#60
Great news Bear. :)
Need some help...my SSD has 3 basic MBR partitions (C D E)...partition C is the System Drive and I want to convert these partitions(DISK) to GPT..I found a program AOMEI Partition Assistant that is able to convert MBR to GPT without data loss, but it doesn't work because it can't convert system drives...I want to somehow convert partion C to be a normal drive so that this little program can convert my disk to GPT...I know that I won't be able to boot again, but that is not a problem I was going to install Windows anyway....I just want partitions D & E to be intact and GPT.
I know I can unplug my ssd and go to a friend with a PC and just format drive C and then convert the entire disk to GPT...but nobody has a PC anymore.
Hello Catalin,
I'm not sure that's possible on a system drive without reinstalling the OS with UEFI so it will be able to boot from GPT. This of course would mean formatting the hard drive in the process though.
An easier option would be to get a second hard drive, convert it to GPT, create two partitions on it to use for D & E instead of them being on your system drive. This way you could just copy over the contents without losing anything.
Hope this may help some. :)
Ah, yeah I like the Ultra Fast Boot option. I had to flash my graphics card's BIOS to make it UEFI compatible first though.
Tried to do this to a 250gb SSD coupled to a laptop (Window 7 Home Premium) logged in as Admin. All went well until the final step when the alternative "Convert to GPT disk" just didn't appear on the right click menu.
Any suggestion would be appreciated.
OF/O2OF
Hello OF/020F, :)
What do you see instead? Please go ahead and post a screenshot showing this to see if it may help to ID what the issue could be.
Did you try the command option?
Thankyou very much for the innput. I have tried again using the elevated command prompt and went back to MBR.
I hope that the installation will be successful.
Thanks again.
Well although everything looked to be OK MBR wasn't there.
I have coupled the ssd back to the laptop where it appears as drive F
I'm hoping to find the right comand to direct fdisk /mbr at this drive. (I'm of course no racer where DOS is involved.)
