Windows 7: Color Bit Depth - Display Settings
18 Mar 2011   #10
Brink
64-bit Windows 10 Pro
No problem Mike.
This can help show you how to fill in your System Specs (see How to - System Specs). The free program Speccy is good to help ID your system information.
14 Sep 2012   #11
ZippoLag
MS Windows Server 2008 R2
Hi there!
I'm having a bit of a problem, perhaps you'll be able to help me out:
I have 2 Samsung monitors, a SyncMaster 740N and a 2243LNX connected to each output of a 9500GT (I'm using DVI-VGA adapters on both), I'm running the first on 1280x1024 and the second on 1680x1050 resolutions, but I have a problem: I want to run one on 16bit color depth and the other on 32bit. But this seems impossible (changing the color depth of one also changes the other, even though in the configurations menu they claim to be in the dephts I setted them independently).
So.. any thoughts?
PS: I'm running Windows Server 2008 R2 Enterprise with SP1.
14 Sep 2012   #12
Brink
Hello ZippoLag,
I haven't tried it myself, but you might check in your NVIDIA Control Center settings to see if you may be able to set a different color depth per monitor.
15 Sep 2012   #13
ZippoLag
Quote   Quote: Originally Posted by Brink View Post
Hello ZippoLag,
Thanks for the quick reply!
Anyays, no, I had already tried that too, it's the same as if I were to use Windows's menus..
02 Oct 2012   #14
mohaman
can i choose any of these list of color in my dell inspiron 5050 ... thanks
02 Oct 2012   #15
Brink
Hello Mohaman,
Yes, but using one with 32 bit would give you better color depth quality.
Desktop solid color settings in Windows 7
Hi, Could someone tell me how to change the Hue, Sat and Lum settings for Solid color Black (desktop background) in registry? I have applied solid color black and want to set the Hue, Sat and Lum to 160, 0, 1 through registry. I do tried changing the value HKEY_CURRENT_USER\Control...
Customization
Question for the 32-bit color depth.
Hey guys, I have a question for the 32-bit color depth, before I brought my PC to a repair shop, the windows minimize, maximize and close button looks like the picture 1, but after reformatting it, I re-installed my gfx card drivers, updated MSE, and updated Java (yesterday), and after restarting...
Customization
Desktop Color Settings - Never Right
I have the WORST TIME with my NVIDIA Control Panel to adjust the desktop color, contrast, video and other settings!! One scene on the monitor, it's too dark so I lighten it. Then, the next page, it's too light, so I darken it! I've never seen ANY "program" where just about all the things I see...
Customization
Nvidia color control vs Windows color control settings?
I am trying to set my monitor's screen give accurate renditions of my pictures. I use Quick Gamma to set gamma. When doing this I can use either Nvidia's controls or windows controls (right click desktop>Nvidia Control Panel. When using Nvidia's Control Panel, there are two choices: Use other...
General Discussion
nvlddmkm.sys BSOD, low color depth, no Aero
When I awoke today, I was greeted by a blue screen involving nviddmkm.sys, and when I rebooted, all of the settings were cockeyed on my monitors. I have squared everything, except that I'm stuck with 16 bit color depth and the basic theme, instead of Aero. The theme problem is due to the low...
BSOD Help and Support
change color depth through command line
Hi, how to change color depth to 32-bit in windows through command or registry
General Discussion
