Window Color and Appearance - Change
Page 7 of 8 FirstFirst ... 5678 LastLast
  1. Posts : 416
    windows Ultimate
       #60
    Hmm I guess I will have to get used to it. Thanks anyways :)
  2. Posts : 44
    Hello @Brink
    Do you know if this will work for changing control panel's and related applet's text size?
  3. Posts : 20,583
    Win-7-Pro64bit 7-H-Prem-64bit
       #62
    Bongo in Customization can likely help you but you will need to take screen shots of exactly where you want larger text.
  4. Posts : 44
    Thanks TZ. Is Bongo a user, a thread? where should I go to post the screenshots?
  5. Posts : 20,583
       #64
    Add the screen shots to your original thread
    Yes Bongo is a forum member :)
  6. Posts : 44
    Done
    I added the pictures to my OP in that thread
  7. Posts : 759
       #66
    Hi, Brink, I have changed some settings in the windows colour, which i could not revert back. Can i opt for default settings from the changed one. Where is the menu in windows ultimate 7
  8. Posts : 72,052
       #67
    Hello jraju, :)
    Using Option Two should allow you change Windows color.
    If all else fails, you should be able to change the theme to use its default settings instead.
  9. Posts : 759
       #68
    hi, what is ask is i have changed some settings, which i do not want . I want to reset to the default windows settings on this. Is there any menu to revert back
  10. Posts : 72,052
       #69
    In that case, what specific settings did you change, and what is preventing you from being able to change it again?
    We may be able to tell you what the default is.
