#320
FWIW. I did one (W7 Pro x86) and the output matched all of the lines in your OSCDIMG utility exactly.
I used SIW2's syntax but did it from a different drive.
I think we need to figure out what the correct file hashes are and list them somewhere. The difficulty will be that this isn't (yet) a Microsoft project so they haven't published hashes.
I also think a lot of this confusion can be cleared up if people look over the OSCDIMG help information before proceeding. Don't rush through it, study the process for a minute. From the command prompt just type "oscdimg /help". You'll get a list of subcategories and be able to learn what the switches do (-h, for example, includes all of the hidden source files and directories), where to put them, and how to place them.
It's not magic, really, it's an old, old programming requirement....syntax.
