#680
Thanks JeffK and nuggamerph
I had the:
ERROR: Could not delete existing file "ûbC:\expandedSetup\boot\etfsboot.com"
problem and the JeffK/ nuggamerph script solved it.
Thanks.
I had the:
Thanks.
when i try to run oscdimg the command window only flashes up on the screen for a split second then its gone. why? and how can i fix this?
Hi Lilmac,
Use this instead. Bootisomaker.zip
Unzip it.
Then Rt click and run as admin on bootisomaker.cmd.
I have only just seen this last post.
Bit late replying - glad to be of help.:)
