Convert a Dynamic Disk to a Basic Disk
Page 16 of 20 FirstFirst ... 61415161718 ... LastLast
  1. Posts : 71,978
       #150
    From the sound of it, you may be better off reinstalling Windows 7 since you were able to recovery your files, and that the Windows 8 Developer Preview has expired.
  2. Posts : 62
    Microsoft Windows
       #151
    I have a strange situation right now. I have a copy of Windows 7 Professional (x64) waiting to get on my computer and get dual booted with my OEM Windows 8.1. In the process of partitioning, being the stupid person I am, I converted my boot disk (Disk 0) into a dynamic disk. I am currently following option one to return to basic and I am stuck since it only allows four partitions for the program to work. I always get 'Failed to convert the specified dynamic disk.' if I try to use it. So I am wondering what partition I can delete. Here are all of my partitions:
    Healthy (EFI System Partition) 500 MB
    Healthy (OEM Partition) 40 MB
    Healthy (Recovery Partition) 500 MB
    Windows 8 Standard Edition (C:\) 1854.76 GB
    Healthy (Recovery Partition) 7.11 GB
    Can I possibly delete one of these and not suffer reinstalling Windows?
  3. Posts : 71,978
       #152
    Hello 1ct01a, and welcome to Seven Forums.
    Please go ahead and post a screenshot showing your Disk Management to help make sure we give the proper advice.
    Since this is an OEM and UEFI installation, it's going to limit the options since we do not want to delete any of your factory recovery partitions.
  4. Posts : 62
    Microsoft Windows
       #153
    There is my disk management.
    I wanted to attach a picture of my System Information as well since I see a strange 1MB Partition. What is that about? I never created a partition of such size.
  5. Posts : 71,978
       #154
    The 1MB partition was created when the Windows partition was converted as Dynamic.
    The safest thing to do would be to do a factory recovery to avoid possibly corrupting the recovery partitions.
    If you have not already, create a recovery drive with a copy of your recovery partitions included to have as a backup. This way you could also use the recovery drive to reinstall Windows with if needed.
    Recovery Drive - Create with USB Flash Drive in Windows 8
  6. Posts : 62
    Microsoft Windows
       #155
    Is it possible to use an OEM disk with my computer for Windows 8? (not 8.1) Also, when I try to create a recovery drive, it says I have required files that are missing.
  7. Posts : 71,978
       #156
  8. Posts : 53
    Windows 7 x64 (Home Premium)
       #157
    I'm following the tutorial but the wizard won't convert the disk to basic.
    It shows error -
    What to do? I've to install Ubuntu on my machine side by windows 7. Ubuntu needs Basic Disks
  9. Posts : 71,978
       #158
    Hello Rajdhakate,
    From the error message, the program only supports converting a "simple" or "mirrored" dynamic volume back to basic.
    More on the different types here: What Are Dynamic Disks and Volumes?: Storage Services
    If you like, you could use one of the other options to convert it back to basic. The other options will wipe the drive though, so be sure to temporarily backup the data to another location first.
  10. Posts : 53
       #159
    Brink said:
    Hello Rajdhakate,
    Thanks for the reply.
    If I convert the disk to basic, then it will effect my OS? Because my windows is installed in that disk only.
    I guess i've to re-install windows then.
