#210
another thing, but expandedSetup folder on my desktop is only 205MB. setup2.box is 160mb and setup1.box is 2.66GB. Did my download complete all the way?
Accordning to OSCDIMG, it wrote 872 files in 200 directories.
I can't get it to boot from disc what do I do??
This has got be the most ridiculous thing ever. I should have just bought the upgrade disc. Digital River should have at least told us that this would be an .exe and we would have to hack it to get it to work the way it should.
figured it out!!!!
ran command prompt as administrator
FRAC!
I thought the pre-release details said the pre-existing Vista installation could be on a different partition, or different physical hard disk, or even on a USB drive!
This little wrinkle means extra work for me, cloning my existing Vista over to the new drive I'm planning to use for W7. My Vista drive is a WD64000AAKS that is ultra noisy. Sounds like sleigh bells. Every time I use the computer I look over my shoulder expecting to see a miniature santa and eight tiny reindeer. I'm moving to a very quiet WD4000AAKS.
Drat the luck.
Marc
[/QUOTE] im not quite understanding this. do i jsut physically copy and paste the 2 files into my C Drive in my computer?
[/QUOTE]
Yes.
If you are rebooting and nothing happens with a properly burned disc as well as having the cd as priority in bios, try mashing all you F# keys from start up till it lets you pick which drive to boot from. f4-f8 i think
