#60
Sorry, but that software is rather useless
It is only able to insert a .theme file into the right directory. It is also required to have a folder in that directory, which you have to move in there manually, so i can't see the point of using this software to move one file then move the folder to the same directory manually after. I guess it's good for replacing system files tho, but i wouldnt reccomend using it for it. Best done manually.
