Windows 7: Theme - Customize Custom Themes
How to Customize a Custom Theme from deviantArt
Published by sergiogarcia9
17 Oct 2009
Theme - Customize custom themes
information   Information
This tutorial will show you how to customize a custom theme with custom taskbar, start menu etc.
Note   Note
To do this you need:
  • ·A pre made custom theme from DeviantArt, in this tutorial I will be using one called Dark7mix
  • ·Restorator (Shareware) or any other editor that is able to edit the msstyles file
  • ·Photo editing software, Photoshop, Fireworks, paint.net, Gimp etc.
  • ·Basic Photo Editing experience
Now go to Dark7mix Theme UPDATED by ~adrianodj25 on deviantART to download the pre made theme.
Unpack the rar/zip file, using winrar or a similar tool.
Now move the folder including the themepack file to: (Your drive letter):\Windows\Resources\Themes)
Now that you got the theme, go to the msstyles file (Inside the dark7mix folder, there should be a file called dark7mix)
Open that file with Restorator (or similar) and extract it to a new folder on your desktop.
Now all the images needed will be located in the new folder on your desktop (The one called IMAGE)
HOW TO APPLY THE CHANGED IMAGES:
To apply the images to the theme, switch to the windows 7 default theme, log off, log on, go to the theme folder (C:\Windows\Resources\Themes) Open the msstyles file, and edit the images as you wish to. Now hit save. Now go select the theme (right click, Personalization) and apply. If you have done it right the changes should show. When you want to apply a new change, do this step over again.
CUSTOMIZING TASKBAR:
The taskbar images in this theme are 921 and 1166. Customize these as you wish to.
START MENU:
The start menu pictures are the following: 870, 871, 872, 873, 875, 876, 880, 881, 882, 883, 884.
Customize these as you wish.
SCROLL BARS:
These are the scroll bar images: 769 (Vertical) and 770 (Horizontal)
Now you got the basics location of the files, try to mess around with these and more, usually you can easy figure out which image is where. If you got any questions or need a particular image location, give me a PM or ask a question in the thread and I will try to help you.
Have fun
Useful links:
Adobe Photoshop CS4 30-Day Trial: Adobe - Downloads
Paint.net (Freeware): www.paint.net
Gimp (Freeware): GIMP - The GNU Image Manipulation Program
17 Oct 2009   #1
mansrm81
Windows 7 Ultimate x64/ Windows Vista Ultimate x64
Fabulous keep up the great tutorials Sergio.
05 Nov 2009   #2
edrik
Windows 7 Home Premium SP1 64-bit
Just wanted to share..
the command module is number 1010
and the preview pane is number 1022
05 Nov 2009   #3
Uber Philf
W7 RTM Ultimate x64
Shame the numbers arent all the same for every theme, it makes it alot harder to modify.
05 Nov 2009   #4
edrik
I think it gives the same numbers for VSB users
05 Nov 2009   #5
sergiogarcia9
VSB has different sections like Taskbar, Buttons, boxes etc so it is a lot easier to use than doing it this way
05 Nov 2009   #6
Uber Philf
W7 RTM Ultimate x64
it is, but its still confusing everytime i edit something, it comes out in NON aero form
10 Nov 2009   #7
Psych0t1c
Windows 7 Ultimate 7600 RTM - Windows Server 2008 R2 7600 RTM Dual Boot
Quote   Quote: Originally Posted by edrik View Post
Attachment 35152
Do you mind uploading your theme? And your explorerframe if it's x64. I tried moding my frames but when I log off and log on explorrer won't run and I get an error.
13 Nov 2009   #8
gohardsupreme
windows 7 home premium sp1 x86
can anybody tell me where to find a restorator like program thats free?
14 Nov 2009   #9
moinmoin
Win 7
Anolis Resourcer for x32 and x64
Anolis - Releases
Theme - How to Apply Custom Themes
How to Apply Custom Themes in Windows 7 This will show you how to apply a custom theme from deviantART as your theme in Windows 7. Here's How: 1. First you will need to click on the Download button below to download and install either the 32-bit (x86) or 64-bit (x64) Universal Theme...
Tutorials
Custom visual style theme not working, only shows Basic themes?
Every time I switch from one of the original Aero themes into a custom theme with visual styles, it turns into a Windows Basic theme? I can back to Aero fine, but switching into the same custom theme will only show the basic theme.
Themes and Styles
Can't change back to custom theme from classic theme w/o restarting
Windows 7 Ultimate x64 SP1 Hello. I've recently reformatted my computer and since then I've been having this rather annoying problem. When I select classic theme from the personalization menu then try to switch back to my custom theme, the only thing that changes is the color scheme but nothing...
Customization
Customize boot up theme
can anybody tell me how to change my boot up theme? its wrecking my head. thanks :)
Customization
Themes - Customize Information, Settings, and Name
This is what you will need: Notepad or Notepad++ Copy of the original Aero folder + aero.theme file from the Themes folder (C:\Windows\Resources\Themes)
Tutorials
Custom Themes, Custom Icons
With the addition of slideshow within Windows 7 it is now possible to do away with single image backgrounds. This short thread will teach you how to create your own themes and use custom icons for that theme. First you need to decide what wallpapers you wish to use for you slideshow, these...
Themes and Styles
