NVIDIA Drivers - Avoid Problems
Page 1 of 11 123 ... LastLast
    How to Avoid NVIDIA Driver Problems
    This tutorial will show you how to do a clean install of NVIDIA graphics drivers for those having problems with the drivers.
    Here's How:
    1. Download the driver you want to install from your computer manufacturer or from NVIDIA.com.
    2. The first thing to do is open Windows updates, in the left column click change settings, in the drop down box select check for updates but let me choose whether to download and install them. The purpose of this is to keep Windows update from automatically installing a driver. We do not want conflicts with drivers.
    3. Next go to your "C" dive and there should be a folder named Nvidia.
    4. Open the folder and you will find a folder named 'Display Drivers', inside that folder will be all the drivers you have installed designated by number.
    5. Delete all of the folders with numbers but Do Not delete the Display Driver Folder itself.
    6. Next go to Control Panel (category View) and Uninstall a Program
    7. Scroll down to the Nvidia drivers and begin to uninstall them but read the info box below before you start.
    If you have an Nvidia chipset, DO NOT uninstall the chipset driver only the Display drivers. Also, uninstall all of the display type drivers but BE SURE TO UNINSTALL THE GRAPHICS DRIVER LAST.
    8. When you uninstall the Graphics driver, Windows will request a reboot, do so. Upon reboot Windows will install a graphics adapter, that is good.
    9. Open the new driver you downloaded, agree to terms and select custom install. Under custom install uncheck everything except the Graphics driver, PhysX and GeForce experience, if you want that. Be sure the 'CLEAN INSTALL' box is checked
    10. Your set up should look like this.
    11. Click next and begin the installation, after which you will reboot. This should give you a clean install of your drivers. You can now re set Windows Update to your preferred setting, as you are through.
  1. Posts : 18,415
    windows 7 home 64bit
    Nice work Steve
  2. Posts : 26,869
    Windows 11 Pro
    maxie said:
    Nice work Steve
    Thanks very much, Maxie. It's my first and most likely needs some work.
  3. Posts : 24,479
    Windows 7 Ultimate X64 SP1
    Good job Steve, especially the Windows update part.
  4. Arc
  5. Posts : 2,409
    Windows 7 Professional 32-bit/Windows 8 64-bit/Win7 Pro64-bit
    Will help for GPU upgrades. Thanks essenbe. :)
  6. Posts : 26,869
    Windows 11 Pro
    You're quite welcome.
  7. Posts : 7,466
    Nice Steve this will help a lot of people with issues of late
  8. Posts : 26,869
    Windows 11 Pro
    Thanks Tommy, I hope it will.
  9. Posts : 5,915
    Windows 10 Pro X64
    Great tutorial Steve. Bookmarked to point users here
