Partition or Volume - Create New
Page 3 of 48 FirstFirst 1234513 ... LastLast
  1. Posts : 2
    windows7
       #20
    thanks brinks,
    it works now i have 2 drives in my system:)
  2. Posts : 72,051
       #21
    You're welcome Sachin. I'm happy to hear it. :)
  3. Posts : 6
    WIndows
       #22
    Brink said:
    hospitaldoctor1 said:
    Brink said:
    You can shrink your C: partition in step 1 of this tutorial on the first page by how much you want the D: partition to be. Afterwards, you can follow the rest of the tutorial to create the D: partition from the unallocated space that your shrunk from the C: partition. :)
    Hi Shawn,
    Sorry, I am confused. I am not a computer expert. What steps would I follow exactly? What do I do?
    Also, how much would I want the D partition to be? What do you mean? What is a good amount?
    Btw, on my computer management, I dont have an unallocated volume (black). It's all blue.
    Sorry,
    You can follow the steps step by step, with using the links in them for more information, on the first page of this thread for how.
    I would leave at least 40GB for the C: drive, but this depends on how much you want to install on it and on the D: drive for how much space you want to have on each one though.
    on my computer management, I dont have an unallocated volume (black). It's all blue. what do i do please?
    I have a 650GB C drive... how much space should I allocate for the D drive?
    So follow these steps is the same as what i had before?
  4. Posts : 72,051
       #23
    Hospitaldoctor1,
    Looking at your screenshot of Disk Management here, you will need to shrink the C: partition by how much space you want for the new D: partition using the link in step 1 of this tutorial on the first page. Afterwards, that will give you the black unallocated space to then create a simple new volume with as the D: partition. :)
  5. kpb
    hi,
    i just got my new computer with 7 pro installed.
    says that my os (c:) is 434 gb free of 451 gb.
    i want to make another partition, D: to store all my music and stuff.
    what do i enter to make each partition have the equal amount of space? my hd is supposed to be 500gb so i was planning on having each partition be 250gb big. thanks.
  6. Posts : 72,051
       #25
    Hello KPB, and welcome to Seven Forums.
    The hard drive may say 500GB, but it true life it will only be 465.76 GB instead with 451 GB of it for the C: drive total due to the way manufacturers advertise the size.
    Anyways, you can use the link in step 1 in METHOD ONE to shrink the C: drive by how much you want the D: drive to be. Afterwards, use the rest of the steps in METHOD ONE to create the new D: partition. :)
  7. kpb
    hi shawn,
    thanks for the reply and welcome.
    i dont wish to sound like a noob , but can you help me on how much exactly i need to enter to shrink it and to create a new partition?
    thanks.
    here's a screenshot
    Attached Thumbnails Attached Thumbnails Partition or Volume - Create New-untitled.jpg
  8. Posts : 72,051
       #27
    No problem. If you want to split the C: drive in half say to 225 GB for the D: drive, then that would be 230400 MB (1 GB = 1024 MB). :)
  9. kpb
    so i'll need to shrink c: right?
  10. Posts : 72,051
       #29
    Correct. :)
    Be sure to see METHOD ONE in the tutorial on the first page of this tutorial for more detailed instructions on how though.
