Start Menu - Customize
Page 5 of 5 FirstFirst ... 345
  1. Posts : 72,046
       #40
    Hello Honu,
    If you like, you could export the "Advanced" registry key from OPTION TWO, edit out the values that don't apply, then merge the .reg file in each account you want to apply the settings to. :)
  2. Posts : 7
    Windows 7 Pro 32bit,
       #41
    Thanks Brink.
    That was going to be my "fallback" solution. It should work out fine since I already have a script that I use to do several other things when new user accounts are created. One more will only take what....a half second?
  3. Posts : 72,046
       #42
    LOL, there about that long. :)
