGroup Shortcut - Create
    How to Create a "HomeGroup Troubleshoot" Shortcut in Windows 7
    Troubleshoot Incoming Connections Shortcut - Create
    How to Create a "Incoming Connections Troubleshoot" Shortcut in Windows 7
    Troubleshoot Internet Connections Shortcut - Create
    How to Create a "Internet Connections Troubleshoot" Shortcut in Windows 7
    Troubleshoot Network Adapter Shortcut - Create
    How to Create a "Network Adapter Troubleshoot" Shortcut in Windows 7
  7. Posts : 72,050
       #56
    Windows 7 Tutorial Index - T (4 of 4)
    T:
    Troubleshoot Performance Troubleshoot Shortcut - Create
    How to Create a "Performance Troubleshoot" Shortcut in Windows 7
    Troubleshoot Power Shortcut - Create
    How to Create a "Power Troubleshoot" Shortcut in Windows 7
    Troubleshoot Printing Shortcut - Create
    How to Create a "Printing Troubleshoot" Shortcut in Windows 7
    Troubleshoot Program Compatibility Shortcut - Create
    How to Create a "Program Compatibility Troubleshoot" Shortcut in Windows 7
    Troubleshoot Recording Audio Shortcut - Create
    How to Create a "Recording Audio Troubleshoot" Shortcut in Windows 7
    Troubleshoot Search and Indexing Shortcut - Create
    How to Create a "Search and Indexing Troubleshoot" Shortcut in Windows 7
    Troubleshoot Shared Folders Shortcut - Create
    How to Create a "Shared Folders Troubleshoot" Shortcut in Windows 7
    Troubleshoot System Maintenance Shortcut - Create
    How to Create a "System Maintenance Troubleshoot" Shortcut in Windows 7
    Troubleshoot Windows 7 Installation Errors : Step by Step
    How to Troubleshoot Windows 7 Installation Errors Step by Step
    Troubleshoot Windows Update Shortcut - Create
    How to Create a "Windows Update Troubleshoot" Shortcut in Windows 7
    Troubleshoot WMP DVD Shortcut - Create
    How to Create a "Windows Media Player DVD Troubleshoot" Shortcut in Windows 7
    Troubleshoot WMP Library Shortcut - Create
    How to Create a "Windows Media Player Library Troubleshoot" Shortcut in Windows 7
    Troubleshoot WMP Settings Shortcut - Create
    How to Create a "Windows Media Player Settings Troubleshoot" Shortcut in Windows 7
    Troubleshooting Windows 7
    How to Open and Use "Troubleshooting" in Windows 7
    Troubleshooting Windows 7 Failure to Boot
    Troubleshooting History
    How to View Troubleshooting History in Windows 7 and Windows 8
    Troubleshooting Internet Explorer Issues
    Troubleshooting Playing Audio Shortcut - Create
    Troubleshooting Settings - Change
    How to Change Troubleshooting Settings in Windows 7 and Windows 8
    Troubleshooting Shortcut - Create
    How to Create a Windows 7 "Troubleshooting" Shortcut
    Troubleshooting Steps for Windows 7
    Troubleshooting with System Update readiness Tool
    TrueCrypt - Encrypt Data Folders
    How to Encrypt Data Folders with TrueCrypt in Windows
    TrueCrypt - Recover Corrupt Container
    How to Recover a TrueCrypt Container with Corrupt Header Information
    Trusted Platform Module (TPM) Chip - Verify on Windows PC
    How to Check if Windows PC has a Trusted Platform Module (TPM) Chip
    TrustedInstaller - Restore as Owner
    How to Restore TrustedInstaller as Owner of a File in Vista and Windows 7
    Turn off all unnecessary animations
    How to "Turn off all unnecessary animations" in Windows 7 and Vista
    Turn Off Display - Add to Desktop Context Menu in Windows
    How to Add or Remove "Turn Off Display" Desktop Context Menu in Windows 7 and Windows 8
    Turn Off Display cascading context menu - Add in Windows
    How to Add or Remove 'Turn off display' cascading context menu in Windows
    "Two-step Verification" - Turn On or Off for your Microsoft Account
    How to Turn "Two-step Verification" On or Off for your Microsoft Account
  8. Posts : 72,050
       #57
    Windows 7 Tutorial Index - U (1 of 2)
    U:
    UAC - Change Prompt Behavior for Administrators in Windows
    How to Change Behavior of User Account Control (UAC) Prompt for Administrators in Windows
    UAC - Create a Elevated Program Shortcut without a UAC Prompt
    UAC - Enable or Disable for Built-in Administrator Account
    Enable or Disable User Account Control (UAC) Prompt for Built-in Administrator in Windows
    UAC - Require a Password for Administrator
    How to Configure UAC to Require a Password for Administrator
    UAC - Require to Press CTRL+ALT+DEL to Approve
    How to Require Users to Press CTRL+ALT+DEL to Approve UAC Elevation
    UEFI and BIOS Firmware Version - Find in Windows
    How to Find the BIOS and UEFI Firmware Version in Windows
    UEFI Bootable USB Flash Drive - Create in Windows 7 and Windows 8
    How to Create a Bootable USB Flash Drive for UEFI in Windows 7 and Windows 8
    UEFI or Legacy BIOS Mode - See if Windows Boot in
    How to Check if Windows is Booted in UEFI or Legacy BIOS Mode
    UEFI Secure Boot - Enable or Disable
    How to Enable or Disable Secure Boot in UEFI
    UEFI (Unified Extensible Firmware Interface) - Install Windows 7 with
    How to Install Windows 7 Using "Unified Extensible Firmware Interface" (UEFI)
    ULPS (Ultra Low Power State) - Disable for AMD CrossfireX
    How to Disable ULPS (Ultra Low Power State) for Graphics Cards in AMD CrossfireX
    Unassociate a File Extension Type
    How to Unassociate a File Extension Type in Vista, Windows 7, and Windows 8
    Unattended Wake Up Return to Sleep Timout Period - Change
    How to Change the Return to Sleep Timeout for a Unattended Wake Up in Windows 7
    Unblock a File : "Open File - Security Warning" and "Windows SmartScreen"
    How to Unblock a File to Stop the "Open File - Security Warning" and "Windows 8 SmartScreen" Prompt
    Undeletable File - Delete
    How to Delete an "Undeletable" File
    Underline Keyboard Shortcuts and Access Keys
    How to Underline Keyboard Shortcuts and Access Keys in Windows 7
    UNetbootin - Create Bootable Live Linux USB
    How to Create a Bootable Live Linux USB Using UNetbootin
    Unidentified Networks - Set as Private or Public
    How to Set Unidentified Networks to be a Private or Public Network Location
    Uninstall and Remove Software in Safe Mode
    Uninstall Confirmation Prompt - Restore in Programs and Features
    How to Restore the Uninstall Confirmation Prompt in Programs and Features
    Uninstall Entry - Remove from Programs and Features
    How to Remove a Uninstall Entry in Programs and Features for Vista, Windows 7, and Windows 8
    Uninstall or Change a Program
    How to Uninstall or Change a Program in Windows 7 and Windows 8
    Uninstall Programs using Command Prompt in Windows
    How to Uninstall Programs using Command Prompt in Windows
    Uninstall Programs with Revo Uninstaller Freeware
    How to Uninstall Programs and their Leftovers using Revo Uninstaller Freeware
    Unknown Devices - Find and Identify
    How to Find and Identify Unrecognized Devices through Device Manager
    Unlock Computer Sound - Play in Windows
    How to Play Sound when Unlock Computer in Windows 7, Windows 8, and Windows 10
    Upgrade Advisor for Windows 7
    How to Use Windows 7 Upgrade Advisor
    Upgrade Assistant for Windows 8 - Download and Run
    How to Download and Run the "Windows 8 Upgrade Assistant"
    Upgrade Install from Windows 7 or Vista to Windows 8
    How to Upgrade from Windows 8, Windows 7, Vista, or XP to Windows 8 or 8.1
    Upgrade Install with Windows 7
    How to Do a Inplace Upgrade Installation from Vista to Windows 7
    Upgrade Install - XP to Windows 7
    How to Do an Upgrade Install from XP to Windows 7
    Upgrade to Windows 10
    How to Upgrade to Windows 10
    Upgrade to Windows 10 from Windows 7 for Free
    How to Upgrade to Windows 10 from Windows 7 for Free
    Upgrade to Windows 10 Update - Enable or Disable in Windows 7 or 8.1
    Enable or Disable Upgrade to Windows 10 in Windows Update for Windows 7 and 8.1
    Upload a File or Screenshot in Seven Forums
    How to Upload and Attach Files and Screenshots to a Post in Seven Forums
    Upload and Post Screenshots and Files in Seven Forums
    How to Upload and Post a Screenshot and File in Seven Forums
    Uptime for the System
    URL Files - Add "Open with" to Context Menu
    How to Add "Open with" to Context Menu of URL Files in Windows
    URL Website Shortcut - Create
    How to Create an Internet Website Shortcut in Windows
    USB Driver - General Fix for Problems
    General Fix for USB Driver Problems
    USB Flash Drive - Create MS-DOS Bootable USB Flash Drive
    How to Make a MS-DOS Bootable USB Flash Drive
    USB Flash Drive - Create Bootable USB or DVD with ISO
    How to Get and Use the Windows 7 USB/DVD Download Tool
    USB Flash Drive - Install and Run Windows on using WinToUSB
    How to Install and Run Windows on a USB Drive using WinToUSB
    USB Floppy or Floppy Drive - Allow or Deny Read and Write Access
    How to Deny or Allow Read and Write Access to Floppy Drives in Vista and Windows 7
    USB or HDD - Quick Format
    How to Quick Format a HDD or USB Drive
    USB - Password Protect with SafeHouse Explorer
    How to Create Password Protected USB Flash Drive with SafeHouse Explorer
    USB Selective Suspend - Turn On or Off
    How to Turn On or Off "USB Selective Suspend" for Idle USB Devices
    USB Storage Device - Enable or Disable Connecting
    How to Enable or Disable USB Storage Devices in Windows
    USB Storage Devices Connection context menu - Add in Windows
    How to Add Enable or Disable USB Storage Devices Connection context menu in Windows
    How to Create a Bootable Windows 7 Installation USB Flash Drive
  9. Posts : 72,050
       #58
    Windows 7 Tutorial Index - U (2 of 2)
    U:
    User Account Control Settings Shortcut - Create
    How to Create a "User Account Control Settings" Shortcut in Windows 7
    User Account Control (UAC) - Blacking Out of Screen
    How to Enable or Disable User Account Control (UAC) Blacking Out of Screen in Windows
    User Account Control (UAC) - Change Notification Settings
    How to Change UAC Notification Settings in Windows 7
    User Account Control (UAC) - Change Prompt Behavior for Standard Users
    How to Change Behavior of User Account Control (UAC) Prompt for Standard Users
    User Account Control (UAC) - Elevate Privilege Level
    How to Elevate All Administrator Accounts UAC Privilege Level
    User Account - Create
    How to Create a User Account in Windows 7
    User Account - Delete
    How to Delete a User Account in Windows 7 and Windows 8
    User Account - Enable or Disable
    How to Enable or Disable a User Account in Windows 7 and Windows 8
    User Account - Hide or Unhide
    How to Hide or Unhide a User Account in Vista and Windows 7
    User Account - Log On to Automatically at Startup
    User Account Password - Change from WinRE
    How to Change the User Account Password if Unable to Login to Windows
    How to Change the Password for Your or Another User Account in Windows 7
    User Account Password - Create
    How to Create a Password for a Windows 7 User Account
    User Account Password Hint - Create, Change, and Use
    How to Create, Change, and Use a Password Hint in Windows 7
    User Account Password - Prevent or Allow to Change
    How to Prevent or Allow a User to Change their Password in Vista and Windows 7
    User Account Password - Remove
    How to Remove the Password for Your or Another User Account in Windows 7
    User Account Password - Reset in Windows 7
    How to Reset the Password of a User Account in Windows 7
    User Account Picture - Change
    How to Change Your User Account Logon Picture in Windows 7
    User Account Picture - Set Default for All Users
    How to Set a Default User Logon Picture for All Users in Vista, Windows 7, and Windows 8
    User Account Type - Change
    How to Change a User Account Type in Windows 7
    User Accounts - Add or Remove from Groups
    How to Add or Remove User Accounts from Groups in Windows 7 and Vista
    User Accounts - Change "Guest" Account Name
    How to Rename the Windows 7 Guest Account
    User Accounts Shortcut - Create
    How to Create a "User Accounts" Shortcut in Windows 7
    User Accounts - Turn Guest Account On or Off
    How to Turn the Guest Account On or Off in Windows 7
    User Accounts - View Detailed Information About in Windows
    How to View Detailed Information About All User Accounts on a Windows PC
    "User Files" Folder - Pin to Taskbar
    How to Pin Your "User Files" Folder to the Windows 7 Taskbar
    User Folder - Add or Remove from Desktop Context Menu
    How to Add or Remove "User Folder" from Desktop Context Menu in Windows
    User Folder - Add or Remove from Navigation Pane
    How to Add or Remove your User Folder from the Windows 7 Navigation Pane
    User Folder Buttons in Start Menu - Open to Users Instead of Libraries
    User Folder - Create Your Own Special Folders
    How to Create Your Own Special User Folder
    User Folders - Allow or Prevent Moving Location
    How to Allow or Prevent Users to Move their User Folders to a New Location
    User Folders - Change Default Icon
    How to Change Default User Folder Icons in Windows 7 and Windows 8
    User Folders - Change Default Location
    How to Change the Default Location of User Folders in Windows 7 and Windows 8
    User Folders - Moving User Folders by Modular Script
    Choose the folders to move, their destination, and just run the script
    User Folders - Restore Default Icon
    How to Restore Default User Folder Icons in Windows 7 and Windows 8
    User Folders - Restore Default Location
    How to Restore the Default Location of User Folders in Windows 7 and Windows 8
    User Group - Create New or Delete
    How to Create and Delete a User Group in Windows 7 and Vista
    User - Log Off in Task Manager
    User Name and Password - Enter at Log On
    How to Make Windows 7 Require a User Name and Password at Log On
    User Permissions - Allow or Deny Users and Groups
    How to Allow or Deny Permissions to Users and Groups
    User Profile - Change Default Location
    How to Change the Default Location of a User Profile in Windows 7 and Vista
    User Profile - Customize During Installation
    How to Customize Default User Profile in Audit Mode
    User Profile Error - Logged on with a Temporary Profile
    How to Fix the Error "Your user profile was not loaded correctly! You have been logged on with a temporary profile." in Vista and Windows 7
    User Profile Folder - Change User Account Folder Name
    How to Change the User Folder Name of a User Profile in Windows 7
    User Profiles - Create and Move During Windows 7 Installation
    How to Create User Accounts on another Partition or Disk During Windows 7 Installation
    User Rights Assignment - Add or Remove Users and Groups
    How to Add or Remove Users and Groups from "User Rights Assignment"
    User - Send Message to in Task Manager
    Users - Add or Remove from being a Member of a Group
    How to Add or Remove User Accounts from Groups in Vista, Windows 7, and Windows 8
    Users and Groups - Allow or Deny Permissions
    Users and Groups Manager - Open
    How to Open Local Users and Groups in Windows 7 and Windows 8
    Users and Groups MMC Snap-in - Enable or Disable
    How to Enable or Disable the Local Users and Groups MMC Snap-in
  10. Posts : 72,050
       #59
    Windows 7 Tutorial Index - V (1 of 1)
    V:
    VBS File - Add "Run as administrator" to Context Menu
    How to Add "Run as administrator" to VBS File Context Menu
    VBScript File - Add to "New" Context Menu
    How to Add "New VBScript File" to the Context Menu in Windows
    Verbose Status Messages - Logon, Logoff, and Shutdown
    VHD - Boot from using Windows 7 and Windows 8
    How to Boot from a VHD using Windows 7 and Windows 8
    VHD - Convert to a ISO File
    How to Convert a VHD File to a ISO File
    VHD - Create and Attach VHD
    How to Create and Attach a Virtual Hard Disk in Windows 7
    VHD - Create and Start with at Boot
    How to Create a Windows 7 VHD at Boot to Start with from Boot
    VHD - Create of a Physical Hard Disk
    How to Create a VHD of a Physical Hard Disk in Windows 7
    VHD - Unattach and Delete VHD
    How to Unattach and Delete a Virtual Hard Disk in Windows 7
    Video or Audio Files - Convert with Format Factory
    Video Card - Flash NVIDIA BIOS
    How to Flash the BIOS on an NVIDIA Graphics Card
    Video Card - Install New Card
    How to Install a New Graphics Card
    Video Card - Overclock
    How to Overclock a Graphics Card
    Video Card - Stress Test with Furmark
    How to Stress Test a Video Card with Furmark
    Video Card - Test NVIDIA/AMD with OCCT
    How to Test NVIDIA/AMD Performance with OCCT
    Video Encoding x264 (MeGUI)
    MeGUI x264 Video Encoder
    Video File Tags - Add, Change, or Remove
    Video Memory Virtualization - A Brief Guide
    Videos Library - Create Shortcut in Windows
    How to Create a "Videos Library" Shortcut in Windows 7 and Windows 8
    View and Print File Directory - Add to Context Menu
    How to Add "View File Directory" and "Print File Directory" to the Context Menu in Vista and Windows 7
    Virtual Hard Disk (VHD) - Boot from at Startup Using Windows 7
    How to Setup Windows 7 to Boot from a VHD (Virtual Hard Disk)
    Virtual Hard Disk (VHD) - Create and Attach VHD
    Virtual Hard Disk (VHD) - Unattach and Delete VHD
    Virtual Hard Drive (VHD) File - Create and Start with at Boot
    Virtual Machine - Create in Windows Virtual PC
    How to Create a Virtual Machine in Windows Virtual PC
    Virtual Machine - Speed Up Performance
    How to Speed Up Performance of a Virtual Machine
    Virtual Memory Page File Encryption - Enable or Disable
    How to Enable or Disable Page File Encryption in Vista and Windows 7
    Virtual Memory Page File - Change or Move in Windows
    How to Change or Move Virtual Memory Paging File in Vista, Windows 7, and Windows 8
    Virtual Memory Paging File - Clear at Shutdown
    How to Enable or Disable "Clear Virtual Memory Paging File at Shutdown" in Vista and Windows 7
    Virtual PC XP Mode - Add Limited User Accounts
    How to Add Limited User Accounts to Windows Virtual PC XP Mode
    Virtual Private Network (VPN) - Enable Incoming VPN Connections
    How to Allow Incoming VPN Connections in Windows 7 and Windows 8
    Virtual Private Network (VPN) – Enable Outgoing VPN Connections
    How to Configure Your Computer to Initiate Outgoing VPN Connections in Windows 7
    Virtual Windows XP Mode - Install and Setup
    How to Install and Setup Virtual Windows XP Mode in Windows 7
    Virtual XP Mode Machine - Copy
    How to Copy a Virtual XP Machine in Windows 7
    VirtualBox - Install Linux on Windows 7 Virtual Machine
    How to Install Linux on a Windows 7 Virtual Machine using VirtualBox
    VirtualBox - Install Windows 8
    How to Install Windows 8 on VirtualBox
    VirtualBox - Install Windows 10
    How to Install Windows 10 as Virtual Machine in VirtualBox
    VirusTotal + HerdProtect - Check Files with Simultaneously
    Check Files with VirusTotal + HerdProtect Simultaneously
    VirusTotal Uploader
    Add an Explorer context menu 'Send to VirusTotal'
    Vista Windows Sidebar - Reinstate on Windows 7
    How to Reinstate the Vista Sidebar on Windows 7
    Visual Basic - Learning to Code
    Learning to Code in Visual Basic
    Visual Effects Performance Options Shortcut - Create
    How to Create a Visual Effects Performance Options Shortcut in Windows
    Visual Effects Settings - Change
    How to Change the Visual Effects Settings in Windows 7
    Visual Styles on Windows and Buttons - Turn On or Off
    How to Turn "Use visual styles on windows and buttons" On or Off
    VMware Player - Expand Virtual Machine Hard Disk
    How to Expand a Virtual Hard Disk of a Virtual Machine in VMware Player
    VMware Player - Install and Setup Zorin
    How to Install and Setup Zorin in VMware Player
    VMware Player - Install Windows 8
    How to Install Windows 8 on VMware Player
    VMware Player - Install Windows 10
    How to Install Windows 10 as Virtual Machine in VMware Player
    VMware Player - Share Partitions Between Host and Guest
    How to Share Partitions Between Host and Guest in VMware Player
    Volume Mixer Shortcut - Create
    How to Create a "Volume Mixer" Shortcut in Vista, Windows 7, and Windows 8
    Volume or Partition - Delete
    How to Delete a Partition or Volume in Windows 7 and Windows 8
    Volume Shadow Copies - Delete
    How to Delete Shadow Copies in Vista and Windows 7
    Volume Shortcut - Create
    How to Create a "Volume" Shortcut in Vista, Windows 7, and Windows 8
