Windows 7: Firefox - Reset to Default
How to Reset Firefox to Default
Published by Brink
05 Jan 2013
information   Information
This tutorial will show you how to completely reset Firefox to default, or reset Firefox while saving your bookmarks, browsing history, passwords, cookies, and Web form auto-fill information.
EXAMPLE: Firefox reset to default
NOTE: This is how Firefox will open after being reset.
Firefox - Reset to Default OPTION ONE Firefox - Reset to Default
To Completely Reset Firefox to Default using a BAT File Download
NOTE: This option will completely reset Firefox to default like when you first installed Firefox. Nothing will be preserved.
1. If you have not already, you will need to close all Firefox browser windows/tabs first.
2. Click/tap on the download button below to download the file below, and go to step 3 below.
Reset_Firefox_Completely.bat
download
3. Save the .bat file to your desktop, and run it.
4. If prompted, click/tap on Run.
NOTE: If you like, you can stop getting the Run prompt by unblocking the downloaded .bat file.
5. You will now notice a command prompt quickly open and close as Firefox is reset.
Note   Note
The .bat file deletes the two hidden folders below.
C:\Users\(user-name)\AppData\Local\Mozilla\Firefox\Profiles
C:\Users\(user-name)\AppData\Roaming\Mozilla\Firefox
6. When finished, you can delete the downloaded .bat file if you like.
7. The next time you run Firefox, it will be reset back to default, and you will see this below before Firefox opens.
Firefox - Reset to Default OPTION TWO Firefox - Reset to Default
To Completely Reset Firefox to Default using Profile Manager
NOTE: This option will completely reset Firefox to default like when you first installed Firefox. Nothing will be preserved. Thanks to our member lehnerus2000 (Peter) for pointing this option out.
2. Press the Windows + R keys to open the Run dialog, type firefox.exe -p, and press Enter.
3. In the profile manager, select the default profile, and click/tap on Delete Profile. (see screenshot below)
4. Click/tap on Delete Files. (see screenshot below)
5. Click/tap on Exit. (see screenshot below)
6. The next time you run Firefox, it will be reset back to default, and you will see this below before Firefox opens.
Firefox - Reset to Default OPTION THREE Firefox - Reset to Default
To Reset Firefox to Default while Saving your Essential Information
NOTE: This option will reset Firefox to default, but will keep your bookmarks, browsing history, passwords, cookies, and Web form auto-fill information.
1. Open Firefox, and do step 2, 3, or 4 below.
2. Click/tap on the Firefox button (top left corner), Help, Troubleshooting Information, and go to step 5 below. (see screenshot below)
3. Click/tap on Help (Menu bar), Troubleshooting Information, and go to step 5 below. (see screenshot below)
4. Type about:support in the address bar, press Enter, and go to step 5 below. (see screenshot below step 5)
5. In the Troubleshooting Information tab, click/tap on Reset Firefox button. (see screenshot below)
6. Click/tap on Reset Firefox button. (see screenshot below)
7. Firefox will now close, reset, and restart. You will see this below for a few seconds before Firefox opens automatically or you could click/tap on Finish. (see screenshot below)
8. After the reset is finished, your old Firefox profile information will be placed on your desktop in a folder named Old Firefox Data. If the reset didn't fix your problem you can restore some of the information not saved by copying files to the new profile that was created. See Copying files between profile folders for instructions. If you don't need this folder any longer, then you should delete it as it contains your sensitive information.
05 Jan 2013   #1
boohbah
Good tutorial shawn, maybe next one on how to back up and restore your firefox profile also.
29 Jan 2013   #2
lehnerus2000
W7 Ultimate SP1, LM18.1 MATE, W10IP VM, W10 Home, #All 64 bit
Old Fashioned Way
Quote   Quote: Originally Posted by boohbah View Post
You should be able to do that the "old fashioned way".
  • Select the Profiles folder (inside C:\Users\<User Name>\AppData\Roaming\Mozilla\Firefox\Profiles)
  • Copy it to your backup location
Additional
I noticed something interesting on my PC.
I have multiple profiles (only one is in the default location, the others are on another partition).
Only the profile in the default location has a folder inside C:\Users\<User Name>\AppData\Local\Mozilla\Firefox\Profiles
If I create a new profile:
  • In the default location, a folder is also created in ... AppData\Local\ ...
  • In another location, a folder isn't also created in ... AppData\Local\ ...
30 Jan 2013   #3
lehnerus2000
Another way to reset Firefox
Another way to reset Firefox is to use the Profile Manager.
1 - Open the Start Menu
2 - Type "firefox.exe -P" (in the Search box, without quotes, remember the space)
3 - In the Profile Manager ("Firefox - Choose User Profile" window), select the "default" profile
4 - Click on the "Delete Profile" button
5 - In the "Delete Files" window, choose "Delete Files" to purge ALL existing user files.
6 - In the Profile Manager, click on the "Exit" button
When you restart Firefox, it will create a new profile and you should see the window that asks you, if you wish to import data from Internet Explorer.
30 Jan 2013   #4
Brink
64-bit Windows 10 Pro
Thank you Peter. Added to tutorial as OPTION TWO.
31 Jan 2013   #5
lehnerus2000
No problems
Quote   Quote: Originally Posted by Brink View Post
No problems (and thanks for the credit).
The other option in the "Delete Files" window, "Don't Delete Files" removes the profile from the "Firefox - Choose User Profile" window, but it leaves all of the files on your HDD.
03 Mar 2013   #6
lehnerus2000
Yet another way to reset Firefox
You can also type "about:support" (in the Address bar) to see more information (like config changes).
You can reset Firefox from that page.
You'll need to click the picture several times to see it at full size.
How can i reset the BIOS to default?
Topic.
General Discussion
Firefox 13 Will Have Reset Button
Read more at: Maximum PC | Firefox 13 Will Have Reset Button
News
Reset CMD to default settings?
I need to reset my CMD to it's default settings how do I do that? I am using Windows 7 Ultimate 32 bit..
General Discussion
I Want Reset WMP 12 Default Size & Position
Hello. I've been looking to Reset the default windows size and position of WMP12 (in the Center of the Screen without Maximizing) the way it is used to be when we launch the WMP12 after a fresh install of Win 7. I know there might be some way to reset it's default size and postion from Regedit...
Music, Pictures & Video
How to reset userChrome.css in Firefox?
Hey everyone, I wanted to see what tabs would look like on the very top of Firefox 4, so I edited my userChrome.css file to do so. Well, there was something wrong with how the code was setup (which most people would never notice), so I want to disable it now. So, I erased the code out of...
Browsers & Mail
Firefox Reset ?
I am a disabled person not technical in Firefox I want to Reset all preferences to program defaults by do this Resetting preferences - MozillaZine Knowledge Base My question is will I lose my bookmarks ?
Browsers & Mail
