Partition or Volume - Delete
How to Delete a Partition or Volume in Windows 7 and Windows 8
This will show you how to delete a partition or volume on a hard disk using Disk Management or Diskpart in Windows 7 and Windows 8 to create empty unallocated space that you can use to create new partitions with.
  • You will not be able to delete the Windows partition that you are currently logged in to. The only way would be to delete it at boot or during a Windows installation.
  • You also can't delete the system partition, boot partition, or any partition that contains the virtual memory paging file, because Windows needs this information to startup and run properly.
   Warning
  • You must be logged on in an administrator account to be able to do this tutorial.
  • When you delete a partition, all data on the partition is erased.
  • If you disable the Disk Defragmenter service, then you will get the error below when you try to do anything in Disk Management. If you get this error, then make sure that the Disk Defragmenter service is set to only Manual.
OPTION ONE
To Delete Partition or Volume using Disk Management
1. Press the Windows + R keys to open the Run dialog, type diskmgmt.msc, and Press Enter.
2. In the middle pane, right click on the partition of a disk that you want to delete, and click/tap on Delete Volume. (see screenshot below)
NOTE: If the partition is a logical partition, then you will need to delete the free space again to have it as unallocated space. Delete_Step1.jpg3. Click/tap on Yes to confirm deletion. (see screenshot below) Delete_Step2.jpg
4. The selected partition (step 2) is now deleted and is unallocated space on the disk. If not, then delete the partition again until it displays as unallocated space like below. (see screenshot below)
NOTE: You can now use this unallocated space to create a new partition with, or extend another adjacent partition on that same hard disk into it. Delete_Step3.jpg
5. You can now close Disk Management if you like.
OPTION TWO
To Delete Partition or Volume using Diskpart Command
1. Open an elevated command prompt in Windows 7 or Windows 8, or a command prompt at boot in Windows 7 and Windows 8.
2. In the command prompt, type diskpart and press Enter. (See screenshot below) CMD_Delete_Step1.jpg
3. In the command prompt, type list volume and press Enter. (See screenshot below)
NOTE: This will give you a list of volume numbers to select from to delete. CMD_Delete_Step2.jpg
4. In the command prompt, type select volume # and press Enter. (See screenshot below)
NOTE: You would substitute # for the volume number listed that you want to delete. For example, I want to delete the listed volume 3, so I would type select volume 3 and press Enter. CMD_Delete_Step3.jpg
5. In the command prompt, type delete volume and press Enter. (See screenshot below)
NOTE: If it fails to delete, then use type delete volume override and press enter instead. CMD_Delete_Step4.jpg
6. In the command prompt, type exit and press Enter. (See screenshot below) CMD_Delete_Step5.jpg
7. Close the command prompt.
8. The selected partition (step 4) is now deleted and is unallocated space on the disk.
NOTE: You can use this unallocated space to create a new partition with, or extend another partition on that same hard disk into it.
Removing an old recovery partition
I currently have a partition labeled as a system partition by the command prompt. It is the recovery partition that was originally on my laptop but which has since been wiped. I have now installed windows 7 and would like to know if I should, or can, delete that partition
Windows 7 home Premium x64Intel Core i5 480M 2.66Ghz with Turbo Boost u...4.00GBAMD Radeon HD 6550M 2651MB HyperMemory/Intel ...
Acer Aspire Timeline X 5820TG
Intel Core i5 480M 2.66Ghz with Turbo Boost up to 2.93Ghz
4.00GB
AMD Radeon HD 6550M 2651MB HyperMemory/Intel HD Graphics
Conexant High Definition SmartAudio 221
15.6" HD LCD
1366x768
750GB HDD
Verbatim Rapier V1
Hello Rurik,
Without that OEM recovery partition, you would not be able to reinstall your previous operating system that came with the computer unless you created a set of recovery discs from it.
If you have create a set of recovery disc, or have no plans of ever reinstalling the OS that came with your computer, then yes you can delete it. However, I would recommend leaving it unless you just really needed the hard drive space back.
Thanks mate, I dont particularly need the space, It has just been annoying me to have it there when I dont think there is anything in there. My harddrive had to be wiped, so I dont think it has anything in there despite it saying it has about 8gb taken
4.00GB
15.6" HD LCD
1366x768
750GB HDD
Verbatim Rapier V1
You're welcome. :)
Hello everyone, hope you can help.
Stuck with one simple problem: how do i reallocate space between two partitions? I have shrunk one already - but it just created an empty volume on the same partition. How do i move it to another partition, which I want to become bigger?
Thanks for your help.
PS
Yep, it's russian OS in the screenshot, sorry :)
PPS
Oh, and BTW - I don't want to delete data on partitions! I just need to reallocate free space.
Hello Lec, and welcome to Seven Forums.
In your case, it would need to use a 3rd party program like Partition Wizard Home Edition to move free space around. Disk Management is limited and will not do that for you without having to delete the partitions.
Thanks for help, Brink, I've already downloaded that wizard - will try it tonight.
Ok. Please let us know how it went for you. :)
Sorry, forgot to answer on time.
Partition Wizard Home Edition did the job well, thanks a lot! :)
You're welcome Lec. I'm happy to hear that you got it sorted. :)
This may be going back over older material so I'll apologise in advance.
Just to explain my problem.
I have recently installed windows 7 onto a PC with two hard drives, a 40GB and an 80GB. One drive now contains Windows 7 and the second Windows XP. I want to remove all of the info from the second drive as I no longer need to be able to boot up with both operating systems. The problem is that no matter what I try I cant seem to format the drive or remove the volume. I just get messages telling me I cant do it when I try. I've tried carrying out the steps in this thread, but they don't work either. Any suggestions would be very welcome.
Windows 7Intel(R) Pentium(R) 4 CPU 3.00GHz, 2992 Mhz, ...2.5GBRADEON X600/X550 Series (Microsoft Corporatio...
Fujitsu Siemans
Intel(R) Pentium(R) 4 CPU 3.00GHz, 2992 Mhz, 1 Cor
Fujitsu Siemans
2.5GB
RADEON X600/X550 Series (Microsoft Corporation - WDDM)
Dell P790
Size 37.24 GB (39,991,275,520 bytes)
Size 74.53 GB (80,023,121,920 bytes)
Hello Diarmuid, and welcome to Seven Forums.
Which OS was installed first?
Hi, sorry for not getting back sooner - powercut knocked out my connection for a while. XP was installed first on the 80GB drive in the PC. The second 40GB drive came from another PC and that is now the one that has Windows 7.
Fujitsu Siemans
Fujitsu Siemans
2.5GB
Dell P790
Ah, that would be why then since it's the boot drive.
You might see if you can restore the MBR for Windows 7 on the Windows 7 drive first, then see if you can delete only the XP drive at boot using your Windows 7 installation disc in the Custom - Drive options (advanced) section, then just back out of the installation and restart to Windows 7.
Thanks - I'll give it a go and then get back to you.
Fujitsu Siemans
Fujitsu Siemans
2.5GB
Dell P790
I have a problem. I do not have the "Administrative tools" option. Does it exist in a specific windows 7?
Windows 7 Home Premium
Hello Kampinas, and welcome to Seven Forums.
Double check to make sure that you have the Control Panel (All Items view) (click on link) opened with icons showing in the Control Panel. However, you can also open Disk Management by typing diskmgmt.msc in the Start Menu search box and pressing enter.
Hi Brink, I replaced my OEM C: drive on a Sony Vaio F Series notebook. I installed the old HDD in a external enclosure & it works fine.
I tried to delete the hidden recovery partition (8GB) using Disk Management but when right clicking, all I get is "Help" while it works fine for the other partitions & lets me delete them. I then tried elevated command & diskpart following your tutorial, same problem! Diskpart deleted my other partitions but quits when I try to delete the recovery partition.
That Sony recovery partition is really protected. :(
This is nuts! Thanks for your help.
windows 7 64-biti7-720QM6GBNvidia GT 330M 1gb
Vaio F Series Notebook VPCF115FM
windows 7 64-bit
i7-720QM
6GB
Nvidia GT 330M 1gb
1080p
Seagate Momentus 500gb
Hello Joe, and welcome to Seven Forums.
You may be able to during the next installation using the Drive Options (advanced) during setup to delete it. If not, you should be able to use the clean command to completely wipe out the hard drive using a command prompt at boot.
