Games Explorer Folder - Add Games To
Page 1 of 21 12311 ... LastLast
    How to Add Games to Games Explorer Folder in Vista, Windows 7, and Windows 8
    "So you add a game into Games Explorer Folder and realize that the game has no
    cover, no rating, no info... Well, this tutorial will show you
    how to add all that missing information."
    First things First.
    • Adding a shortcut into Game Explorer Folder (GEF):
    • Copy the main executable, then right click and select paste shortcut.
    • Or Just Drag n Drop a shortcut of the game.
    Use a shortcut, never use the main executable.
    • Using the Registry Editor (REd):
    • Hit the Start Orb and type regedit in the search box, an UAC prompt will ask you to authorize access by clicking Continue.
    • The Files you will need:
    • Inside is the GameUXLegacyGDFs.txt file, Just save it for later use.
    The Tutorial:
    This tutorial subdivides in Semi-Automatic for games already in the database which the GEF doesn't recognize automatically and manual for the ones not included in the database.
    Always remember to close GEF every time you need to edit the values in the REd, otherwise the game shortcut will be deleted.
    Let's Begin...
    • Semi-Automatic
    Microsoft has added various old games to be recognized automatically by the GEF using a file called GameUXLegacyGDFs.dll but some of them need a little extra work to show-up.
    Step 1: Add a shortcut into the GEF and then close it.
    Step 2: Extract and then open the file GameUXLegacyGDFs.txt from the downloadable file.
    • Hit Ctrl+F to bring the search option in Notepad.
    • Type just a part of the game's name.
    It is very important to search only a part of the name otherwise you will cannot find any game. (e.g. if i want to find Hidden & Dangerous 2, i just type hidden in the search box).
    • Hit "Find Next" button 'till you find the game your looking for.
    If you cannot find the game please refer to Manual part of this tutorial.
    Step 3: Open the REd and navigate to this location.
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\GameUX
    The KEY name might be different from yours.
    Step 4: Once you find the KEY that belongs to your game, edit as follow:
    • In AppExePath put the location of your game executable.
    (e.g. C:\Program Files\Illusion Softworks\Hidden & Dangerous 2\hd2.exe).
    • In ApplicationId put the xxx value you found in *GameDefinitiongameID="xxx", on the GameUXLegacyGDFs.txt file.
    Add just the value between commas.
    • In ConfigInstallType replace the value to 3.
    • Delete the Title String.
    • Add a new String (Right-click>New>String Value) and name it ConfigGDFBinaryPath, then in the value data space put C:\Windows\system32\GameUXLegacyGDFs.dll
    It should be look like this.
    Step 5: Close the REd and open GEF, wait 'till windows updates the game info.
    • Manual
    If you can't find the game your looking for in GameUXLegacyGDFs.txt, you still can use another already in the file and edit its values.
    Step 1: Go to All Game Guide to search your game.
    Save the cover image for later use.
    Step 2: Now go to Entertainment Software Rating Board and find a game with similar rating.
    Step 3: Now lets find out if its listed on the GameUXLegacyGDFs.txt file, if not keep searching on the ESRB page.
    Step 4: Open the REd and navigate to this location.
    Step 5: Once you find the KEY that belongs to your game, edit as follow:
    Step 6: Open GEF and wait to update the info.
    Step 7: Update the REd by hitting the F5 key and replace the info as necessary.
    This is just the basic info only, you can fill the blank spaces if you like.
    Step 8: Now copy and paste this values and put them like so:
    • in TimeToRefreshBasicData: b357951d59359b57 (Hexadecimal)
    • in TimeToRefreshBoxArt: 855c358859359b57 (Hexadecimal)
    The given values should stop reverting the game to its defaults every once in awhile.
    Step 9: Now navigate to this location and paste the image your game will use as a cover.
    C:\Users\%username%\AppData\Local\Microsoft\Windows\GameExplorer\GamesBoxArt
    The AppData folder is hidden by default you can learn how to unhide it in this tutorial.
    Step 10: Change the name of the image with the one we're replacing.
    • If you wanna use another type of image you need to edit the last part of the BoxArt String to the kind of file you wanna use.
    (e.g. ...//images.../g21004lorom.jpg) JPG/PNG/BMP.
    • Or if you want to use an icon instead, just edit:
    AppExePath put the location of the icon.
    BoxArt leave it blank.
    Step 11: Now open the GEF and your game should display with the new info on it.
    BTW, if you think is too much work for you, just take a look at this tutorial Games Explorer - Edit all credits to Darkness Warrior '96.
    That's all for now...
    Rjck.
  1. Posts : 367
    Windows 7 Home Premium [64-Bit]
    Thanks! Rep+
  2. Posts : 1,065
    Great tutorial Rep+ from me!!
  3. Posts : 161
    it has been a pleasure.
  4. Posts : 6,305
    Great work man, i've been looking for something like this since the early Vista days
    +rep
  5. Posts : 1
    Windows 7 Ultimate
    Hi, Thanks for the tutorial.
    But i have one question: Where I can find the GameUXLegacyGDFs.txt file?
  6. Posts : 161
    It's at the beginning of the tutorial under the purple button that says DOWNLOAD, just need to extract the file from the zip my friend.
  7. Posts : 4
    Windows 7 Ultimate 64bit
    Very nice! Thank you. It seems like a lot of work (I have a lot of games) but it will be worth it in the end. Too bad there isn't an automated tool.
  8. Posts : 161
    There are some tools out there my friend but the info is the always the same in every game...
    lets hope some of your games are already in the GameUXLegacyGDFs.txt file, good luck.
  9. Posts : 5
    Windows 7 x86
    Anyone knows how to manually add an icon or image to a shortcut i put manually in the game explorer in Windows 7 ?
    In Windows Vista you were able to change the shortcut properties and so you could change the icon, but now this option is gone, any help ?
    Thx.
